Yes i'm back and you get to watch me continuously post benchmarks with my new toy
I couldn't wait for Gecube to provide me with my X1900XTX/XT Crossfire cards for my testing on DFI CFX3200-DR http://i4memory.com/cfx3200dr/ so decided to fork out for half the setup myself, in the form of a 512MB Gecube X1900XTX card
The card arrived yesterday but since i have the flu and bad cough keeping me up at night I thought I'd give the card a whirl
System:
WinXP Pro SP2 fully updated
6.70WHQL Chipset drivers
6.5 Catalyst Official drivers
Right now stock heatsink air cooled with fan speed at 100% I managed on GPU core using ATI Tool 0.24 beta 14.
GPU Overclocking
1.175v = 655mhz
1.400v = 684mhz
1.425v = 702mhz
1.450v = 712mhz
1.450v = 720mhz with ~63C load temps as monitored via Rivatuner RC16.
1.500V = 725mhz with ~66C load temps as monitored via Rivatuner RC16.
1.500V = 729mhz with ~66C load temps as monitored via Rivatuner RC16.
Here's one of my first 3dmark05 runs with ATI Tool and Rivatuner RC16 running in background.
Video Memory Overclocking
As to memory clocking, seems like my 512MB HIS X1800XT, part of the puzzle is GPU voltage, as you increase GPU volts, mem clocks higher at some point. Here it seems to be at 1.525v GPU volts.
GPU/VDDC/VDDQ/VDDCI = GPU/Mem
Note: PASSED means ATI TOOL continued to run at that stated speed only.
1.500v/2.086/2.086/1.486v = 725/801-805.5mhz PASSED
1.525v/2.086/2.086/1.486v = 725/810-814mhz PASSED
1.525v/2.168/2.086/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.135/2.006/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.140/2.121/1.486v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.105/2.102/1.510v = Artifacts at 725/850-855mhz
1.525v/2.113/2.102/1.510v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.121/2.102/1.510v = Locked up in ATI Tool at 725/814mhz heat up phase
1.525v/2.113/2.102/1.510v = PASSED dropping GPU by 5mhz = 720/846mhz
1.500v/2.113/2.102/1.510v = Locked up in ATI Tool at 720/823mhz heat up phase
1.500v/2.113/2.102/1.493v = Artifacts at 720/846-850mhz
1.500v/2.119/2.108/1.493v = Locked up in ATI Tool at 720/814mhz heat up phase
1.525v/2.113/2.102/1.493v = Artifacts at 720/837mhz
1.525v/2.113/2.102/1.510v = Locked up in ATI Tool at 720/859mhz heat up phase
1.525v/2.116/2.105/1.524v = Locked up in ATI Tool at 720/855mhz heat up phase
1.525v/2.119/2.105/1.510v = PASSED at 720/846mhz
1.525v/2.119/2.105/1.540v = Locked up in ATI Tool at 720/868mhz scanning artifact stage
1.525v/2.119/2.105/1.563v = PASSED at 720/855mhz load temp 75C
Haven't found the max yet for GPU or Mem, but at this point it seems the memory needs more GPU voltage to clock higher than 801-805mhz.
Seems for 3dmark05 at least 720/850 is achievable with 1.525/2.119/2.105/1.563 with load temps of ~67-75C.
3dmark05 = 13,885
http://service.futuremark.com/compare?3dm05=2077846
While Rivatuner RC16 and ATI Tool were running in background.
@720/850 - 13,885 http://service.futuremark.com/compare?3dm05=2077846
@720/850 - 43,894 http://service.futuremark.com/compare?2k1=8998288
@720/850 - 6,962 http://service.futuremark.com/compare?3dm06=353082
Doesn't seem to be the best clocker, but not bad at all
