Conroe E6700 voltage 1.78v to 4ghz already @tower120!!!
Vcore1.78v
16k
Vcore1.78v
16k
well,heres the fabled 4 on air... but JESUS that VCore is NUTS!!! whats temps like???? How heathy can that be for the longevity for that poor thing?
"Roses are FF0000, Violets are 0000FF, All my base are belong to you."
Asus P6X58D-E
I7 930 @ 3.9
Asus 660ti DirectCU OC
Antec Twelve-Hundred
Grats![]()
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
16K stable. Woohoo!![]()
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
1.78v on 90nm is insane, but 65Nice work though
Rig #1 | Opteron 165 (2898 @ 1.35v) | DFI nF4 Ultra-D | GSkill ZX 2x1GB | HIS X1900XT 512MB | Seasonic S12 550w in Antec P160
http://www.last.fm/user/repoman0/
thats insane...what are your temps like?
omg !!!! 4GHz on X6800 is no dream yayaya!!!!! hooray !!!!![]()
is that done on your new ATI XPRess3200 motherboard??
Wow .. 4Ghz on air !!! Man Conroe is still driving me nuts.
3.9g@32MPI pass![]()
temps idle/load ?
Wow, 1.78V in 65nm is awesome! Great job!
Tower120 is one of the best heatsinks, the best that i've used.
wow its totally stable, it past the 32M pi test
prime95 can stable@3.9g single core
Ha, I wondered when someone would try to melt one of these.![]()
Seriously, I'd like to see max volts before China Synrome.![]()
This is just preposterous power on air. To think a month or so ago nobody could even come close to these pi times on LN2.
Obviously 1.78 is ludicrous on air, but maybe not on subzero cooling. Only time will tell.![]()
Keep pushing it Coolaler! "I'm willing to fight to the last drop of your blood." - Moe Howard.
<----- REST IN PEACE, KIT. 1993-2007.
Christ, that poor chip.
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
Crazy voltage, i had no idea Conroe was so resilient to volts. Good work Coolaler, once again.
Intel Rig
2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
Custom Water of course
3.9G@Cinebench 2003
0.08v ?
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
cpu z doesnt tell the real voltage
yaya more results, ill stay here for couple more minutes
keep 'em comin coolaler
The Cinebench is way off, at that speed you should be under 20 seconds easy. @ 3.4Ghz I pulled 24s
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
two sp2004 ?Originally Posted by coolaler
God damn, I don't even have the balls to take a 90nm P4 to 1.78 volts, and here you go and do it on a 65nm chip.
I think Fugger ran 1.9V into his Prescott in the pre-90NM days.
Yep, and the multiprocessor speedup is only 1.52, normally it's around 1.82. And the Open-GL speedup is 0.52. There must be a bug somewhere, i've also seen the same dendencies on other Conroe Cinebechs, but not all.Originally Posted by FUGGER
