Results 1 to 16 of 16
Thread: First Results: BiostarT TForce 500, A64 3500 Orleans, Corsair TWIN2X2048-6400C4
    Jun 2006
    Chattanooga, TN
    This is my first overclocking experience. This is the highest clock I can boot. Voltage is high at 1.7. Also right now the HTT is running at 3x264...for some reason I can't change the CPU Multi...whatever I set it to, it just defaults to the stock (though the bios shows mine). I want to run 9x322 for this speed that way I could get a better HTT. I'll add some hardware pics tomorrow after work and work on some better results. Also thanks to all who helped me decide on hardware.
    Jan 2005
    Slovenia -> Ljubljana
    1.7V!? Would you like to burn CPU or what? If you're on air you should immediately lower volts
    Gigabyte 890GPA-UD3H
    AMD Phenom II X6 1055T
    Kingston HyperX 2x2GB DDR1600
    Asus A5770 1GB
    ***CPU & GPU H2O cooled***
    Xtreme Cruncher
    Nov 2005
    Netherlands
    2.9 is pretty good, nicely done.
    But does that 3500 really need 1.7v (what you set in BIOS is real) for a 1m SuperPi? What are your 24/7 clocks on this one?
    You should really be able to lower the multi, if you cant you need to flash to a diff BIOS. You need this lower multi not for high HT bus but for your memory clocks.
    edit: Igor0203 thats more than likely just for benching 1m there.
    Jun 2006
    Chattanooga, TN
    Quote Originally Posted by igor0203
    Well the monitor said 36c under load so I figured I was safe
    Quote Originally Posted by v0dka
    Well for some reason I had reached the conclusion that it wouldn't even boot under 1.7v but I think that was my sloppy notes because just now I switched to 1.6v and no problem 1m even did the same.
    Yeah the lower clock would help with the memory too...really noob question: what's a 24/7 clock?
    Oh, and I don't think biostar has any other bioses available for this board.
    Jun 2006
    well i'd say it's a decent OC you got there at 2.9G but i got a question , how come you get 31S only on superP at that clock ?? isn't too a bit too slow at that clock ?? is it because it's a dual core maybe ??
    Jun 2006
    Chattanooga, TN
    its not a dual core, that's actually an error on CPUZ's fault, and I don't believe 31 is slow for that clock, I think to get below 30 you have to break the 3 Ghz mark.
    Jun 2006
    Thats a pretty nice overclock there. I'm trying to tweak my x2 4000+ Windsor with that same motherboard. Right now, it maxes out at 2.75 ghz with 275x3, however the idle temps are still low (below 25-30 C). Somehow, whenever I push the frequency past 280, the reboot reverts my processor's speed back to 2.01 ghz. You seem to have nice results with the Biostar Tforce 550, so could you please help me with my issue here? Thanks
    Chuck Norris Worshipper
    Dec 2002
    Stevens Point, Wisconsin
    nice, i'm looking to get that 6400C4 ram myself...
    Xtreme Cruncher
    Oct 2004
    Germany, near Stuttgart
    Quote Originally Posted by akijikan
    31sec @ 2,7ghz is no problem at all!
    nice results. i like those biostar board. have the nf4ultra version and its clocking very good.
    E2160 @ 360x9, max 390x9 watercooled
    GA-P35-DS3
    Cellshock D9GMH @ 545mhz cl5-5-5-5-15
    Palit 7300gt 500/1000 @ 780/1600 watercooled
    XS_THE_MACHINE
    Jul 2005
    Exton, PA
    I get 27s at 3GHz with my 165, I've seen other people's pi results that looked slow as well. seems AM2 is a bit slower than 939 on pi.. first thing you might wanna do is set a bigger up-divider, 322 is kind of slow for DDR2
    Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
    http://www.last.fm/user/repoman0/
    Jan 2006
    i can get 31s below 2.7... lower multis/high fsb help alot. i also used a 2gb kit, but my chip is a s939, ddr2 has really high latencies and that probably hurts your score. if you had 1gb of ddr, you wouldve broke 30s at 2.9
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    ahhh yes biostars infamous 270-280 HTT limitations
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
    May 2005
    Arizona State
    if he had better ram running 500+ 4-4-4 instead of 322mhz it would be a good time
    Q6700
    MSI P35
    8GB OCZ
    2xHD 2900 XT
    PCP&C 1kw
    Live Long And Overclock
    Sep 2004
    Very nice
    Perkam
    Jun 2006
    that's what im sayin .. 31s is definatly slow for almost 3G's... i myself get 34 for 2.5Gh/z on a venice...that's why i thought there was somethin wrong with your P results and then wondered if you're using a dual core...
    anyway, as said before, it's maybe your timings but 31 is still slow IMO. for nearly 3Gh/z.. i actually beleive you got somethin wrong in your hardware or tweaking that bottleneck you OC performance... good luck in tweakin !
    Dual Bios GA-K8NS PRO 939 Nf3 Ultra ~ Venice 3200 @ 2.5Gh/z Air Cooled By a Big Typhoon ~ Corsair 3200 XMS XL Twin's -512*2- @250Mh/z with 3-4-3-8 1T ~ POV 6800GT @ 420/1.12 Air Cooled By an Nv Silencer5 rev3
    Jun 2006
    Chattanooga, TN
    Yeah, I'm currently talking to Biostar support about the CPU multiplier issue beacuse its really holding me back...it looks like I'm headed for an RMA though.
    If that gets taken care of them I can put the memory where it should be...the RAM is supposed to be good OC and it irks me that that potential is going to waste. And Thunder I think it is different for DDR2 memory as cky2k6 pointed out.
