Results 1 to 10 of 10
Thread: How do you apply Arctic Silver on Nake Core
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    How do you apply Arctic Silver on nake core CPu to give you the best temperature?
    I am Xtreme
    Oct 2004
    U.S.A.
    the same way you would with an athlon xp or GPU.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    I am Xtreme
    Jul 2005
    apply it like a layer of icing on cake...be done with it
    [SIGPIC][/SIGPIC]
    Xtreme Guru
    Jan 2006
    Milan, Italy
    doesent work as well as the drop of TIm on the center, which is the method ArticSilver have in their instructions.
    Quote Originally Posted by Bloody_Sorcerer
    flowrate is for losers!
    Quote Originally Posted by MaxxxRacer
    Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
    Banned
    Sep 2005
    East Coast USA
    take some saran wrap and stretch it across your index finger so it is nice and tight. then place a small amount of as5 on your covered finger. then, apply it to the core. this allows for an unmessy way to apply it. works great for me every time.
    Mar 2006
    Sunny Lizardland
    Quote Originally Posted by cronic
    ...then trim to paper-thinness with a razor blade.
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    Ookay THanks For all your inputs.
    Steak for Breakfast
    Dec 2005
    N.Vancouver, BC, Canada
    I just put a small dab in the center, then let the HS sit. Yes you waste very little amount of paste but you get less air bubbles, same way you would apply a microscope slide. Or just use ceramique
    Xtreme Cruncher
    Dec 2005
    St. Paul, MN ,USA
    put a drop in the middle by spreading it you risk trapping air in the middle and if you're worried about shorting then put non-conductive paint [non-lead-base] around the core
    beat me to the air thing by 1 second, damn you slow typing and dial-up
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    use ceramique instead. Just run a very thin line of ceramiue down the middle of the core. Remember the core is not square like the IHS. If you only use a dot in the middle, it will have lots of spill over.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
