Results 1 to 14 of 14
Thread: Conroe Stepping 4 on Asus P5W DH
    Nov 2005
    I have a Conroe E6700 (stepping 4 according to CPUz) and the Asus P5W DH board. Works great, but despite saying it is multiplier unlocked, I can't seem to set any options that work.
    The BIOS says the min ratio is 18 and the max ratio is 24. I have no idea what its talking about, but then right under it say Default ratio 10, which is correct. Changing it to anything 18-24 does nothing.
    Any thoughts?
    Dec 2005
    Post some BIOS page shots.
    Nov 2005
    Here you go, Merom on the left, Conroe on right.
ID:	48371   Click image for larger version.
    Jan 2005
    Northern VA
    did you rip of the merom socket?
    or does Asus provider an adapter
    Looks like you are doing it right, maybe the BIOS are buggy ATM
    Nov 2005
    That's just how the Merom came, I didn't rip it off.
    Jul 2004
    denmark
    how does this board handle high fsb?
    Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
    E6850@ 4500
    1000w psu/vapo Ls/2x74gb raptor raid.
    Nov 2005
    No idea yet, haven't gotten that far. I usually don't do the extreme OC'ing you guys do here.
    Apr 2005
    Belgium
    I guess the bios isn't 100% Conroe compatible because it's saying the CPU has 8MB cache... It thinks it is some kind of Pentium D or so...
    intel Core 2 Duo E6600 @ 8x400MHz
    Asus P5E X38 bios 1201
    Corsair TWIN2X2048-6400 x2 4GB in total
    eVGA Geforece 9800GTX+ || Creative Audigy 2 ZS
    Adaptec AAR1430SA 4port Raid card
    Seagate Barracuda 7200.10 160GB 8MB SATA2 x2 (RAID0, OS drive) on Adaptec
    Seagate Barracuda 7200.10 250GB 8MB SATA2 x2
    Seagate Barracuda 7200.11 500GB 32MB SATA2
    Seagate Barracuda 7200.11 1000GB 32MB SATA2
    Seagate Barracuda 7200.11 1500GB 32MB SATA2 x4
    Coolermaster CM 690 || Corsair CMPSU-520HX
    Windows 7 Ultimate RTM x64
    Philips 200WB7ES 20" WS 1680x1050
    MacBook Pro 15" June 2009
    iPhone 3GS 16GB
    Mar 2006
    Europe - Black Forest - Celtic Area
    disable hyperthreading ..there is no such thing in conroes
    Nov 2005
    I did, that didn't change anything.
    Mar 2006
    Quote Originally Posted by Vigile
    seems the actual bios has some kind of problems with your very early A1 stepping 4 Conroe
    B0 and stepping 5 seems to work fine , we will see some reviews in the next days.
    actually asus is well known for their so called "maturing bios " phenomenae , get the newest
    so I think there is hope on the horizon :-) ...
    Jun 2003
    Italy
    also CPU-Z says Pentium D on A1 revs
    3570K @ 4.5Ghz | Gigabyte GA-Z77-D3H | 7970 Ghz 1100/6000 | 256GB Samsung 830 SSD (Win 7) | 256GB Samsung 840 Pro SSD (OSX 10.8.3) | 16GB Vengeance 1600 | 24'' Dell U2412M | Corsair Carbide 300R
    Mar 2005
    Spain
    Try enabling intel speed step... Maybe you get luck...
    Asus P5K Premium//Intel E6600@3,6ghz//Corsair PC6400C3@500 4-4-4-12 2,2v//8800GTS G92//Audigy 2 ZS//SeaSonic M12 700W & LianLi V2000B
    Jun 2004
    get latest beta bios for P5W
