Page 31 of 43 FirstFirst ... 212829303132333441 ... LastLast
Results 751 to 775 of 1072
Thread: The Venice OC DISCUSSION Thread
  1. #751
    Feb 2005
    OZtralia
    Quote Originally Posted by Leverpospade
    Just resived my 3000+ venice. It's a 0520 EPMW, and right now I'm running with the stock cooler and stock voltage. So far I have been able to reach 2,9 GHz with stock voltage but then it bluescreened
    I'll be testing it futher tonight, and hopefully I'll mount my Vapochill SE tomorrow
    So after 4 venice CPUs, I have got a nice stepping...
    Hmmmm I have a 3200 0520 BPMW that so far have only been able to get 2400 default Vcore (1.344 in CPU-Z) , still early days though
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
  2. #752
    Mar 2005
    Quote Originally Posted by burningrave101
    I have a week 15 3200+ Venice and it has no problem running 2.8Ghz but i would have to agree that it seems to have a weak memory controller. It doesn't like to run high memory speeds so i sold my TCCD.
    Yes, week 15 seem to have a very weak mem controller. Didn't allow my BH-5 run with 2T timing @ over 245 2-2-2-5. Is there any BIOS can fix this problem ? ?
  3. #753
    Jul 2004
    Maringá - Paraná - Brasil !
    There are two things that can help you to solve this problem:
    - Disable Bank Interleave
    - Sell the processor
    Good luck
    Day-to-day config:
    Venice 3000+ LBBLE 0515FPCW @ 2.7GHz 1.47v
    DFI LanParty UT nF4 Ultra-D Rev. AA0 702-2 coolermod
    1GB G.Skill PC4800LA @ DDR600 2.5 4-3-6 1T 2.72v [TCCD 440 Brainpower 0808]
    Gigabyte GeForce 6600GT PCI-Express
    SoundBlaster Audigy ES
    Seventeam 420w ST-420BKV (real power, 2× +12v [16A each], 24-pin)
  4. #754
    Jun 2005
    Greece
    Quote Originally Posted by vozbidder
    My venice week 15 can run my Tccd at 290 and my single stick ch-5 at 260 1.5-2-2-5 with 3.4v
    My tccd at a claw hammer cpu was able to run at 315 at 2.8 volt....but now with this venice i was able for 290 at 3.1 v and 2.5-3-3-5 (always memtest stable)
  5. #755
    Jul 2004
    Here with my week 15 I can run 300 FSB 1:1.
    Day-to-day config:
  6. #756
    Apr 2005
    Brazil
    E aeeeee Higher!!!
    Hi guys,
    I was wondering how much voltage is safe to run 24/7 on a Venice 3200? 1.6v? 1.7v?
    Thanks!!
    AleX
    AMD Athlon64 3200+ @ 300x9 | Venice 0519 | DFI LP NF4 UltraD
    GSkill F1 2GBHZ DDR500 | BBA ATI Radeon X1900XTX 512 MB
  7. #757
    Jul 2004
    E ae Alex.. hehe.. blz? :***
    I think 1.65v would be a safe bet! In the air I wouldn't go for more.
    Good luck!
    Day-to-day config:
  8. #758
    Apr 2005
    Brasil
    I would stick to no more than 1.6V for every day usage.
  9. #759
    Jun 2005
    Greece
    Quote Originally Posted by higherøx
    Good luck!
    Depending on cooling
    If you have air cooling i think that 1.55 its ok
    For water 1.65
    And on dd 1.75
  10. #760
    Mar 2005
    Quote Originally Posted by OverClocker_gr
    Have you tried to run tight timing @ 250 2-2-2-5 ? Really disappointed about my 3200 week 15, althought it has impressive OC result
    Do you guy have any BIOS to fix the mem controller problem ? PLzz show me 1
  11. #761
    Jun 2005
    Greece
    So.. yes i tried 260 at 1/1 at 1.5-2-2-5
  12. #762
    Mar 2005
    sry bro , i wanted to know about dual , not single stick
  13. #763
    Jun 2005
    Greece
    I think that there will be no difference if the controler cant handle it...
    btw with my tccd at 2-3-3-5 i am able to run at 255
  14. #764
    Apr 2005
    Denmark
    I had my vapo SE installede last nigth, but I had a lot of problems getting the 939-kit to fit. After 2 hours I managed to get it to fit, so it could keep an okay temp.
    Right now I'm running around 5-10 C idle, but in load it sometimes jumpes up to around 35 C
    But here is what I have been able to do so far:
    http://photobucket.com/albums/a120/L...zsuperPI1m.jpg
    Anyone know how to bring down the PWMIC temp, cause it's seams quite high..
    My mobo won't clock over 350 FSB, so have anyone got suggestion to how i can get higher??
    Hope you understand my bad english
  15. #765
    May 2005
    Dubai,UAE
    ok here what i have done ... i changed my 3500+ (CH) to 3500+ ( Venice )
    and iam very happy with until i reached with it to 2.65Ghz @1.43V.
    the problem is .. During Prime95 CPU Torture TEST to see the Stability .everything seems OK. ( no Errors for over 2 hours)..but when i reach 2.7Ghz Prime95 does not give me any errors..no.. instead the comp hangs without any warnings..
    so i think my PSU is the Problem ..right? i have 18A in 12+ Rail.
    help plz
  16. #766
    Xtreme Mentor
    May 2005
    San Diego, California
    It could be, 18A on the +12V rail is kind of low, as i've said before, it's recommended to have 26 or more amps on the +12V rail for AMD64 Xtreme OCing. I have dual 18A rails and they kind of suck, instead of prime95 erroring i get voltage droops under load and reboots. A more powerful PSU would be a good idea.
    Reboots or prime95 hanging is caused by low voltage, give it more and it should be fine... but again, i think the low voltage is associated with teh voltage drop under load, my voltage goes down by ~.016 under load, which doesn't sound like much but *perhaps* that's the difference between fully stable and not fully stable.
    Intel Rig
    2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
    Custom Water of course
  17. #767
    May 2005
    Dubai,UAE
    Quote Originally Posted by Absolute_0
    so what Psu do you recommand me to buy??
    i need the Psu to be fully stabilty at very high overclocking.
    thank you
  18. #768
    Xtreme Mentor
    May 2005
    I'm not sure, antec550 and powerstream 520 are pretty popular. Can't go wrong with PC Power and Cooling or a high end Zippy though
    Intel Rig
  19. #769
    May 2005
    Dubai,UAE
    will antec550 do the job perfectly??
  20. #770
    Dec 2004
    Atlanta
    Look my 3200 has a new friend I got it earlier today but about 15 mins in I had to step out. Should have some results later tonight!
  21. #771
    May 2005
    Dubai,UAE
    What PSU you use to get that high of Oc'ing??
  22. #772
    Jun 2005
    Greece
    Your +12v rail must have more than 25amps for stable o/c
  23. #773
    May 2005
    Dubai,UAE
    can you guys tell me which is the Best PSU for high overclocking for around 170$ ??
    and Btw iam running Q&C = Default, the 12+=11.84v and @ 2.65Ghz ,12+ = 11.56v Idle and 11.36v @ load then boom restart
  24. #774
    Jan 2005
    I picked up the Ocz modstream 520watt yesterday it has 28amps on the 12volt and a 12volt peak of 40amps, so far so good, I haven't had chance to test it fully yet but yesterday I tried 1.75vcore in corecenter and it didn't shutdown. So mayne soon When the a/c is on max I'll try some higher vcore, does this board undervolt or what? If i set 1.60 in corecenter i get 1.52 in cpu-z whos right and where can i test with Multimeter?
    I just noticed that Now with 1.6 in corecenter I get hihger vcores 1.55 now lol sweet so I can probably low it abit and still be stable, I had 18amps on my old psu looks like it really was a problem.
  25. #775
    May 2005
    Dubai,UAE
    i found Vantec VAN-520A.. it got 28A on 12+ rail , 52A on +5 Rail and 26A on 3.3V ,,,what do you think?
    other than that they got Enermax 600 and 550 watts PSU's and thos is really bad on 12+ rail ,, i know that they got 2x12+ but i dont need it cause they carry out 18A on both of them.
