GSKILL DDR1-500 2GBHZ , 1:1 FSB 270*10 2.7G with XFX XXX 570/775
on DFi Ultra-D
single card
on DFi Ultra-D
single card
Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
Check out our items on NewEgg
Wow...nuts.
Grats on the awesome testing !!
Perkam
Good clocks for 2 gigs of ram but everyone benches with no more than a gig of ram as they can get much higher than 270MHz and 2-2-2-5 timings instead of 3-4-4-8!
3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
9700pro at 325/310 runs all games buttery smooth!![]()
9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
3dmark scores with Ti4200 and Ti4800se
Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
3dmark scores with older gpus
Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
Not to offend the xtreme, but there are also those whom use their computer for more than just benching. With todays graphics power, its pretty much a bare minimum to have 2gb of ram to play todays high end games at highend quality. So this is bench is for the mass enthusiast market, not macci, or fugger, or kingpin.
PLus, Nice numbers.
Current 24/7 settings
Delidded L628B e6400@ 3.6ghz 1.38v
3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
x1900xt 690/780
SLI is not possible yetOriginally Posted by ugp
with future drivers maybe.
I am not a fan of high latency ram even if its a large quantity. I prefer quality and speed over quantity but thats me![]()
Well, it doesn't look like playing FEAR with everything @ MAX and 4xAA/16xAF is much of your concern, so i can understand view. But for me, when I tried it with 1gb when one of my boards wouldn't take both sticks, i had to turn alot of things down just so it would stop caching to the HD.
x1900xt 690/780
need more on the cpu and you'll break 15 easily
thats some nice ram you got there though
DFI LANPARTY UT nF4 Ultra-D [6/23 BIOS]
AMD Opteron 148 [CAB2E 0546GPMW] [257x11.0 @ v1.500] & Zalman CNPS7000B-CU
OCZ EL Platinum Rev. 2 2x512[207FSB @ 2-3-3-6 @ v2.80 1T]
DFI Ultra-D [6/23 BIOS]
eVGA 7800GT [470 / 1100]
Western Digital Caviar SE 250GB Serial ATA
Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
