Results 1 to 8 of 8
Thread: AMD 3700+ woes :( here's the post sam
    Mar 2006
    Bakersfield, CA
    I bought my 3700+ a few months ago and couldn't figure out why everyone
    could do higher overclocks than I. I found out yesterday. See images.
    It's a stupid Toledo dual core (4800) i'd guess with one core disabled. This would explain my shotty temps and overclocks.
    LP UT CFX3200-DR 05/23 Bios
    AMD Opteron 165 CCBBE 0617 FPMW @ 3.0Ghz auto Volts + 114% 334x9 166 divider
    Thermaltake Big Typhoon w/Antec 120mm 2000rpm
    2x1Gig G.Skill PC4000 HZ Samsung UCCC 3-4-4-8-2T 250 Mhz
    ATi X1900 Crossfire Edition
    ATi X1900XT
    3x74Gig Raptors Sil3114 RAID 0
    1x400Gig Hitachi SATA
    NEC AD-7170A 18x DVD Writer
    X-Fi Platinum
    Tagan TurboJet 1100watt
    Windows XP Pro SP2
    Jan 2006
    st-jerome.qc.ca
    unlock it?
    or try to i should say
    Representing The REAL 0nes
    Excuse my english im still learning
    1x A8N32 SLI Deluxe
    1x 3500+ venice core
    1x 2Gig OCZ DDR500 Platinum EB
    2x BFG 7800GT OC in SLI
    1x OCZ 520W Powerstream
    1x X-Fi Xtreme Music
    1x WD 250gb sata2 16mb cache
    1x G15 Gaming keyboard
    and plenty of other stuff...
    Banned
    May 2005
    Belgium, Dendermonde
    1.35V, put that to 1.45V and see what happens
    "I eat motherboards"
    Dec 2004
    Topeka, KS
    Stock volts should be 1.3v... Well atleast mine is. Once you break the barrier of 1.6v these chips become an unmanagable beast, moreso with MPS Multi and the works. Before's chip (Yes the guy with the 4200mhz FX-57)and my chip are excellent chips that will do more than 3.2ghz on phasechange and the works. The only diffrence, he needs to run MPS Multi to keep from bugging on SS @ -50*C evap.
    杰森
    I can picture in my mind a world without hate, a world without violence.
    And I can picture us attacking that world, because they'd never expect it.
    Mar 2006
    Bakersfield, CA
    Quote Originally Posted by GoThr3k
    I'm there right now 250x11 1.45volts 1:1 G.Skill DDR 500 3-4-3-6 1T LDT @ 4
    I just wanna be able to do 2.9 like everyone else
    ATi X1900XT
    X-Fi Platinum
    Windows XP Pro SP2
    Dec 2004
    Topeka, KS
    ^^^ These cpu's are special in most regards, they can take a fair amount of cold, and have a very strong memory controller to boot. They take more TLC than the regular "San Diego" chips.
    杰森
    Xtreme Mentor
    May 2005
    San Diego, California
    CCBWE 3700+
    lol, you got a bad dual core stepping turned into a single core. It'll go cold but won't overclock particularly well. Just bad luck. As Stephen has been saying, it looksl ike AMD is trying to transition single cores into dual cores with 1 core disabled.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
    Dec 2004
    Topeka, KS
    This is been know for months... I have THE E6 Sandy that he showed. Before has been going crazy benching Pi 1m, So far 24.6xx @ 3300mhz. The downside to this chips, they need more volts than a regular San Diego.
    杰森
