Many years ago (damn cant remember exactly, but its was when the voodoo 2 graphics cards were out) i had a strange idea looking at my large Kenwood tall air cleaner to put the computer inside and it would cool the whole computer perfectly with its dual massive squirel cage fans at the top pumpin out insane CFMs. Worked perfectly as well. Even had a glass front window. I thought it was sweet but everyone thought i was crazy and it was ugly. The part that sucks is that i dont even have a pic of it anymoreThough i told everyone that it was a prototype, and that one day i'd build it from the ground up and it will be the perfect All Air cooling + perfect cooling for water cooling as well.
Well many years later and crappy stock cooling cases later i decided i cant take anymore and i need to build it!!
So i looked all over the internet for ideas on what to build it out of since i live in a condo and i dont have access to the right tools and even if i did i could'nt build it here.. Finally i seen a custom case built out of Lubic. Now in the past i thought no way could i build it out of this stuff with the cost involved but once you think about the fact that you can reuse it to fit your needs so its futrue proof i jumped on it!
Bought up 2 combo kits and 1 airplane kit of Lubic.. I thought hell, with all the parts i'll have i should have no problem building whatever i wanted no matter how big!
Well to make a very long story short.. In the end it took me 4 months to finish this case! I could not believe how challenging it would be to use lubic. Worked on my spare time.. Usually 2-3 days a week solid and maybe a few late nights. This case took all my free time. Everything about it was a pain! Its even hard to think back.. feeling all that fustraition over again hehe.
Oh and i could'nt tell you the exact end cost but just the case alone has to be over a $1000 easy! Took many trips to lowes and it was like a hundred everytime from tools to plexy down to screws.
The idea of the case is simple.. Suck in air from the bottom front and back and out the top. Along the way it cools the hard drives in the front goes up threw the 2 massive triple fan rads cooling the water cooling and up over the motherboard cooling that and the graphics cards and eventually out the top 16" fan. I wanted just one quiet Large fan cooling everything. Thats how i had it till near the end when i finally got the whole thing togeather and turned on the fan and noticed that the fan was'nt getting enough air and working too hard for it.. So i noticed if i kept the back top door open it would take some stress of the fan and it was still getting great pressure threw the rads.. So i made a screen on the back door. Then i finally broke down and though, well lets put 6 120/38mm 120CFM fans blowing up under the rads and i bet i'll get what i'm after. Once i did that i got major pressure and damn did it cool the system and the top fan could finally breath.
Insert one cheesy air flow diagram pic please! lol
Simple.. Air comes in from the bottom front and back threw the hard drives and up threw the 2 massive triple fan rads and up over the motherboard and out the top fan.
The case has plexy glass walls all around and the top is made out of thin panel wood. I could'nt just do plexy walls cause its been done so many times so i made my life hell and did the black painted metal mesh in a sandwich between 2 layers of plexy so its encased. That way it will be easy to clean and i dont have to try and get dust of all the cracks.. That would be suicide!
Heres another shot.. The doors and the front drive bay are from my previous Mountin Mods UFO case.. I could not believe that the walls from the UFO case fitted the door frame so perfectly, so i had to use them hehe. The front drive bay actually pulls out and screws in just like on the UFO case..Air tight seal all around ofcourse. Only the best if your gona build it right the first time![]()
![Send a message via AIM to [XC] MarioMaster](images/misc/im_aim.gif)
Get a STORM!
this looks like the mother of all towers ^^
