Moving up to the B0 stepping and put the Core 2 Dou E6300 1.8Ghz 2MB L2 Cache under the vapo for some FSB testing and to see if the 2MB makes any difference in overclocking.
If my Presler could hit this kind of bus speed it would give the AM2 a brutal beating in bandwidth.
This is the low end chip matching my 2.13Ghz A0 chip in speed and beating it on bus speed. This chip also allows full voltage from the mobo.
http://valid.x86-secret.com/show_oc?id=97732
Both cores enabled, memory timing at 4-4-4-x as I am pushing the FSB.
