Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: MSI Neo2 Platinum
  1. #26
    Jul 2004
    I'm having problems maintaining a stable overclock on my Neo2 at over 250HTT. I have the command rate at 1T and aggresive timing on. I'll try that out tonight and see if it will help.
    Cheers
  2. #27
    Jun 2004
    california
    what bios are u using
    Speaker4theDead?
  3. #28
    Jul 2004
    Ok, H20
    I will try those settings tomorrow. Damn I dont understand why prime makes erros in less than 10 min at 10*240. I already tried 4x htt with 1.65 volts in cpu and it didnt work either. The only thing left is to try it with the auto settings in bios fot the cycle time.
    Mcklain
  4. #29
    Jul 2004
    Bios version 1.1
  5. #30
    Sep 2003
    Just received a pair of 512MB OCZ PC3700 EB today and has been doing some testing. Result is very disappointing. SuperPI failed starting at 222 HTT and I have tried most tweaks already.
  6. #31
    Jul 2004
    have you tried memtesting those sticks? If it errors out at stock then rma them.
  7. #32
    Xtreme Recruit
    Aug 2004
    Sweden
    I have a pair of 512MB 3700EB ocz and I have them at:
    3-2-2-10 1T
    270
    3.2v (ddr booster)
    MSI K8N Neo2 Platinum
    Asus P5W DH Deluxe, E6700 @ 3.6Ghz, Super Talent PC6400 4Gb, nVidia 7600GS, Creative X-Fi
  8. #33
    Sep 2003
    3-2-2-10 1T
    270
    3.2v (ddr booster)
    That's very nice. Can you run most tests (Prime95, SuperPI, 3DMarks, etc.) error free at that speed? And what's the max without the booster?
  9. #34
    Xtreme Recruit
    Aug 2004
    Sweden
    3DMarks I can run without any problems, haven't tried with the other programs.
    And I bought these memories along with the ddr booster, so I haven't used them without it.
  10. #35
    Jul 2004
    Hi,
    H20, so what youre saying is that over 220 htt, youre pc is not stable??(either prime or superpi makes errors). Cause if its the case, youre not alone. At 218 I dont have any problems running prime but at 240 it makes errors quickly, but I know it's not the ram. I am thinking this board has alot of difficulties with the ram voltage. What fo you think?
    Mcklain
  11. #36
    Xtreme Recruit
    Aug 2004
    Sweden
    I tried Prime95 and I get error but everything I do otherwise on my comp is stable.
    But I read somewhere that Prime95 gets error if one has 1024mb in ram?
  12. #37
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    I have the same problem. I cant get my KHX PC3500 (bh-5) to run more than stock (216) it seems like my RAM is not responding to the increased voltage. if i give them 2.85v they dont wonna go further than 216 anyway. they should run 220 2-2-2-5 at 2.8 like they did it my barton system, but they cant.Its the same problem with my ABIT and my NEO2 and my Soltek. so i am starting to blame the memory controller in my fx-53 ???
    Also when i try increasing my PSU +3.3 line all the way to 3.7 it does not make any change.
    And 1 prob i dont understand is, that everytime i play with the rails om my PSU, i cant get ANY USB devices to work at the same time.
    Also
    The whole world's hip and thats not cool !
    Rip Van Hippy
    Doesn't expecting the unexpected make the unexpected the expected ?
    Light travels faster than sound. This is why some people appear bright until you hear them speak
  13. #38
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    ohh..and i cant run superpi or install any progs at 10*265, but ALL 3d marks and games i can run all night without probs
    Rip Van Hippy
  14. #39
    Aug 2004
    Italy - Piacenza
    Gascone, how many point do you get in the 3DMarks?
    Opteron 170 @ 2.2Ghz - Zalman 9700
    OCZ Pc3200 2x512Mb VX @ 220Mhz
    DFI nF4 SLI-DR ( 3.29 BIOS )
    Leadtek 6800GT@415-1120
    Seagate Barracuda 2x120Gb Raid0
    This is the rule :P
  15. #40
    Xtreme Recruit
    Aug 2004
    Sweden
    I'll let you know soon as I get my X800XT PE.
    Using 9600XT at the moment while waiting got my new card.
  16. #41
    Aug 2004
    Italy - Piacenza
    Ok Ok, no problem .
    In my opinion this mobos are very differents from standards, someone lucky, someone unlucky .
    This is the rule :P
  17. #42
    Xtreme Recruit
    Aug 2004
    Sweden
    It is the same with all other mb's.
    Have had my fair try with some.
  18. #43
    Sep 2003
    Originally posted by Mcklain
    Hi,
    Mcklain
    I have tested 3 pairs of 2x512MB RAM. Here is the results:
    1. Corsair XL - max FSB at 2-3-3-6 is 230
    2. Adata Vitesta DDR566 - max FSB at 2.5-4-3-6 is 260
    3. OCZ PC3700 EB - max is 220 no matter what the timing is. Trust me, I have tried most known tweaks already such as lowering HT freq to 3x, increasing vDimm/vCore, lowering multiplier, relaxing timing. The only thing that can help is to run it at 2T. I managed to hit 230 HTT with this. But performance hit is pretty significant here.
    Note that for all three, the only difference component in the system is the RAM itself. Also, Success/Failure is determined by the successful run of all SuperPI, Prime95, 3DMarks, and StressCPU tests.
    Now, any advice will be greatly appreciated on why EB performs so badly on MSI Neo2
  19. #44
    Xtreme Recruit
    Aug 2004
    Sweden
    Im using Ocz 3700EB with MSI K8N Neo2 Platinum.
    3-2-2-10 1T 270fsb 3.2v (ddr booster)
    Ocz likes lots of voltage it seems.
  20. #45
    Jul 2004
    Hey Gascon what are all youre settings on the bios.
    I am running an fx-53 with k8n neo 2 and prime doesnt last more than 3 hours without errors. I am trying to run stock settings on the cpu with 2.5-3-2-9 on the ram with 2.85 v in it. Can you help me?
    I have ocz pc 3700 EB
    Mcklain
  21. #46
    Xtreme Recruit
    Aug 2004
    Sweden
    Max Memclock: 200
    Memory timing: 1T
    Cas (Tcl): 3
    Ras Trcd): 2
    Min Ras (Tras): 10
    Row (Trp): 2
    Aggressive Timing: Disabled
    Dynamic Overclocking: Disabled
    Spread Spectrum: Disabled
    HT Frequency: x3
    Cool'n'Quiet: Disabled
    Cpu Ratio: x9
    Cpu Fsb Frequency: 270
    Agp Frequency: 67
    Cpu Voltage: 1.55
    Memory Voltage: 2.8 (booster at 3.2)
    Agp voltage: Default
    My cpu is a 3500+ @ 3800+
    Raptor on Sata port 3
    I read somewhere that having 1024Mb will get error in Prime95. =/
  22. #47
    Dec 2002
    St-Hyacinthe,Quebec
    same here with my 3700EB
    Xtreme Parson Russell Terrier Breeder
    Core I7 920@ 4Ghz
    Asus P6T
    Adata 3x2gb DDR3-1600
    eVGA 9800 GX2
  23. #48
    OCZ Product Specialist
    Mar 2004
    Best we can figure out on the EB @ 220fsb issue is that there is a power or available current issue on the MSI board. The EB requires lots of juice to work properly and the MSI is appatrently not up to the task in stock form. As you have read from guys that are running the OCZ DDR Booster in their boards, they have no issues at all.
    The EB series was designed before this board came out and works just fine in nearly all boards. I suggest you add a DDR Booster and enjoy killer performance. This may be the only solution sabe for modding the board.
    OCZ Marketing Team
    Email Me Here or Need Technical Support? Go to OCZ Support Forums
