Page 20 of 23 FirstFirst ... 1017181920212223 LastLast
Results 476 to 500 of 571
Thread: Impressive 6200 Overclocks
  1. #476
    Feb 2005
    Iowa City
    use the latest version of nvflash, 5.13
    AMD 6400+ BE
    DFI Lanparty UT 790FX-M2R
    2gb Crucial Ballistix DDR2 800
    ATI Radeon X1900XT 512mb
    PCP&C 750W
    Water cooled:
    Swiftech Storm CPU
    Maze 4 GPU
    MCP655
    Modded Heater Core
  2. #477
    Oct 2004
    Việt Nam
    Help
    I have a Leadtek 6200 and I can OC core/mem 600/700 with Leadtek 6600 bios.
    My problem, when I use nvflash 5.13 anh flash this card with SparkleUltra bios. Everytime, boot in windows I receive notice - the power not connect this card and Riva show core/mem is 300/550.
    I can't OC more a bit with this bios .
    Please help me.
    Thank for information.
    sorry my English
    AXP-M 2400+@2.92G
    San Diego 3500+@3G
    Opteron 146@3.06G
    Opteron 170@3G
  3. #478
    Xtreme X.I.P.
    Aug 2002
    Quote Originally Posted by iMAX
    Please help me.
    sorry my English
    My Leadtek 6600 flashed ok with Sprkle 6600 BIOS, what is the Ultra version ?
    Regards
    Andy
  4. #479
    Nov 2004
    Estonia
    hello
    tnx for your tips, i managed to dump bios and i reaced 530/730 and my 03 scoor was 8k , bretty good, but i have now OCing problems, i but in rivatuner hihger clocks, it shows i have butted higer clocks, but in rivatuner monitoring are my clocks still sama.
    sry for my english
  5. #480
    Xtreme X.I.P.
    Aug 2002
    Quote Originally Posted by sponge bob
    sry for my english
    Hi, No problem with the English !
    I think you must be doing either of the following :-
    a) altering the 2D clocks
    b) Altering the 3d clocks in rivatuner but do not have force performance level on, so it only goes to the 3d higher clocks when 3dmark is run. This being the case if you leave rivatuner on during 3dmark then it should increase and then decrease again as you enter and leave.
    Good luck !
    Regards
    Andy
  6. #481
    Jan 2005
    France
    WR 6200 3D05 WHQL - FM approved
    ORB Link
    DFI NF4 Ultra-D
    Opteron 165 @ 3.0GHz Max | Opteron 146 @ 3.2GHz Max
    Leadtek PX6200TD GF6200 @ 692/743 Max
    Sapphire X800-XL R430 @ 549/579 Max
    Sapphire GTO² R480 @ 684/633 Max
    2x512 Twinmos UTT 270 2-2-2-5 @ 3.63V
    2x512 CMSAM New BH5 250 2-2-2-5 @ 3.5V
    Waterchiller by Learn R22-225W
    #5 6200-3DM01:21891 |WR 6200-3DM03:8753 | WR 6200-3DM05:3946 | WR 9800Pro-3DM05(110):3676 | #2 X800XL-3DM05:6660
    | WR X800 GTO² 3DM05:8050 | WR X800 GTO² 3DM03:16472
    Overclocking-Masters.com
  7. #482
    Sep 2004
    Istanbul , Türkiye
    Quote Originally Posted by Ebola
    ORB Link
    Ebola , great score congt..
  8. #483
    Oct 2004
    Việt Nam
    @Ebola : stop here now
    Core ~ 700 Mhz -> it's very nice
    @zakelwe : Ultra version is core/mem 500/700. Someone tell me it's good for ocing, but not for me
    AXP-M 2400+@2.92G
    San Diego 3500+@3G
    Opteron 146@3.06G
    Opteron 170@3G
  9. #484
    Xtreme X.I.P.
    Aug 2002
    Nice score ebola !
    Shame the Ultra settings do not work for you iMax.
    Regards
    Andy
  10. #485
    Nov 2004
    Estonia
    03 Overclock@535/735 8287 (y)
    05 overclock 535/735: 3607 :o
    my beast imho core oc sucks hard
    btw andy i run 3d mark but clocks wont go higer, still the same clocks as my 2d but low power 3d helped me little bit
  11. #486
    Aug 2004
    Kaohsiung.Taiwan
    my asus 6200's core=600
  12. #487
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    erm what is wrong with 600/762 ???
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
  13. #488
    Aug 2004
    Kaohsiung.Taiwan
    ORB Link
  14. #489
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    lol i barerly get 540 at my 6600
  15. #490
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    I got a Gigabyte PCI EX 6200. it mods to 8 pipelines perfectly.
    so I took a old P4 Heatsink, and mounted that on it. and it was doing 615/730 at stock. just the P4 heatsink was all that was different.
    while this was impressive for what the card was doing at stock, I knew it had alot more in it.
    so I extracted the default bios, and modded it, for new clock speeds of 575/650, and enabled the Temp Sensor to work.
    this was cool to see the temp sensor working.
    finally, this card felt like it was turning into a card I could game with
    well, good is never good enough for me, I had to go farther...
    so I started messing with the driver first, and found that if you use the 6600 Driver, you get a nice boost in your 3dmark2003 score
    then I volt modded it, and quickly found the limits this card has...
    anything above 1.54 volts, equals fuzzy dots on the screen, and quick freeze ups, even at low clock speeds.
    this card just will not take anything more then 1.54 volts.
    at 1.45 volts, the speed I used was 640 mhz, which worked great. but at 1.5 volts, the card quickly overheats, even with the huge P4 heatsink on there.
    seems this card needs a waterblock
    so no more then 640 on air for me... not yet atleast.
    the Memory however, is abit of a mystery.
    it's solid up to about 3.25 volts, then after that, it appears to be doing great...
    but if you up the voltage past 3.3 volts, the memory just goes nuts.
    I had it all the way to 3.53 volts, and the card was fine, just doesn't like anything more then 3.25 volts.
    at 3.15 volts, I had 770 stable for benchmarks.
    thats nice getting another 40 mhz with that volt mod, cause that alone, got me another 200 points on 3dmark2003, which showed me, the memory was really holding back my Core.
    sooooo, so far, this cards pretty damn cool.
    it was only $50 from neweggs refurbs, and at that price, I am beyond impressed and have had a ton of fun with this card.
    only problem so far, is a strange one...
    the 7189 driver sucks for this card.
    about 20 seconds into 3dmark 2003, it will just "blink" then the speed is drastically lower, getting about 7000 frames total, when the airplane test finishs.
    when the card works great with the 6693 driver, I get about 9700 frames by the end of that same test, cause it doesn't do that "Blink" with that driver.
    that thing with 3dmark2003 and the 7189 drivers, is constant, once it blinks, you have to reboot, before the computer will start being any good again.
    so the newest drivers from Nvidia, are totally unsuable for me, so my 3dmark2003 scores are really lacking at the moment
  16. #491
    Xtreme X.I.P.
    Aug 2002
    Kunaak, does your Gigabyte have the ISL6549 IC for voltages ?
    Regards
    Andy
  17. #492
    Feb 2005
    I did 621/619 on my Leadtek 6200TD http://service.futuremark.com/compare?2k3=3758720 with score of 7117
    and 628/629 with score of 7044 http://service.futuremark.com/compare?2k3=3758483
    CPU is affecting the result
    Headshot ! those who can, do, those who can't, complain.
  18. #493
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by zakelwe
    Regards
    Andy
    Nope.
    ISL6534CR.
  19. #494
    Xtreme X.I.P.
    Aug 2002
    Quote Originally Posted by Kunaak
    Nope.
    ISL6534CR.
    Hmmm, the Leadtek has ISL6534 and ISL6549 and when more than 1.55v is applied either blank screen or lock ups occur. At 1.5v+ if you go into 3d it locks up, at 1.55+ it locks up in 2D, I wondered if your card was showing the same problem because of the ISL components?
    Regards
    Andy
  20. #495
    Mar 2005
    Belgium
    Is a 6200 MSI a good card for overclocking?
    E6400@3.2GHZ | P5B deluxe |8800GTS 512MB | 2*250GB Hitachi + 500GB WD|
    Aerocool masstige | Seasonic 600W |
    MX510@450HZ | 24" LG 245WP
    Cooled by: Swiftech storm - MCP 655 - Maze4/EK vodni block - Nexxos Dual Extreme
    A64 3000+@2.9ghz // XP M 2500+@2.5ghz // XP M 2600+@2.6ghz benchable at 2.9ghz superpi 35s //
    AMD opteron 146@3GHZ CABYE APMW batch 0076
  21. #496
    Feb 2005
    Estonia/Tallinn
    Very nice oc m8 m cheers :=) Keep up da good work
  22. #497
    Nov 2004
    Estonia
    Quote Originally Posted by neoman
    look whos here next week im going to hit atleast 8,6k in 03 with my asus 6200 i have problems butting on my barton inbox but soon ill fix it
  23. #498
    Nov 2004
    Estonia
    now my asus 6200GE is full modded gpu and mem
    i reaced 780 mhz 3v
    but i cant OC my core, it seems that thermal thortling in action, but my temps are realy fine any help how can i get ride off that throtling, there were rivatuner tweaks but i cant find them
  24. #499
    Mar 2005
    Indonesia
    that's great spoge bob, maybe u can change with the Sparkle Ultra BIOS (to get more core oc'ing headroom)
    anyway, what's ur mem? 4ns or 3.6ns?
    and what ramsinks do u use on the mem modules?
  25. #500
    Jan 2004
    I have an Sparkle 6200 agp and an 6600 agp in tests but the max I can get with stock cooling is 460/555 for 6200 and 525/585 for 6600. I can activate the extra pipelines for 6200. But I'm dissapointed about the overclocking. What can I do ?
