Page 33 of 63 FirstFirst ... 233031323334353643 ... LastLast
Results 801 to 825 of 1570
Thread: 2x1GB/1x1GB OC Database
  1. #801
    Xtreme Legend
    Dec 2003
    Northern California
    pentium777, hope you get your RAM straightened out. Sounds to me like a heat problem. But someone said you're using active cooling. Strange.
    I just ran a couple of complete passes of Memtest at DDR600 and 3v. As you know, each pass takes forever to complete with 1GB sticks.
    Audentes fortuna iuvat
    "Fortune favors the bold"
  2. #802
    Feb 2005
    bakersfield ca
    OMG sierra bound that unbuffered bandwidth is huge!! i think thats the biggest a-64 unbuffered bandwidth ive ever seen!!!!!!!
    ________
    Bdsm bbw
  3. #803
    Xtreme Legend
    Dec 2003
    Northern California
    Memtest bandwidth is 3777 MB/s at DDR580 which is where I normally have it because I don't like using 3v all the time.
  4. #804
    Jun 2005
    sierrabound,
    That is awesome. What do you run for everyday stable settings? What voltage?
    Do you run active cooling with your memory? Is it worth it?
    I am just doing a new build with those chips. Would you be kind enough to give some of the settings you used to start with. I am only looking for 270 out of my matched set. Not looking to break any records just want a good stable system for running AI algorithms for 24 - 48 hrs.
    I am especially looking for the following. This is my current settings. Whatever you can fill in would be a great help.
    DRAM Frequency Set - 200 (DRAM/FSB:1/01)
    Command Per Clock (CPC) - Enable
    CAS Latency Control (Tcl) - Auto
    RAS# to CAS# delay (Trcd) - Auto
    Min RAS# active time (Tras) - Auto
    Row precharge time (Trp) - Auto
    Row Cycle time (Trc) - Auto
    Row refresh cyc time (Trfc) - Auto
    Row to Row delay (Trrd) - Auto
    Write recovery time (Twr) - Auto
    Write to Read delay (Twtr) - Auto
    Read to Write delay (Trwt) - Auto
    Refresh Period (Tref) - Auto
    Write CAS Latency (Twcl) - Auto
    DRAM Bank Interleave - Enabled
    DQS Skew Control - Auto
    DQS Skew Value - Auto
    DRAM Drive Strength - Auto
    DRAM Data Drive Strength - Auto
    Max Async Latency - Auto
    DRAM Response Time - Normal
    Read Preamble Time - Auto
    IdleCycle Limit - 256 Cycles
    Dynamic Counter - Disable
    R/W Queue Bypass - 16 x
    Bypass Max - 07 x
    32 Byte Granularity - Disable(4 Bursts)
    As you can see from all my Auto Settings I have been tweaking hard .
    All help would be appreciated.
    Thanks Man,
    Prasith
    MB: DFI LanParty NF4 UT SLI-DR
    -Bios: 6/23/2005-3
    CPU: Athlon64 X2 4800 Toledo
    -OC: None YET
    -Cooling: Stock HS - XP-90 or Zalman 9500 to come
    Memory: Crucial Ballistix PC4000 Z503
    -Size: 2x1024MB on Orange Slots
    -Timings: ??? Don't Know Yet
    GPU: BFG NVidia 7800 GTX 460/1300
    HD: 2 x 74GB WD Raptorks 10k
    -RAID: Trying for 0
    DVD: NEC 3540A DVD-RW
    Power: PC Power & Cooling Express SLI 510
    Case: Lian-Li PC V1200B
    Windows XP Professional w/SP2
  5. #805
    May 2003
    Greece,Athens
    new mems keep testing
    OCZ EL 2GB DC KIT
    2.8v street racer normal,5,enabled,disabled
    keep testing
  6. #806
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by Prasith
    sierrabound,
    For everyday usage I run them at 290 with 2.8v. I do use active cooling (90mm fan) and would recommend it. Here are the memory settings I use. BTW, these are the same settings I used to run Memtest at DDR600. One other thing. The Ballistix had been running all day before I ran Memtest for an hour, so I wasn't testing with cold sticks.
  7. #807
    Xtreme Legend
    Dec 2003
    Northern California
    Sandra buffered and unbuffered at 300X12.
    And just for kicks, a suicide Memtest screen at DDR616.
  8. #808
    Jul 2005
    Quote Originally Posted by fareastgq
    yeah, makes sense, it's a heat issue most likely. I'm running my ran at 2.5 volts 0 errors.
    I can confirm definately not a heat issue, have a room dedicated AC unit that blows fairly close to the PC, at the time ambient was around 72-74'F and I have a tornado of fans in my case ram is barely warm if even noticable when touched. So far 2.5 @ 246 and 250 haven't produced any errors but I've been running over a month at 2.6 also until I checked that test #4 and got 1 error.
    PC1 EVGA Nvidia 790i Ultra | E8400 Retail @ 4.05GHz 1.35v | 8GB Mushkin Ascent @ DDR3-1680 | 2xBFG GTX 280 SLI @ stock | 30" Dell 3008WFP @ 2560x1600 XHD | XFI Fatality | 3x256GB Corsair(Samsung) SSD Raid0 & 1TB Samsung Backup | LG DVD / CDRW | NEC DVD DL 16x | CoolerMaster Stacker 830 8x120mm high 110 CFM per fan| 1000w Corsair SLI certified | Scythe Infinity (dremel mod to avoid caps on board)
    PC2 (Wife) ASUS P5WDH Bios 1101 | E6400 Retail @ 3.2 | 4GB Corsair 6400C4 | 1xBFG GTX 260 @ stock | 24" Dell 2405FPW @ 1920x1200 XHD | XFI Xtrememusic | 2x150G Raptor Raid0 & 1TB WD Backup | Pioneer DVD | CoolerMaster Stacker 830 | 850w PCP&C | Stock HSF
  9. #809
    Nov 2003
    Discovering vCore-to-Strap locks
    I have set my stable speed at 289 1:1 x 9.0 = 2600 MHz.
    Timings at stock, vDIMM at 2.85v.
    My memory bandwidth is extremely low for the OC that I have.
    Sandra Buffered shows right at 7Gs, which is low for 289 MHz FSB 1:1, no?
    Any ideas on what is going on here?
    See sig for more details.
    Q6600 G0 at 3.5 GHz 1.30v on DFI P35-T2R
    4GB OCZ PC2-9200 Reapers
    150GB WD Raptor, 2xWD 120GB RAID-0, 3x320GB HDD
    BFG 8800GTS OC at 675/2100
    Danger Den Based Water Cooling: TDX-775, 8800GPU, DD NB Block on Thermochill PA120.3 Radiator w/ DD 12V Pump
    OCZ GameXStream 850W
    MountainMods U2-UFO 18" Cube Case
    DELL 2405FPW 24" Widescreen LCD
    RME-Audio Fireface 800 based audio production
  10. #810
    Xtreme Legend
    Dec 2003
    Northern California
    At 290X9 with the settings listed above, I get around 7350-7400 in Sandra buffered.
  11. #811
    Jan 2005
    sierra_bound Awesome!!
    Lood007 Maybe some of your 'lesser' memory timings like your Twr, Trtw, Twtr, Trfc are a bit conservative?
  12. #812
    Nov 2003
    Wait... don't X2 CPUs lose a lot of bandwidth b/c of their shared mem controller?
  13. #813
    Jul 2003
    Massachusetts
    Quote Originally Posted by Lood007
    I score around 7000 with 270x10 1/1 3,3,2,5
    So you might be a little on the low end but not much
    A64 X2 4400+@2.7/DFI NF4 ULTRA D//Patriot Pc3200 LL CE-6 2gb@540 3,3,2,5/7800GTX/OCZ Modstream 520/LLPC75 swiftech H20.
  14. #814
    Nov 2003
    Quote Originally Posted by skipio
    Timings are in my previous post here
    http://www.xtremesystems.org/forums/...&postcount=766
    All timings look good to me... nothing too conservative.
  15. #815
    Xtreme Idiot
    Mar 2005
    has anybody tried out the ocz titanium or platinum yet?
    merom t7200
    aopen ydg 975x
    2x1gb patriot pc6400
    ati x1800xt
    x-fi xtreme music
    wafflepot+ dice
    Conroe...
    The conroe uses 4mb's of L2, it is a SSE monster. 2 cores, extra 64 bit line. About it. Will be a great multi-tasker. But its really not that impressave.
  16. #816
    May 2005
    Fayetteville, North Carolina.
    Quote Originally Posted by sierra_bound
    I set my rig up EXACTLY like yours. Memtest86 only shows 3199MB/s compared to your 3908. Any clues? what bios are you using?
    Gigabyte Z68X UD7
    Intel Core i7 2600K (testing)
    16GB Mushkin Redline 17000 2133 1.65v
    EK, 3x120 Rad 2xMCP655
    Acer 1200w PSU
    2-128GB Samsung SSD RAID 0
    2-1TB Seagete 32mb RAID 0
    1-1TB Western Digital
    1- Plextor PX-B320SA Blue Ray
    1- Plextor PX-880SA 24x DVD/RW
    2- EVGA Nvidia GTX-480 SLI
    LG 30", Hanns G 28"
  17. #817
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    He's at 3.6GHz nugzo....that's why
    Formerly XIP, now just P.
  18. #818
    Xtreme Legend
    Dec 2003
    Northern California
    Quote Originally Posted by nugzo
    702-2. And that Memtest screen was for 2.7GHz (300X9). Only the Sandra results were at 3.6GHz (300X12).
    I don't know why bandwidth was 3908. I run Memtest mainly to check for errors. I ran it last night after pentium777 said he was having problems. Just wanted to check to make sure I wasn't getting errors. I also ran it several times at 300X9 and each time bandwidth was 3908. Someone else was getting 3708 MB/s at 295.
    http://www.xtremesystems.org/forums/...92&postcount=3
  19. #819
    May 2005
    Yeah i used 300*9 also. 704-2 bios. will try 702-2. if that doesn't do it i guess its the "New" ballistix that's is doin it. Check Bigtoes setup Here post # 46 and see if you can get the same or better with his config. I couldn't come close with my setup.
    Gigabyte Z68X UD7
    Acer 1200w PSU
    LG 30", Hanns G 28"
  20. #820
    Xtreme Legend
    Dec 2003
    Northern California
    Actually I did try 257X11 last night after seeing his set-up. I got similar bandwidth: around 3550.
    The OCZ modules are pretty good. But they can't do 280-300 @ 3-3-3 like Ballistix. A few people are making a big deal about the multiplier used. Well, a lot of CPU's simply can't do 280X10 or 270X11. Has nothing to do with having a bad memory controller. Some CPU's just can't run at those speeds. A Honda Civic isn't going to do 175mph. But it's not because it has a bad engine. It's just that it doesn't have enough power.
  21. #821
    Xtreme Idiot
    Mar 2005
    i only need 250 so if either of them does that at reasonable timings i'd opt for those over the out of stock crucial
    merom t7200
    aopen ydg 975x
    ati x1800xt
    x-fi xtreme music
    wafflepot+ dice
    Conroe...
  22. #822
    NREMT-I
    Jul 2005
    near Atlanta Georgia (and hate it)
    I have some of this ram on order, and should be here tomorrow. I was just wondering, is there something different with the "NEW" ballistix? Did they change something? I just want to see what im in for. Thanks
    Nothing anymore
  23. #823
    Sep 2002
    Dallas Tx
    Quote Originally Posted by Waffles
    Ballistix Z503's are in stock at Crucial, looks like even the Tracer is in stock
  24. #824
    Xtreme Idiot
    Mar 2005
    Quote Originally Posted by Blue078
    iits like friggen $400 tho lol
    merom t7200
    aopen ydg 975x
    ati x1800xt
    x-fi xtreme music
    wafflepot+ dice
    Conroe...
  25. #825
    Jan 2005
    Lood007
    I thought
    Trc = Tras + Trp
    then
    Trfc = Trc + (2 - 4)
    But neither you or sierra_bound seems to be using this in their A64 Tweaker, why is that? Am i missing something? Or is the above wrong?
    Also how come noone is using Everest or Sciencemark 2 or something else that benches latency? From what i've seen DDR416@ 2-2-2-6, DDR500@2.5-3-3-7 and DDR560@3-4-4-8 have within 4% the same latency yet the bandwidth difference is about 20-22%.
