Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: E6600ES temps on air? too high?
    Jan 2004
    Frankfurt, Germany
    Hi there, my lovely E6600ES arrived yesterday and I was messing around a bit with it. I'm using a Scythe Ninja to cool the cpu. At standard voltage it's already at 50° in BIOS and goes up to 60° when primed. Roomtemp is ~25-26°. Can anyone else tell me his temps? (in case you don't know which tool: everest home -> computer -> sensors)
    Jul 2005
    ATX
    is this on the badaxe? ppl have been reporting high sensor temps on that board,
    Xtreme Legend
    Dec 2003
    Northern California
    I would recommend not using more than 1.6v with air cooling. 1.5-1.55v is probably better. The BIOS temp readings on some of these boards are nowhere close to being accurate. On the Bad Axe, the BIOS temp may say 60C, when it's actually closer to 30C when measured with a probe.
    50C with stock voltage sounds way too high. You should be idling in the 30's.
    Jan 2004
    Frankfurt, Germany
    Yep indeed. Bad Axe 304 newest bios. Got a link on that?
    Jan 2004
    Frankfurt, Germany
    Quote Originally Posted by sierra_bound
    Well that's what scares me, but if you're confirming that the bad axe is reading too high, I'm fine.
    Feb 2005
    Somerset UK
    I had an application that i picked up from the Yonah thread that read the core temp direct from the CPU, this was much more accurate than the motherboard. It does not seem to work with the Asus p5W DH and an 805... might work with Conroe. http://www.thecoolest.zerobrains.com...opic.php?t=137
    Give it a try. and see if it works...may give a better indication of temp!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    i'm on water with e6600 on badaxe, bios idles at stock vcore 31C and at 1.418v vcore idles at 34C... load temps are 34-38C in windows according to everest heh
    Feb 2005
    Somerset UK
    Just read the details and says it does conroe temps off the die http://www.thecoolest.zerobrains.com...opic.php?t=137
    Jan 2004
    Frankfurt, Germany
    Hm thanks for that eva2000, I feel much better now :P
    @simonmaltby
    core temp has the same value as the bios
    WHY is this pos cpu so hot?
    Jan 2004
    Frankfurt, Germany
    Come on guys, I'm not willing to buy a new cooler for nothing. Gimme more temps!
    Xtreme Legend
    Dec 2003
    Northern California
    Have you tried using the Intel Utilities Program? It's on the motherboard CD. It's a little accurate than the BIOS as far as reading temps.
    Feb 2005
    Somerset UK
    Are you 100% sure that you have good HS contact. Might be worth taking off, cleaning and reseating?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    how you ascertain that ?
    Xtreme Legend
    Dec 2003
    Northern California
    A friend has the Bad Axe. He used a thermal probe to determine the truth. BIOS read 60C. Utilities program read 45C. Probe read 30-35C.
    I also had a Bad Axe. Temps in BIOS were always very high. I just ignored them.
    Jan 2004
    Frankfurt, Germany
    I already took off the cooler and lapped the IHS, but it was already flat. I tried the programm Core Temp, but it also gave me results as high as 60°C. I found a thread here where many people got problems with the BIOS readings. But what about "Core Temp", did it also gave such results for you? I don't feel comfortable about ignoring these temps since I don't know exactly they're misread.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    interesting i'm play on water with e6600 @3810mhz at 1.453v vcore fixed via ITK modded bios and bios says 46C idle hehe
    sai i'll let ya know a bit later just doing a prelim memtest before i let it boot into windows since i'm testing a new pair of ram too heh
    Xtreme Legend
    Dec 2003
    Northern California
    If you have a probe, you should test and see what results you get. My friend was getting high readings in the BIOS and decided to check for himself.
  18. #18
    Jan 2004
    Frankfurt, Germany
    That's the problem, I don't have one.
  19. #19
    Apr 2003
    Israel
    my 6600 on badaxe 304 - 1403 bios read 55C~ in the bios idle in win 50C~
    stock cooler
    stock vcore
    the hsf feels hot...
    btw:
    i got "internal temp" 10C lower the "cpu" ...
  20. #20
    Mar 2005
    Quote Originally Posted by The Byter
    stock cooler
    stock vcore
    btw:
    What heatsink? And is it on stock clocks/volts?
  21. #21
    Memory Addict
    Aug 2002
    Brisbane, Australia
    hmmm bad axe has 3 temps in bios mine at 3810mhz at 1.441v read
    cpu 45C
    internal 31C
    remote 30C
    maybe internal or remote is the internal cpu temp ?
  22. #22
    Apr 2003
    Israel
    Quote Originally Posted by taemun
    intel stock HSF 0.28A
    all stock
  23. #23
    Jan 2004
    Frankfurt, Germany
    Quote Originally Posted by eva2000
    cpu 45C
    internal 31C
    remote 30C
    Ain't that Northbridge and Southbridge temps? BTW do I need to disable speedstep in windows or will it work when I just switch it off in BIOS. I'm asking because FCG made this Speedstep disabling tutorial?
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    E6600 QPGE Step 5/B1 / Intel D975XBX Badaxe rev304 temperatures
    Well here's some temperature readings but not sure which is right. Most badaxes owners say bios temps are +10C higher than reality.
    @9x266fsb = 2400mhz stock vcore 1.242v
    Room temp = 24.8C right now
    Bios cpu temp = 30-31C
    Windows Idle = 27C/25C for core#1/core#2 most of the time but fluctuates by +3C for both cores at times.
    Windows Load (dual stressprime) = 37C/37C for core#1/core#2
    click image for larger pic
    Will do oc'd temps later
  25. #25
    Jan 2004
    Frankfurt, Germany
    Any more input guys?
    Hm so what to do now? Just ignore that and keep below 1.5v? i'm sure it'll go up to 70° with 1.5v and decent oc, well shouldn't be harmful anyway considering the tcasemax of 85° ?
