Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: The next P5ND2 problem...overclock wont stay in windows
  1. #26
    Dec 2003
    Yes i still have this problem. Its reported that the shiping BIOS does not have this problem- but other ones like hanging on each reboots, which is annoying.
    God of all that is SFF.
    SFFclub.com
  2. #27
    Jul 2005
    Antequera
    I having the same issue. Try to use ntune. You can tweak voltages and timings in bios and then make the FSB overcloking with ntune. There is only one problem, ntune is limited to 250FSB.
  3. #28
    Dec 2003
    Windows overclocking isnt my thing, i format allot and i just wont trust allot of windows-based hardware tweaking.
    SFFclub.com
  4. #29
    May 2005
    IA
    Quote Originally Posted by afireinside
    Even if you hate it its worth a shot to see what it detects for fsb setting and if changes via it work. Heck, you might even take to windows OCing
    Agreed. I simply HAVE to windows OC if I want to get full performance. Bios only lets me hit 235, 236+ = no POST. This ram is stable up above 250, so to get it to push as hard as I want, clockgen + EIST all the way. Personally, I'd rather oc from bios alone as well, for 24/7 settings; but for benching, I still choose winxp oc. Honestly, if you are just trying to find the maximum you can push your rig, I would definately recommend windows OC, clock gen raise fsb 1mhz and set values until you either cant s_pi 2m or until it crashes, then set backwards from that point.
  5. #30
    Xtreme Family
    Dec 2004
    Republic of Hiroshima
    i have the same problem with my P5ND2 Deluxe and 0780 Bios,i can“t oc in the bios ,just with clockgen
    if i use HT enable the SO get crashed with oc or without oc.
    setting fsb 230 in the bios and getting nothing in windows ,aibooster keep the oc for 30 secs before turn back to 3ghz
    and CPU-Z reads CPU incorrectly
    and running with a poor oc in SLI mode
    in heavy load 830/XMS2-Pro runs great with i945, the problem is NF4 4 sure
    0780 bios sux with Smithfield?any beta bios to help? for better oc the i955X is the way?Gigabyte Royal or Asus again?
    thanks 4 any help.
    Junior
    Mojo
    Family
    Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
    Criminal
    Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
    Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
    Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
    Kids
    P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
  6. #31
    Sep 2005
    hi guys!
    Anyone have found a way for use this damned motherboard???
    I bought it some days ago and can't overclock
    Any one can send me the bios 0605 for P5ND2-SLI Deluxe?
    mail: uomoazione@hotmail.com
    Really thx for any help!
