Looks 8 pin or 6 pin to me :s
edit: hmm maybe 4-pin with black components either side. Its hard to tell to say the least![]()
Opteron 170 @ 3.0Ghz on air, Opteron 144 @ 3.1Ghz on air
Noticed both those things too.Originally Posted by Joe Camel
It's 8 pin like on some Intel boards, needs an 8 pin connector on your PS or it won't work. I had one of my PCPC 510's moded to be ready.
{2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
Crap..this will not be out till Oct..no hel pf or me now....
wonder if I should go ahead and get DFI now..I really hate this..sure suggests they have an issue with their current product...too many changes here for simple fine tuning
Chipset location still does not look good![]()
ill personally trust DFI one more time... on the way using it im sure what the cause was for this new revOriginally Posted by HARDCORECLOCKER
if this is your first night in xtremesystems,
you have to overclock.
what is the floppy connector for on the NF4, still got me stuck, i didnt hook it up when i built my cause i didnt know that was what it was.
Desktop
AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
Gigabyte GA-MA790X-UD4P (F9 Bios)
8GB (4x2GB) @ DDR2-800
ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
Corsair Force GT 120GB
LSI MegaRAID 8408E (3x750 R5)
Windows 7 x64 SP1
Cisco E2000 with DD-WRT kernel 2.6
It's for extra power for SLI systems.Originally Posted by BrokenWall
Well we will see how things work out when a couple of us get the board![]()
Abit KN9-SLI
X2 3800+
1gb corsair pc5400
2 evga 7900gt
200gb maxtor sata
ocz 520w
heatware:althes
ebay althes
Or when one of us gets a couple of boards![]()
what makes u think that? this pic is from the DFI Lanparty UT RDX200 CF-DR with ATI chipset.Originally Posted by Vassili
What i want to know is WHY the new revision....Whats gona be different from the first board.
Description:
EVGA X58 Classified 3, Core i7 980 Extreme(Running Stock ATM), 6GB DDR3 Corsair Dominator GT 2000mhz, 2 x EVGA GTX 580 SC in SLI (Running Stock ATM),
2x WD Cavier Black 640GB Raid 0, Silverstone 1200W PSU,Corsair Obsidian 800d Case, Windows 7 Ultimate 64 Bit.
Oskar ?
DFI better hurry up because that Sapphire board looks MONEY
i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60Originally Posted by CompGeek
dont know if it is nf4, but what makes you think it will be better? maybe is a cost saving new revision without much improovement, and no 4v option (way to many problems).
i could be completely wrong but you never know (happened with lanparty nf2 the ones from taiwan were better than the ones from china).
you must be drunk it says nforce 4 right on it hehe its just laid out the same.Originally Posted by Der_KHAN
im sure this board has all the hardware features that the ati chipset one does. 4vdimm is fine on it because it uses a different type of volt regulator that is cool.
________
MERCEDES-BENZ 320 SPECIFICATIONS
hmm, nf4 huh? good pointOriginally Posted by brandinb
I just found this information .....
PURE PI-A9RX480 - ATI's Chipset for the AMD Enthusiast "The ATI Xpress 200 Chipset Family"
Discussed here for a long time
http://www.xtremesystems.org/forums/...6&page=3&pp=20
