Results 1 to 7 of 7
Thread: Woodcrest, Opteron and UltraSparc: Server CPU Shoot-out @ Anand's
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    source here
    Conclusion
    Two months of testing and tweaking allowed us to gather a lot of information. Our Sybase and DB2 tests still need a bit of tweaking before we can publish result on them, but with tests on SSL, JSP, LAMP, MySQL and PostGreSQL, what can we conclude so far?
    Sun's T2000 server and it's 32 thread T1 CPU turned out very variable results. It is not the best choice for open source databases. PostGreSQL and MySQL scale better on Solaris than they do on Linux, but both RDBMS have trouble scaling over multiple cores. It is likely that the DB2 and Sybase results will be much better on the T2000. The SAMP web performance of the T2000 was good when we cached the PHP pages and we had few accesses to the MySQL database. When PHP pages had to regenerated with every access and the query cache of MySQL was used, performance was pretty bad compared to the x86 competition. The best purpose for the T2000 is a JSP server with SSL authentication.
    The Intel Xeon 5160, a.k.a. Woodcrest, will simply be the most powerful server CPU this year (though it's not yet available for purchase of course). As our extrapolated calculations show, even a 2.6 GHz Woodcrest will outperform the current Opteron 285 with a 5 to 55% margin, nothing short of impressive. The new Xeon is however not invincible: the Opteron can still give some serious resistance when running some instruction mixes with lots of rotates, add-carry or load effective address instructions. RSA, AES and other benchmarks clearly show this. Intel will still have to convince some software vendors to port to SSE if it wants Woodcrest to be the completely superior CPU. The advantage in MySQL is also rather small, a result of the relatively high latency of the FB-DIMMs. But we are nitpicking: Intel's newest Xeon has taken back the performance/Watt crown. In one word: Woodcrest rocks!
    And what about AMD? The Opteron remains a powerful architecture with a flexible platform. It is quickly becoming the most popular platform for 4 sockets and the upcoming Tulsa CPU is most likely not going to change that. However part of AMD's success has been Intel's Prescott/Nocona failure. In the K6 and Athlon (K7) years, AMD managed to improve the architecture every two years. In 1999 we had the original Athlon, in 2000 we got Thunderbird (integrated L2 cache) and in 2002 we got the Athlon XP. For the few past years, the Opteron architecture has made the move to dual-core and received a better memory controller, but the necessary IPC improvements and cache enlargements have not materialized. "Only the Paranoid survive", remember?
    The Intel P-M architecture went from 1.7 GHz Single Core (Banias) in 2003 to 3 GHz (Conroe, Woodcrest) in 2006, while it quadrupled the L2 cache and significantly improved the IPC. At the same time, AMD's K8 series went from 1.8 GHz to 2.8 GHz dual-core, with the same amount of cache, and almost equal IPC. The result is that AMD will not be able to regain the performance crown in the dual and quad-core market until the K8L arrives. The future looks bright in the quad socket market however.
    In summary:
    Intel Xeon 5160 (Woodcrest)
    Advantages:
    * Best server performance across all applications
    * Best Performance/Watt in the high end
    * Absolutely stunning web server performance
    * FB-DIMM enables high RAM capacity and bandwidth (quad channel)
    Disadvantages:
    * Needs SSE optimized code for some special case code (RSA, AES)
    * FB-DIMM adds extra latency, cost (small) and power
    UltraSparc T1 / Sun T2000
    Advantages:
    * Superb SSL performance
    * Excellent Performance/Watt with SSL and Java code
    * Solaris, a robust and well scaling OS
    * Quad channel enables high RAM capacity
    Disadvantages:
    * Heavy optimizing is necessary; out of box software performance is low
    * Low single threaded performance; also results in low performance in server software that scales badly
    * Price/Performance compared to Woodcrest
    AMD Opteron
    Advantages:
    * Well rounded CPU: performs well even with non optimized code; still excellent MySQL server results
    * Excellent Quad socket platform
    * Does not need FB-DIMM for high capacity thanks to NUMA
    Disadvantages:
    * Web server performance compared to Woodcrest
    * Power at higher clockspeeds (110 W vs. 80 W)
    * DDR2 offers lower latency, less power and less cost (for now)
    Apr 2005
    UK
    intresting but how is "* DDR2 offers lower latency, less power and less cost (for now)" a disadvantage?
    Ed.
    Conroe E6420 @ 3.3ghz at the moment.
    DFI Dark P965
    2gb Geil DDR800 4-4-4-12
    8800GTS 512mb
    1.7TB Storage
    CM Stacker
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    Something just seems a little bit off
    edit now I see it:
    Opteron Server 1: Dual Opteron 275 2.2 GHz 2x1MB L2 cache (4 cores total)
    64 bit Gentoo Kernel 2.6.15-gentoo-r7
    Solaris x86 10
    MSI K8N Master2-FAR
    4 GB: 4x1GB MB Crucial DDR-400 (3-3-3-6)
    NIC: Broadcom BCM5721 (PCI-E)
    2x Western Digital Raptor 36 GB SATA
    Opteron Server 2: MSI K2-102A2M
    ServerWorksHT2000 Chipset
    Opteron Server 3: HP DL385
    Solaris x86 10
    AMD 81xx chipset
    2x Seagate Cheetah 36 GB - 15000 rpm - SCSI 320 MB/s
    Client Configuration: Dual Opteron 850
    MSI K8T Master1-FAR
    4x512 MB Infineon Registered DDR-333, ECC
    NIC: Broadcom 5705
    why the hell are they talking about socket F when they are using 940 for testing?
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    May 2005
    Quote Originally Posted by nn_step
    edit now I see it:
    yes and using budget systems, no normal server chipsets
    some are dual core benches some quad... depending on the results probably...
    rather off benches, lets see what benches they bring on wintel....
    nice end quote from anand... woodcrest is the server proc for 2006
    did they see the socket F already? the forgot a line in there bench. "anand thanks intel for the new sponsering contract and donations"
    Quote Originally Posted by Movieman View Post
    Fanboyitis..
    Comes in two variations and both deadly.
    There's the green strain and the blue strain on CPU.. There's the red strain and the green strain on GPU..
    Live Long And Overclock
    Sep 2004
    Thread title edited for clarity.
    Perkam
    Feb 2004
    Montreal
    Quote Originally Posted by eddieate
    Ed.
    The opteron doesnt support ddr2, so its a disadvantage that it cannot be enhanced by those advantages
    In other news, the denial is strong in here!
    It basicaly wins every test but one. : "but the case was yellow! everyone knows amd's cant perform in a yellow case! Damn you anandtech for selling out!"
    Sep 2004
    Quote Originally Posted by Ailleur
    Unless of course AMD joined up in the Green Lantern Corps, lol, then that wouldn't be the case
    Perkam
