Page 8 of 97 FirstFirst ... 5678910111858 ... LastLast
Results 176 to 200 of 2422
Thread: XS Case Gallery
  1. #176
    Xtreme Recruit
    Aug 2004
    Greece
    An excellent project!!Very original!Well Done!
    This is not a sig.
    This is a duck.
    Quack.
  2. #177
    Xtreme Lusitanian
    Mar 2004
    Luxembourg
    @WeldZilla
    I always wanted to do that but I never had the courage neither the skills to do so, Congrats very cool your case and really clean, masterpiece you got there
    Mother Tongue speaks to me in the strangest way I ever seen, I know she sees in me the proudest child ... virando costas ao mundo orgulhosamente sos, gloria antiga volta a nos" - MOONSPELL
    Who are you to criticize, to judge and burn the tribes, the world will be extinct and your flesh will rot with mine - SEPULTURA
    XS WCG
  3. #178
    Dec 2004
    WOW that's a well done case Weldzilla. Really unique shape.
  4. #179
    Jul 2004
    Maryland
    Quote Originally Posted by conrad.maranan
    WeldZilla - You did one hell of a remarkable job, my friend. That has to be one of the most original cases I have seen in a long time.
    How long did that take?
    Processor: Athlon XP-M 2600 IQYHA 0401
    Motherboard: DFI NF2 Ultra Infinity vcore, vdroop, OCP, vdimm, vdd mods
    Cooling: Swiftech MCW6002a-Swiftech MCP350-Weapon Modded 2-302 headercore+Shroud
    Memory: 2x512 Kingston HyperX KHX3200 BH-5 2-2-2-11
    Power Supply: OCZ Powerstream 520
    Sound Card: EMU 1212m
    Headphone Amp: DIY Pimeta/Mint/CMoy
    Headphones: Senn HD580/Etymotic ER6i/Sony MDR-D66 Eggos/Koss ksc75/Shure E2c
    Video Card: Radeon 9600 Pro @ 489 Core/680 Mem fdd power mod, vmem, vgpu
  5. #180
    XS - Extra Strong
    Aug 2003
    Toronto, Canada
    Quote Originally Posted by cetoole
    Why are you calling him stupid excatly?
    -Phenom2 x6 1055 @stock
    -8gb ddr3
    -Gigabyte UD3
    -Geforce 7900Gt 755/1863 1.562v vgpu
    -OCZ Powersupply 600w
  6. #181
    Xtreme Mentor
    Oct 2004
    No offense taken. It's just an emoticon.
    Happy Holidays!
  7. #182
    Dec 2004
    Time
    Well again thanks you know there was about 32 hours of actual work in the project . But, there was about 45 to 50 hours just spent thinking about the project, planning the little details. you see when I turned the front of the case sideways I also moved it forward to 2 inches to insure plenty of room for roms. That was easy at the top of the case since I just built a whole new one, But, at the bottom of the case I decided to fill in the 2in. x 8 1/2 in. void with metal i had from the pieces I already had cut out. (The window). Then I had to have some pieces to build the lip back up where the cover would go back on. Remember that right side cover is now the rear of the case. Well I had done a job customizing some metal legged bar stoolls for a guy and as luck would have it. the square pieces from it were the exact same size as the bent lip of the case. Here is a pic. You will see the pieces I used and also where I had to fill the back corner in. When I was done I used a flap disc in a 4 1/2 grinder where it was easy to get at.In the hard to reach areas I used a small flap disc on a die grinder ( air powered dremel) I came out great!! didn't have to use bondo to get it perfectly smooth. Her are a couple pics.
    Here it is all back together. Beofre it was fully danded out.
    Another thing that condumed time was the mount for the water tank. Easy,just time consuming. I had some pipe but it was all too big so I cut out an inch section of it, squeezed it back to gether in the vice. then I welded it. smoothed the weld out and used the vice and a small ball pin hammer to make the rings perfectly round again.
    There were many small things to do to add up to the finished product. I llike little details. the legs took time to make. again I had some old oil stove plumbing around that was just the right size. So I cut legs out of it and tapped them with 1/2 in stndard course threads. I cut the heads off some 1/2 in bolts and wellded them onto my leg brackets .Then I was able to just screw the legs on. it also made them adjustable. As I said the work was easy. the thinking was sometimes pretty intense.
    I like putting my insignia in my cases
    Coming in the Spring 2005.......
    WeldZilla 3 "Domination By Design"
    WZ
  8. #183
    Dec 2003
    God of all that is SFF.
    SFFclub.com
  9. #184
    Nov 2002
    USA
    I just finished this up between Xmas and New Years, Santa was good to me last year.
ID:	22506   Click image for larger version.
    EVGA X58 - Intel i7 920 (3.8 gig) - EVGA GTX295 - 6GB OCZ Platinum - LG 22" Monitor
    1 x 80GB Intel SSD - 2 X 300GB Velociraptors - Corsair 1000 wt PSU - Windows 7 + Linux
  10. #185
    Jan 2005
    WOW... Some great Masterpieces here('S)my last Case Build/Mod...
  11. #186
    Xtreme Mentor
    Oct 2004
    Cleveland OH USA Bored?: You Know It
    thats pretty nice, you built that?
  12. #187
    Jan 2005
    Thanks...pretty much for under $50 Plexi can be precut and then use of Plexiglass glue. The base is 21" all around @ the bottom and the Case stands 21" tall...I was tallied with a Bud who was into painting and modding Cases as well..
    http://puters.ledm.us/images/Radeon-DFI.JPG
  13. #188
    Dec 2004
    I'm sorry man but that must be one of the ugliest modcases i've ever seen.
  14. #189
    Xtreme Lusitanian
    Mar 2004
    Luxembourg
    Quote Originally Posted by MrQ3W
    I think you was a bit rude, 'cos tastes aren't the same for each people, I don't like it either but perhaps you don't like metal bands and I really hate RAP songs, and you are not seeing me advertising this everywhere, as I said tastes is for each people, if you don't like it don't see it, hell you can even unsubscribe from this thread
    XS WCG
  15. #190
    Dec 2004
    Turrkey
    this is mmy case
  16. #191
    Dec 2004
    Turrkey
    and this
  17. #192
    Dec 2004
    Czech Rep.
    What case is that?
    "Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
  18. #193
    Jan 2005
    Carlisle, PA
    Quote Originally Posted by dimasdw
    this my PC case (not yet finish,i have a plan to use acrylic)
    not enough fans.
  19. #194
  20. #195
    Jan 2005
    NICE CASE piercedandtatto ..
    Mainboard:Gigabyte GA-K8NSNXP-939 *limited edition with dual bios*
    CPU: Athlon 64 3000+ wini @ stock
    Ram: 2x256 Take MS Pc3200 Dualchannel
    GPU: Radeon 9800SE softmodded to 9800Pro[407 / 330 ]
    Harddrive: 80gb Samsung Spinpoint
    PSU: 350W
    Case: Xtreme modded Chenbro Gaming Bomb
    A PC can“t be chilled enough :banana4: !!!
  21. #196
    Jan 2005
    Maybe I could see some of your work?...meanwhile here's some others that might get your approval and tickle your Fancy
    http://puters.ledm.us/images/Harleyset-up.jpg
    http://puters.ledm.us/images/GreenLights.jpg
    Then there's this one that my 7 yr old daughter helped build while playing with her Barbie Dolls
    http://puters.ledm.us/images/Pinkie.jpg
  22. #197
    Xtreme Cruncher
    Feb 2005
    Finland
    Well, my first message here.
    Really nothing xtreme with this case, it's just for 24/7 use quiet "workhorse". Vertical panels are sealed so the air flows from the bottom to the top of the case, through rad.
  23. #198
    Jan 2005
    Denmark
    just a Sunbeam acrylic case with some blueled fans and some green UV cable sleeving ......next project is a aluminium case made from a suitcase...with a tft monitor in the top............
    E3110//4,1Ghz @ Asus Rampage x48 cooled by NorthQ Siberian Tiger
    Mushkin 2*2GB pc8000| Gf 8800GTS-512
    OCZ 600W | samsung 226BW | logitech G15
    Speedlink medusa 5.1 | MS Habu@nova killer
  24. #199
    Feb 2005
    A Corner of Hell
    jeeeez, nice rigs guys. I wish I had half that type of creativity!
  25. #200
    Dec 2004
