http://forums.anandtech.com/messagev...&enterthread=y
Found it over at AAT...
Direct Link:
Gersson's Modified Toxic Bios: http://rapidshare.de/files/22676263/...mings.rom.html
ATI Winflash 1.10: http://www.techpowerup.com/downloads/281/mirrors.php
Rabit 2.0: http://www.techpowerup.com/downloads/283/mirrors.php
Anybody want to give it a try?his is a modified Sapphire toxic bios. I changed all the relaxed timings to regular XTX speeds which makes it actually faster than the toxic card. The fan is made to run faster under load. My purpose was to not have to use ATI Tool with crossfire (PITA) and still have an OCed slave card. This is if all you want is a modest OC or if your card can't take all that much.
Please be sure you can run 675/1600 before downloading! Also this is only recommended for Samsung 1.1 memory. Make a backup using ATI WinFlash before anything else.
Works with XT or XTX that have 1.1 samsung memory. 1.2 only if you have cards to throw away and want to test
I was thinking, if my card hits 690/800 with ATiTool (which doesn't relax timings), then in theory I should be able to set that as my default clocks, no?
Hmm.... risky business certainly.
