Hello XS,
Long time reader, relatively new poster.
As many others, I plan on buying Conroe in about a month or so.
I have most of the system figured out, and the plan is to buy a E6600 and a 7900GT.
But! With all the new motherboards out, I am a little unsure which motherboard i should buy.
Right now I have narrowed it down to these three boards:
P5B (non-deluxe) (215$)
P5B Deluxe (293$)
P5W DH (276$)
I plan to do some silent air, perhaps Tower120(how noisy is it?) or Scyche Ninja+.
One of the things that I wonder most about is whether motherboard FSB wall will mean anything to me with this relatively lousy cooling.
I do not have an urgent need for WiFi+Accesspoint, but I could use it(it can be used as a wireless swich/router, right? So i can have my laptop on wireless). The remote sure is handy, and I think I will use it a bit.
Also: I think I'll buy a Antec P150 case with an Antec 430W PSU. This has a 4-pin powerplug, so I wouldn't take advantage of a motherboard with 8-pin powerplug.
I think I'll go with eigher P5B Deluxe or P5W DH, but whichI wont run Crossfire, but maybe SLi someday(I know it's not supported officially, but I think the hacked drivers with support for 7900 will be out when/if I upgrade(not for the next 6-12 month))
I hope you don't think, "Oh no, another "want-to-buy-conroe" noob asking questions". I have done a bit of research on this, but can't quite deside.
Thanks in advance XS - you are the greatest![]()
