Page 7 of 7 FirstFirst ... 4567
Results 151 to 174 of 174
Thread: Those of you considering 2GB kits-Might wanna check this out!
  1. #151
    Jul 2005
    Any idea if the new HP3200's are hitting the same 250+ Cas 2.5 settings as the old ones? Thanks!
  2. #152
    Admin
    Feb 2005
    Ann Arbor, MI
    Alright...first experience with Mushkin RMA and it was great. Of course, I had help from above (read: Duonger), but I expect it would still be great anyway.
    Now to figure out whether or not I want to send in only the completely dead stick or both...I was given the option.
    Anyway...
    [stewie voice]This calls for a sexy party![/sv]
  3. #153
    Aug 2005
    Quote Originally Posted by Doom5
    I will let you know by this weekend.
    Antec P180
    AN8 Ultra bios 17
    3700 San Diego 11x240 1.5v
    2x1gb Mushkin Blue 2-3-2-6 1t (ddr400)
    WD 74g Raptor
    OCZ Powerstream 520
    xfx 6800GT pci-e
    Blue Chieftec w/clear window
    AMD xp2200 @ 200x10
    EpoX 8RDA+ w/volt mod
    2x256 Corsair XMS pc3200 LL PLT 2-2-2-5 1t
    80 gig WD
    40 gig IBM
    stock 400w psu
    MSI 9800 Pro (r360)
  4. #154
    Mushkin U.S.A.
    Mar 2005
    send in both so brian can test them as a dual kit and get the best performing ones back to you
    Duonger
    Quote Originally Posted by Vapor
    Anyway...
    Mushkin Employee and DAMN Proud Of IT!
    www.mushkin.com<---new and improved
    email me <--- For any assistance or help
    Keep your eyes open... more to come.....muhahahaa
  5. #155
    Admin
    Feb 2005
    Ann Arbor, MI
    Quote Originally Posted by Duonger
    Duonger
    Wow! Now that's what I call service...so my one good one that runs perfectly fine at 278 will be matched? w00t!!!
  6. #156
    Aug 2005
    So when does the Mushkin "weekend" start? I am ready to pull the trigger on something and want to check these out!
  7. #157
    Mushkin U.S.A.
    Mar 2005
    5pm mst
    duonger
  8. #158
    Aug 2005
    991481 eXtreme Performance 2GB (2x1GB) XP3700 3-3-3-8
    Each 128Mx64 XP3700 has a 64Mx8 chip density. Rated 3-3-3-8 at 466MHz. Voltage: 2.6V ~ 2.8V. These modules are tested in a dual channel motherboard before shipment to ensure full compatibility in dual channel mode.
    Latency 3-3-3-8
    Frequency 466MHz
    Parity Unbuffered
    Voltage 2.6-2.8V
    Module Density 128Mx64
    Chip Density 64Mx8
    Pins 184
    Package Jet Black 6 Layer PCB
    Heat Spreader Yes (color may vary)
    Part # 991481
    $340.00
  9. #159
    Jul 2005
    Quote Originally Posted by Capt_Caveman
    Thx again OP. Well, since Mushkin is charging $322 for the HP 2gb Kit then we're looking around $350 for the PC3700. Being $100 more than ZZF for the PC3200, I'll keep my order with ZZF and hope I can get them up to 250 on CL=2.5 that many have.
    going to be doing the same unfortunately.. Got the impression that these new sticks were going to be at or slightly lower than the $300 mark..
  10. #160
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    Duonger,
    Does Mushkin still have the RMA policy where if the sticks are bought from someone else, you cant RMA?
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  11. #161
    Mushkin U.S.A.
    Mar 2005
    yea we do. but call in, we will see what we can do. we have been generous lately..hint hint...
    Duonger
  12. #162
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    crap wish you guys would continue to be generous. lol
    Palit 4870x2
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  13. #163
    Mar 2005
    Madison, WI
    I'm using Redline 4x512 and having some problems. I have the DFI SLI-DR board, FX57, OCZ 520W power supply, Zalman 7700 fan, and 510-2fixed bios. I've got the sticks cooled with a 80mm fan at 3.5-3.6V. I'm running the sticks at 2-2-2-6 at 214x14 = 3000. I've also tried 250x12=3000. I don't want to loosen the timings too much b/c I've seen others getting 250 with a stable 32M pi at 2-2-2-6.
    Do I have to change the voltage on my 3.3V rail to handle the 3.6V I'm sending it? Smart Guardian is telling me 3.21V. I know a realistic OC for the FX57 should be around 3050 (or 3100 but that's stretching it on air) but is the 4x512 limiting me?
  14. #164
    Admin
    Feb 2005
    Ann Arbor, MI
    Is your JP17 config right? No way you could be saying 3.5V in BIOS and only get ~3.2V unless something is seriously wrong. When you set JP17 to 2-3, it takes off your 5V line, no need to tweak your 3.3V line.
    Also, set everything to auto in BIOS except 2-2-2-6
  15. #165
    Mar 2005
    Madison, WI
    Thanks Vapor.
    Smart Guardian says my DRAM is at 3.53V and my ATX +3.3V is at 3.21V.
    Where might I find the JP17?
    I will try everything on auto except 2-2-2-6 (along with optimized defaults.)
  16. #166
    Admin
    Feb 2005
    Ann Arbor, MI
    Your RAM voltage is fine if SG says it's at 3.5V. JP17 is the jumper to switch to >3.2V mode.
  17. #167
    Dec 2004
    Spain
    What do you guys think about that screenies??
    Samsung Value modules w/ Samsung UCCC chips, cheap and ocing stuff...
    I havent read the entire thread, if it is in another page, sorry...
    My screen is the first, with the two modules in dual channel, using the hardware of my sig... the other screenies are from a friend, who has a 754 rig, because of that, those are in single channel...
    Voltage used was 2.9v.
    I find this modules a serious option if you want to run 2x1Gb @ 1T, because they do 2.5-3-3-6 @ 240 fully stable, and 3-4-4-8 @ 270 too...
    Post your opinions...
ID:	35823   Click image for larger version.
ID:	35824   Click image for larger version.
ID:	35825   Click image for larger version.
  18. #168
    Sep 2004
    Wow! Very impressive! My Transcend brand Samsung UCCC didn't do anything even close to that. Voltage didn't seem to help over 2.7v. Please post a Tweaker shot and list your tref setting please.
    You can read about my UCCC here.
    Please get your results into the stickied 2x1GB/1x1GB OC Database.
    Sourcing parts for a mildly over clocked abacus.
  19. #169
    Dec 2004
    Spain
    Sorry, but I tested this modules in a LAN Party, not are mine. They are of my friend, who lives in another city, and who has a DFI Nf3 754 board, but if you want, I can ask him for a tweaker SS (but it will be in single channel mode, and at 265, he doesnt get 270 in his system...)
    BTW, the only timmings tweaked were the 3-4-4-8, the rest in the DFI bios were left at stock...
    Tell me if you want that tweaker screen...
  20. #170
    Sep 2004
    Quote Originally Posted by Lord_RTKK
    Heh. You need to borrow those sticks again! Would like to see the tweaker shot even at default detect setting on your dual cahnnel mobo.
  21. #171
    Dec 2004
    Spain
    You will have to wait until September, at the next LAN Party here in Spain... xDD
    Those are really amazing sticks, giving you high FSB, relatively good timmings and 2 Gb of ram in dual channel, and all of this for 260 € the two modules...
    The shop that sells it here in Spain is this --> http://davidhardware.com/tienda/prod...93017a0eabd274
    They have a screen of it too, but only cpu-z, not tweaker...
  22. #172
    Nov 2004
    Palma de Mallorca, Spain
    Lord, can u ship them to me? It would be great!
    De quien son? (Who is the memory owner? )
  23. #173
    Dec 2004
    Spain
    The owner is Zarza, he is in N3D and Metamods forum, and he is a good friend of mine, he comes with me to Lan parties...
    I can ship some modules to you, but living in Spain too it is not easier that you could shop them at davidhardware.com?? (joking... :P)
  24. #174
    Nov 2004
    No money :P if i had money i would buy a dfi, an nVidia 7800, a vapochill, a OCZ PStream 600w and.. why not? 4 or 5 gigs of that ram :P
    Yes, i saw his results on N3D (same nick: BeSaiD).
    C you!
