Hello all,
I just wanted to confirm whether or not the Intel D975XBX CPU temp readings are indeed actually off.
I'm running a 3.6GHz CPU (not o/c'd) with a Zalman 9500 cooling, and the BIOS (the version it was shipped with; not sure which) is reading my CPU temp at 60C idle... which cannot be accurate.
I've heard that people running 3.6 CPU's sometimes cant get their temps below 50C, but in my old ASUS board, with the Zalman, the BIOS read 40C idle.
So... not sure whether to believe that BIOS or this one, though I know FCG (whom I emailed... thx for the info) said the BIOS on the Intel D975XBX reads only the CPU temp wrong.
Am I running that hot due to the power of this particular board? Or is it simply reading 20C hotter than what I'm actually running?
If anyone else can confirm this, just so I can double-check that I'm safe (don't want to burn anything out), please let me know.
I'm using air cooling through my entire modded Lian Li case, and my ambient temp (in the summer) is being read the same, at 40C roughly, by both the BIOS and Riva Tuner.
Thanks much in advance, your help is appreciated.
