Apologies for the delay in publishing the guide
Off we go;
Just in case if you can´t read the instructions from the picture:
Solder a 10k variable resistor between the spot (pointed by the arrow) and ground. The alternative soldering spot is marked with blue X.
Lower resistance means higher DDR2 VDD.
I highly recommend that you use the alternative soldering spot.
Soldering directly to the IC leg is easier and safer, since the primary soldering spot is quite small.
Damn, I love this board
Vcore, Vdroop & MCH VDD mods will follow soon.
I have already done FSB Termination mod, but it has no effect to overclockability.
512mhz 4-2-2-1............ monster D9
