Results 1 to 25 of 72
Thread: Latest revision Conroe 6700 - step 5 - quick test
Threaded View
    silver wall jumper X
    Apr 2005
    Las Vegas
    Having a B0 stepping 6700 ES myself I have been spoiled with the power of an ES with downwards open multis.
    After pluggin it in - it turns out no open downards multis
    Booting her up into Windows went fine - but CPUz showed something new:
    (BTW - that scrreny was under stock everything - vcore 1.4V / stock Intel aircooler ...)
    Here a CPUz of the previous stepping 4:
    The above screenshot was done with a single stage and was the max of my Rev B0 stepping 4 CPU. 3.68ghz was all she can handle....
    Looks like the stepping 5 CPU might be a "release sample" of the actual retail CPU. Not sure - but just my guess. Putting the stepping 5 ( Rev. C1? ) under the test to see how it will compare to the old B0 I put it under the same Chilly1 single stage and got this out of it:
    4.25GHZ with 1.55V vcore. pretty impressive on the step 5 - at least to me. Had access to quiet a few Conores but this one topped 'em all easily. 4.2GHZ was also 3Dmark01 stable - what I had needed Ln2 before on my B0....
    Well a bit of LN2 on this stepping 5 got me only up to 4.45GHZ - but I don't think the CPU was holding me back - but rather the motherboard. 425FSB seemed to be the max on my current board ( might have been the reason for 4.25GHZ only ) - only freezing the Northbridge allowed me to get a tad bit higher to ~ 445.
    Obviously all the above runs were not tweaked and optimzed - so please make no fun of the times - this weekend hopefully I have more time ( and a better board!!!) to get things flying ... Breaking 70K on a single GFX will be my goal - here's a teaser with a STOCK 7900GTX : http://service.futuremark.com/compare?2k1=8994597
    Well before that it will have to do a 24hour Rosetta session - hint hint...http://www.xtremesystems.org/forums/...d.php?t=100731
    The Conroe future is looking better with every new revision! While there have been a few incredible air clockers been published here in the forums - I had managed to run quiet a few of the older steppings - and from my experience - the Step 5 is a nice step up to an even better Conroe
