Full pics
http://i4memory.com/phasechange/kayl/arrived/1/html/
http://i4memory.com/phasechange/kayl/arrived/turnedon/
http://i4memory.com/phasechange/kayl.../NF4_UT_SLIDR/
http://i4memory.com/phasechange/kayl...F4_UT_SLIDR_2/
Yeah baby sub 21min! But man look at -20C idle cpu temps at 3515Mhz at 1.6v with load around -3C to -6C!
managed suicide run with cpuz @3645mhz at 1.728v but after got the run bsod LOL
Okay in an effort to find my ram's max limits for Super Pi 32M decided to drop the cpu multiplier and clock up the ram.
12x260mhz 2-2-2-0 7-12-0212 at 3.48v
12x266mhz 2-2-2-0 7-12-0212 at 3.65v
13x266mhz 2-2-2-0 7-12-0212 at 3.65v
Seems 266mhz 2-2-2-0 at 3.65v is okay for a comfortable overclock on Kayl Black Frozen SS with FX-57
I'm pretty sure my FX-57 is limited by cooling right now to clock any higher >3.6Ghz probably needs colder load temps.
Difference between idle and load at >1.65v vcore is as much as a +28C delta.
After FX-57, will try Opteron 170 CCBWE 0546XPMW and FX-60 CAB2E 0536RPMW
Thank you Kayl![]()
