Heyloo guys!
Yep, you right... We're gonna have another OCing Report and this time I'm focusing on Corsair's latest-greatest 2GB DDR2 set of low latency TWIN2X2048-6400C3.
This is the first ever PC2-6400 memory kit to be rated at CAS3 and also the one to feature EPP (Enhanced Performance Profiles), new memory standard that Corsair and NVIDIA came up with. The kit is rated at DDR2-800 9-3-4-3.0 @ 2.2v and built with highly screened for low-latency performace, Micron's new D9xxx ICs. After Micron's legendary D9 "Fatbody" was discontinued, memory manufacturers went searching for the next best thing. They sampled few other of Micron's ICs, like D9GKX, D9GHM, D9DCN... Some in-house testing, screening and sorting later... bang!... Le Roi est mort. Vive le Roi!
Anyway, for those of you that don't know yet what EPP is about, here a short explanation:
Unfortunately, M2N-SLI Deluxe BIOS doesn't support this feature yet and I'm honestly not sure if it ever will. From what I gathered, only nForce590 SLI chipset supports it, so no EPP for me... I would most likely not use it anyway, but I'm sure there are quite a few beginners that are just starting their adventure with overclocking. With help of EPP and compatible motherboards, they would have a good start and a convenient way to get their overclocking adventure going.Jointly developed by Corsair and NVIDIA® as a new open memory standard, Enhanced Performance Profiles elevate memory performance by taking full advantage of the additional memory parameters (such as Command rate, memory voltage) that are now added to the unused portion of the JEDEC standard Serial Presence Detect (SPD). Memory modules from Corsair support two types of performance profiles that are based upon a high frequency or low latency design. Enhanced Performance Profiles brings simplified overclocking success for entry enthusiasts, and access to more advanced memory specificationsand a higher recovery point to hard-core overclockers.
Let's take a look at modules, shall we?
This OCing Report will focus at two aspects of memory overclocking: MAX all-stable and MAX 1M/Sandra only DDR2 clocks. The platform I've been testing this set on, delivers up to 2.5vdimm and this is how far I went to get the best out of this RAM. I will be soon volt-modding this board to allow 2.7+ vdimm and then try to hit even higher speeds
Configuration of my platform is as follows:
Testbed Configuration
AMD AM2 3200+ "Orleans"
ASUS M2N-SLI Deluxe (nForce570 SLI)
Corsair TWIN2X2048-6400C3 2x1024MB
Single EVGA 7800GTX KO @ 490+40/1390, ForceWare 84.21, Modified driver settings (High Performance)
Let's get going with the first part of my stress-testing:
Part1: High-stress testing
MAX fully stable DDR2 clocks @ 8-3-3-CAS3.0 ---> DDR2-882 @ 2.5v
SPi32M -------------------------------------------------- SP2004 LargeFFT 1024MB used
3DMark2001 & 3DMark03 -------------------------------- 3DMark06
6400C3 reached very impressive, fully stable DDR2-880. Past that, I was not able to pass SPi32M, nor required 2hrs of SP2004. Nevertheless, very good result at 8-3-3-3.0!
MAX fully stable DDR2 clocks @ 8-3-4-CAS3.0 ---> DDR2-940 @ 2.5v
After relaxing to TRCD=4 I managed to climb a bit higher, up to DDR2-940 and still at CAS3. This is 17.5% overclock from stock DDR2-800, which is quite sweet, isn't it?
MAX fully stable DDR2 clocks @ 8-4-4-CAS4.0 ---> DDR2-1100 @ 2.5v
Yep, DDR2-1100 has been broken with this kit and 2.5vdimm. Good for the eyes and very good for performance as well![]()
Part2: Low-stress testing
MAX benchmark stable DDR2 clocks @ 8-3-3-CAS3.0 ---> DDR2-920 @ 2.5v
SPi1M --------------------------------------------------- Sandra 2007 Memory Bandwidth
Yeah, DDR2-920 8-3-3-3.0 for you 1M'ers
MAX benchmark stable DDR2 clocks @ 8-3-4-CAS3.0 ---> DDR2-956 @ 2.5v
How about DDR2-956, with slightly relaxed TRCD=4 and still CAS3.0 ?
MAX benchmark stable DDR2 clocks @ 8-4-4-CAS4.0 ---> DDR2-1112 @ 2.5v
And some more in 8-4-4-CAS4.0 compartment...
Conclusion
So what can I say? TWIN2X2048-6400C3 has some serious OCing potential and will sure please a lot of hardcore OCers out there. I could not think of any disadvantage of this set, except for the price... Extensive screening and sorting of already expensive Micron D9 dies that this set is made of, contributes to it's premium price. It sure isn't cheap but If one wants some of the greatest then one often needs to pay for it. It's a kickass performer, not only at low latency but high frequency overclocks as well! You name it, 6400C3 delivers!
July 1st UPDATE!
MAX SPi32M stable DDR2 clocks @ 8-3-3-CAS3.0 ---> DDR2-900 @ 2.5v
SPi32M
MAX SPi32M stable DDR2 clocks @ 8-3-4-CAS3.0 ---> DDR2-950 @ 2.5v
SPi32M -------------------------------------------------- 3DMark2001 & 3DMark03
Any questions or requests are welcomed,
So on![]()
