Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 134
Thread: chipset cooler dfi ulltra d sli
  1. #76
    May 2005
    Toronto, Canada
    Well I just got done installing the Vantec Iceberq4 and my temperatures have gone up atleast 2C!! WTF?! I even applied AS5. I tried reseating the whole thing twice now and the first time my temps almost hit 60C. I don't get it, I thought this thing was supposed to improve temperatures. I also chipped two corners of my chipset when doin' it. I don't think it'll hurt anything, but if I'm unstable at the same settings I'll know why. This really pisses me off! It seems like I've wasted $23 CAD so far. The light looks cool and does go well with my Asus AX800XL. Hmm, maybe the Iceberq4 is taking the hot air exhausted from my graphics card and putting it straight to the chipset. BTW, I'm using MBM5 to monitor temperatures.
    EDIT: I'm using 1.6V through chipset. Idle with Iceberq4 is now 50-52C. With the stock is was 48-50C w/o AS5. I'ma try the stock cooler with AS5 in a minute.
    DFI NF4 Ultra D 3/10 Bios
    A64 3200+ Venice LBBLE 0515FPBW
    Thermalright XP-90C w/high speed Panaflow 92mm
    OCZ Enhanced Bandwidth PC3500 (2 x 512)
    1 Pioneer DVR-106
    ASUS AX800XL PCI E
    OCZ 520 Powerstream
  2. #77
    XS News
    Aug 2004
    Sweden
    Quote Originally Posted by s7e9h3n
    I'm working on that as we speak. I've got an aerocool vgacooler that needs a little work fitting on the chipset....
    Tell us when your done, think im gonna try build one from copperblock and some other stuff just for fun.
    Why would the vantec be so much better ?
    In my eyes its the same size ?
    Everything extra is bad!
  3. #78
    Xtreme 3DTeam Member
    Jan 2004
    Dresden
    i did it like Minstadave but also mounted an amd fan which is plugged in the fan3-connector
    works great and is very silent
  4. #79
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I personally don't think anything is wrong with the stock hs, take it off and put some good TIM on it and that should suffice.
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
  5. #80
    Mar 2005
    Quote Originally Posted by Major
    It gets very hot with an arctic cooler fitted and spins up after 45 degrees and gets noisey, thats with AS5.
  6. #81
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    Quote Originally Posted by Minstadave
    Yep the fan on it is "winnie"
    See if you can't mount an 80mm fan blowing over the area, the nb fan is controlled in bios and also smart guardian. If you can get some cool air blowing towards it you can turn the fan down on the nb so it's not as noticable. IMO if you have good airflow in the case then a passive hs like has been illustrated would work fine too. I've just never had any problems in my case with either of my NF4 and temps. they run around 45c which IMO is normal and under stress get to 50c but I've never had any issues with the temps causing hardware problems.
  7. #82
    May 2004
    UK, London
    Im thinking about changeing chipset fan to passive hs cooling. You think its enough ? Im planing to buy old non working gfx card for 1$ and use it on my dfi.
    What ya think ?
    http://www.allegro.pl/show_item.php?item=52655708
    i3770K@ 4.4 - 1.25v - TR120 Black+ Scythe GT AP-14
    Crucial Ballistix Tracer 4x4096 DDR3 1866Mhz
    Asus P8Z77-v Deluxe
    PowerColor HD R290 moded to X
    Samsung SSD 256GB 840 Pro
    Samsung HDD 7200RPM 2TB (2x1TB) SA(N)TA
    Corsair HX 650W
    Antec P182 +3x Scythe -800-1200RPM
    Asus 27" VN279QLB
    Logitech G100S, CM Storm Quick Fire TK
    Win 8.1
  8. #83
    Apr 2005
    Norway, approx. 1367Miles from the Northpole
  9. #84
    Xtreme Recruit
    Jan 2005
    looks nice.
    current computer aresnal
    A64 3200+ / DFI "LANPARTY nF4 SLI-DR / 1Gig Gskill LE / 6800GT / watercooled (custom radiator/Maze4 gpu/TDX/AquaExtreme50Z)
    a64 3200+ / MSI K8N Neo2 / 6800gt agp
    a64 3200+ / MSI K8N Neo2 / 6600gt agp
    AthlonXP 1700 file server (almost 1 Terabyte)
    3DMark2001 3DMark05
    xtrmeme workbench
  10. #85
    Apr 2005
    Evolution
    Live to Mod.. Mod to Live!
  11. #86
    Feb 2004
    Houston, TX
    Hah, do you run your motherboard vertically or horizantally? Because that looks very heavy...
    Nice mod!
    Intel E6400 @ 3.2GHZ (1.35v) - Freezer Pro 7
    Gigabyte DS3 C1 F8i
    2GB G. Skill PK @ 400mhz 1:1 (4-4-4-12)
    Asus EN6200 8 pipes enabled
    250GB Hitachi T7K250
    Fortron Blue Storm 500W
    Antec P180
  12. #87
    Apr 2005
    Quote Originally Posted by JDizzle
    Nice mod!
    Not heavy at all.. approx. 150grams
    Running vertically
  13. #88
    Apr 2005
    ..or use som parts from an old zalman GPU cooler
  14. #89
    Mar 2005
    Imladris
    looks interesting..... so what are the temps like and how much will it cost?
    The little air system that could.
  15. #90
    Mar 2005
    Montreal, Canada
    Let me tell ya that during the summer, the chipset temp is a problem with the 2 6800 ultra breathing hot air onto it. Tambient: 32C Tchipset: 57C at idle.
    CPU Intel i7 930 3001A125 @ 4.0 GHz HT
    Mobo Asus Rampage III extreme 1208 BIOS
    GPU Asus GeForce GTX 770 DirectCU II
    RAM G.Skill Ripjaws F3-16000CL9T-6GBRH DDR3-2000 (6x2GB)
    SSD Corsair Force GT 120GB SATA3
    HDD WD Caviar black 1.5TB SATA3
    HDD WD Caviar blue 1.0TB SATA3 (2x)
    HDD WD Caviar 250GB SATA2 (2x)
    HDD WD Raptor 74GB SATA
    Storage controller IBM M1015 SATA3 RAID controller
    CPU Block Koolance CPU-370
    Radiator Phobya G-Changer 360 (3x Panaflo FBA12G12U 120mm)
    Radiator HardwareLabs Black Ice GT Stealth 420 (3x Yate Loon D14SM-12 140mm)
    Pump Swiftech MCP650 (2x)
    Case MountainMods Pinnacle 24
    PSU Enermax Evo Galaxy 1050w
    Sound SB X-fi titanium Fatal1ty
  16. #91
    XS News
    Aug 2004
    Sweden
    Articoc that was very clever solution.
    Can you fit SLI with it ?
    Its an Freezer thats cut ?
  17. #92
    Apr 2005
    ok ok Vantec Iceberq or Iceberq4 or is this totally not even worth getting and just sticking with stock.... I dont want something too loud....
    Intel Core i7 930 @ 4ghz | Gigabyte X58A-UD5 | 6GB G.Skill Ripjaws DDR3 | Radeon 4850 | Crucial m4 128GB SSD
    Intel Core i5-2400 | Asus P8H67-M EVO (Waiting to change to Z68) | 8GB G.Skill Sniper DDR3 | 8x2TB Samsung F4-HD204 | OpenIndiana | ZFS raidz2
  18. #93
    Apr 2005
    Yeah! Done
  19. #94
    Feb 2005
    ArcticOC, how did you cut the heatsink fins so cleanly?
  20. #95
    Xtreme Gamer
    Jan 2004
    Europe
    very xtreme!!! nicely made
    any improvements in terms of OC?
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
  21. #96
    The only ORB-Owning Camel On XS
    Mar 2004
    Ohio
    WOW ArcticOC, that's REALLY nice work!!!
    just want to make sure y'all are aware that in PC health there is a NB fan setting...
    @ stock, the thing wont run 100% till its >50C!!!!
    make sure you set it so that it runs 100% at >26C
    i assume if you use a new HSF but plug it into the NB fan header, it will "under spin" that fan too
    EDIT:
    ive replaced the stock TIM with AS5 and run the fan @ 100% .
    here are my load temps:
    (room temps were 67F)
    (the mem is running on a 5/6 so its @ 250)
    JoeCamel is FOLDing for... A CURE!!! 70+Ghz (please fold so i dont have to quit smoking. j/k)
    6800 EX Conroe @ 4740 MHz (395 x 12) - - Dry-Ice in The Camel Pipe -
    - X1900 CrossFire - - @ 846/945 -- MachII cooled Slave XTX - mOUSE-pOT cooled Master -
    - ASUS P5W-DH -- V-Mods: MCH, V-Core, V-Dimm - - 700w "Mr Zippy" PSU
    - Corsair XMS 6400 CAS3 - 2x gig @ 494 MHz 4-4-3-1
  22. #97
    Apr 2005
    I`m going on (alco)hollyday tomorrow , so the results must whait a while
    And my screencard i currently in RMA.
    I used a circlesaw to cut the cooler.
    The cooler won`t let you use SLi, but lets you use any known VGA-cooler
    My former cooler will do it in SLi (see sig.)
    The cooler was quite simple to bulid
  23. #98
    Nov 2004
    Hunting down Jobs!!!
    Well I'm working on a solution that is easy, cheap, looks cool and hopefully it will cool as well as H2o. I'll post here when all this is confirmed and I have pictures then maybe you will want to duplicate my idea.
    University of Florida Graduate 2005
    CPU: Q6600 @ 3.55Ghz @ 1.52v bios lapped
    MEM: Crucial Lan Fest 2x 1GB DDR2 1185 @ 2.275v
    MOBO: IP35 PRO Hacked W/ heat pipes modded using MX-2
    PSU: 600W POWERSTREAM
    GPU: 8800GTS 602/908
    COOLING: Thermalright Ultra Xtreme - Lapped - 2x 12CM S-flex
    Thermal Interface: MX-2
    Case: Cooler Master CM-690 5x 12CM Fans
    OS: Vista, XP, Ubuntu
  24. #99
    I am Xtreme
    Dec 2003
    Talking I will say more after more testing
    Fed up w/ trying all the low profile , so I grabbed an AL heatsink from digi-key (had it for awhile) bent it up to allow my, err I mean her x700 to fit then epoxied (AS) it onto the chip on my wife's future 'puter, temp after 1 hr of occt is 38c (but it's in the cool basement. Closing the case DROPS the temps from 40c (guess the flow sets up better )
    Will be bringing it up next week to the 'real world' and see what happens - my target temp is < 45. If needed I can always point an 70-80mm fan there
    Pics if successful
  25. #100
    Jul 2005
    hi, my first post on Xs
    i live in austria and here it is very hard to find the vantec iceberg cooler and special stuff that dont sells well today i came across this Revoltec vga cooler. it looks exactly like the iceberg.is vantec and revoltec the same company? or are they workling together?
    what do you guys think will it fit on the lanparty ut nf4? anybody running this setup? the mounting holes sould be fine -right? do i need to get aditional screws and nuts for assembling? i remember a post here at xs where somebody said he had to dremel his vantec iceberg, i will look that up later.
    thx and sorry for my bad english
