Results 1 to 21 of 21
Thread: the best thermal paste? Liquid Metal Coollaboratory Liquid Pro vs. AS5 [pics 3MB]
    X.I.P
    Mar 2005
    before apply CPL to my intel 651... i love to use this thin blade to apply any kind of thermal paste
    it is not easy to apply CLP... sometime i did the paste too thin and cooler base can not 100% touch the paste, i added a drop in the middle to ensure CPU and cooler base perfect touch
    45 degree photo
    after applied and removed the cooler, it looks like this
    CPU top looks like this...
    i used soft napkin to clean it... however it is very hard to remve
    this is the best i can do....
    CPU only can done like that
    GOOGONE, always use this to remove any kind of paste
    after googone it...
    the formal thermal paste winner, AS5
    i used another Tower 120 cooler, never apply CLP b4
    add some more drops in case too thin that cooler base can not touch it
    after using AS5.... easy to clean
    easy to remove from CPU too. however, i think there was some CLP not complete remove and caused reaction.... became like black hahah
    soft napkin done a good job again (good for other cleaning? )
    after googoned it!
    X.I.P
    Mar 2005
    room temp 24.3C
    using CLP
    right afte Windows loading , CPU idle temp
    SP2004 5mins
    after turn off SP2004 about 30sec
    room temp 24.2C
    using AS5
    right after Windows loading , CPU idle temp
    SP2004 5min
    after turn off SP2004 about 30 sec
    Nov 2004
    Wow, great pictures and very impressive results. Thanks a lot for all your work!
    AMD Athlon 64 X2 3600+ @ 3.0GHz||Biostar TF560 A2+||4x1GB Team Xtreem D9s||Visiontek HD3870||WD 250GB||Seasonic SS-600HT
    AMD Athlon 64 X2 3800+ @ 2.6GHz||DFI NF4 Ultra-D||OCZ VX 4000 2-2-2-5||ATI X1900XT||Seagate 320GB||Seasonic S12 600
    Nov 2005
    I understand CLP should not be used on Alu but isn't the IHS Alu? Correct me please if i'm wrong.
    May 2006
    Belgium
    http://www.xtremesystems.org/forums/...ad.php?t=72814
    Read this thread, I think its wise to stay well clear of this CPL crap cuz it will indeed harm your IHS in the longrun(not visibly but damages will be there).
    Banned
    Feb 2006
    Ontario, Canada
    when you apply thermal paste, its best to put put one little tiny drop in the middle, and let the pressure of the heatsink do the rest. This is been proven too btw
    Nov 2002
    Sweden
    Unless the testing of each compound was carried out over a week the test isn't interesting from a cooling perspective since we all know that AS5 takes days, up to a week, to "bond" and reach the peak effectiveness. Took ~4-5 days and my CPU suddenly went 4-5 degrees cooler the next morning.
    ps. I wouldn't let that liquid corrosion aluminum killing chemicals near my equipment..
    Xtreme Cruncher
    Mar 2005
    Lancaster, PA
    Quote Originally Posted by qwerty69
    An IHS is nickel-plated copper, so shouldn't be too much of a problem.
    A wolf in wolves clothing.
    Feb 2006
    Way too much arctic silver 5 on there.
    E6300
    Gigabyte DS3
    2 x 1 GB Corsair PC6400
    eVGA 7900gt
    Seasonic S12 500W
    Praetorian 730 - Dell 2005 FPW
    X.I.P
    Mar 2005
    Quote Originally Posted by Scyphe
    that is ok! i knew ppl will asking about this b4 i posted
    mine 7900GTX vmoded 1.55v core is using AS5 for over 1.5 mos
    it must be over 100hr burn in as AS5 official website require. moreover, i turn on and off and that is another requirement for AS5 burn in... so now let me show the magic of CLP... (to me it is woow! like the 1st time i use AS5)
    AS5; room temp is 23.4C
    7900GTX idle
    7900GTX full load and temp is almost the same
    after full load about 60 sec, 1 block is 10sec
    CLP; room temp is 23.0C
    7900GTX idle
    after full load about 64 sec, 1 block is 10sec
    Aug 2005
    OMG :o
    I really want to try the CLP, I'm only scared that it would eat the core of my winchester. (I have the IHS off).
    Does anyone know if the bare core can stand this liquid metal stuff?
    Jochenp
    Patriotism is the conviction that this country is superior
    to all other countries because you were born in it.
    -- George B. Shaw
    X.I.P
    Mar 2005
    Quote Originally Posted by Jochenp
    OMG :o
    Jochenp
    you can wait for a mo to see my 7900GTX still working or not
    Mar 2006
    United States of America
    You use way too much thermalpaste, i used to spread my AS5 on the whole IHS when i first got this 3000+ but last time i installed the cooler i only used a small drop and that small drop even improved my temps compared with the whole IHS covered in thermalpaste!
    - Schmetterling
    Oct 2005
    Denmark
    maybe but why should he lie.. where can we got that metal thing CLP
    Asus Rampage II Gene - i7 920 D0 Lapped - Lapped Noctua NH12U-F
    Sapphire HD4870 X2 - 6GB Corsair Dominator GT@T1 - Windows 7 x64
    2 x WD Velociraptor 150GB Raid 0 - 500GB Samsung T166
    Antec ThreeHundred - Samsung A656 40"- TX650W
    Xtreme Cruncher
    Jul 2005
    London - UK
    theres often some on ebay UK
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    Jan 2006
    st-jerome.qc.ca
    i think www.frozencpu.com has some in stock
    Representing The REAL 0nes
    Excuse my english im still learning
    1x A8N32 SLI Deluxe
    1x 3500+ venice core
    1x 2Gig OCZ DDR500 Platinum EB
    2x BFG 7800GT OC in SLI
    1x OCZ 520W Powerstream
    1x X-Fi Xtreme Music
    1x WD 250gb sata2 16mb cache
    1x G15 Gaming keyboard
    and plenty of other stuff...
    Jan 2005
    NJ
    psh AS5 ftw
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
  18. #18
    Skulltrail Junkie
    Jan 2005
    Milwaukee, WI
    ill stick to shin-etsu G-751, has given me better results than AS5, and i prefer not to put some crazily conductive (and proven destructive... atleast on aluminum) TIM on my components
    • Lian Li PC-75B • Corsair Professional Series 850w •
    • 2x Intel Xeon E5420 @ 3.0GHz (400x7.5) • Intel D5400XS Skulltrail •
    • 8GB (4x2GB) A-Data DDR2-800 FB-DIMM ECC (1:1 @ 400MHz) •
    • MSI Radeon HD4870 1GB • Creative X-Fi Titanium HD •
    • 2x WD VelociRaptor 150GB (RAID 0) + 2x WD Caviar Black 500GB •
    • 2x EK Supreme HF CPU • EK S-MAX NB • EK VGA Supreme GPU • Blastflow Tidal SB •
    • Thermochill PA120.3 • Swiftech MCRes-Micro • Laing D5 w/ Bitspower Top •
    Heatware • http://www.heatware.com/eval.php?id=34593
  19. #19
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Whoever is worried about IHS being aluminum, don't be. IHS is anodized copper.
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
  20. #20
    Skulltrail Junkie
    Jan 2005
    Milwaukee, WI
    Quote Originally Posted by IvanAndreevich
    you can only anodize two metals: aluminum, and titanium (different process)
    copper can be plated, but not anodized - the IHS is made of nickel plated copper
  21. #21
    Xtreme Recruit
    Mar 2006
    u can anodize copper. its just a b***h of a process.but it can be done.asked my uni profs today and they reckon its gd to go but cant see y u wud want to.
    athlon 64 4000,2x1gb XMS 4000@250mhz-2.5,3,3,7,leadtek 7800gtx extreme @550/1.39 stock volts,hiper type R 520W,400gb HD's.
