Page 17 of 31 FirstFirst ... 71415161718192027 ... LastLast
Results 401 to 425 of 756
Thread: AMD Newark 3700+ @ 3105.1MHz Air-Cooled
  1. #401
    May 2005
    Camping your spawn :)
    well im tryin right now im at 2760 with 230fsb on a 180 devider
    for some reason at ddr 200 2-2-5-7-16-2 my copm fails horrible on memtest
    I have to have cpc disabled to run it at any speed or hundreds of thousands of errors.
    Is there some kinds of timings specifically for speed premium bh-5 utt?
    I had it at 3.4 and was failing at ddr 200 1-1 with fsb with those timings
    I know this baby can go way higher
    right now im at 1.45 volta idle at 32-34 so i know i have room to go with this setup
    Someone pla help me out with some timings i want 250 1-1 X12 multi maybe 11 multi well see
    until then ima sit right here at 2760
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
  2. #402
    Xtreme Mentor
    Oct 2004
    Have you tested your memory on another system to verify that it can reach 250MHz and beyond?
  3. #403
    May 2005
    well today i tested each module individually and each can hit 240 at 3.2 which is a good starting point for me thats with cpc on also single sticks
    problem is when i put both sticks inthere i have to turn cpc off and set fsb to 235 with multi of 166 which is actually ddr 195
    i know there has to be a setting in bios i have th change in order to ge tthese sticks to run together 1:1 with fsb
    plz help me out here fellas
    -Emo Philips
  4. #404
    Love and Peace!
    Dec 2004
    hiding somewhere!
    i had a LOOOOTTTT of trouble getting both of my ballistix sticks over 210mhz when i first got the newark... forget everything you know about timings, and start over again. especially trc/trfc (8/10 is best for me, higher gives errors, lower gives raid detect)
    also, max async latency and read preamble are very picky for me..
    Got a fan over those memory sticks? No? Well get to it before you kill them
  5. #405
    May 2005
    cool ozzi anyway u can post me what u have so i can try them out and go from there
    I cant seem to get anything stable because of this memory stuffs
    like a screenie of a64 tweaker would be nice
    or maybe a screenshot or bios whichever u want
    so i can get an idea
    right now im 2-2-5-2-8-16-2 drive strength 1
    and not workin
    even with cpc off
    i want 1:1 250 cpc on :0
    actualy right now i would be happy with anything with cpc on and over 200 at this point. im getting errors in everntthing i dop
    cant game or anything
    last night iwads fraggin at 1760 now i cant
    wierd
    i dunno but i hope i can fix this soon
    its killin me
    at 2820 fully loaded it goes to 37 mostly sometim4s hits 38
    at 1.375 110%
    plz help me get this figured out.
    atleast i know someone else had same problem and it was resolved
    so i know im not gonna be throw to the dogs
    as we speak im at 2-2-2-11-13-15 old bh5 timig to see if they work out
    so far priming ok
    better than 5 8 16
    -Emo Philips
  6. #406
    Love and Peace!
    Dec 2004
    hiding somewhere!
    my ballistix like drive strength of 1, and bank interleaving on. i actually get more errors with interleaving off
    and here's my timings for 229mhz on the ballistix.
    to get to 245mhz with 2.8v, i need to drop twr and trtw to 3.
    i have async latency and read preamble on auto, as it seems to work quite well
    also, tref is very picky. mine likes a weird 0776.. when i crank up the speed, somewhere in the 0900's works a bit better, but not much.
    i hope this helps some
    as a side note, i have two single sided bh-5 sticks sitting around, want me to pop them in and take it up to 270mhz or so?
  7. #407
    Oct 2003
    Alpine, TX, USA
    Quote Originally Posted by ozzimark
    Yes plz
    Redline 3D Socket 754 = 40,179
    Retired
  8. #408
    Love and Peace!
    Dec 2004
    hiding somewhere!
    sorry for the delay, i had a few things to take care of. currently pushing 265mhz with 3.2v, trying to tweak the last bit out without bumping the voltage again. i'll get a screen when i max the stuff out
    EDIT!
    here we go. ended up needing 3.3v to make 265mhz stable.. the trick is in the trc and trfc again. i could change most of the other things to whatever i wanted, and it works
  9. #409
    Oct 2004
    Finally got my 3700+ running, for now just trying to find out its max at default voltage. Currently feeling out stability at 2.5GHz.
  10. #410
    May 2005
    i finally switched my bios to 4-15 and now my mem will run higher, just tryin to get errors out of prime now
    best ive done so far is 5 mins @ 230 with 3.2 volts
    im at 230X11 2530 at stock volts as well
    im tryin 1.5-2-2-5-10-12 and some other various things to try stability
    not doin to well so far, im sure some of its prob the psu I set it to 3.3 or 3.4 in bios but it never goes higher than 3.16 is that why most ppl have ddr booster? because nf3 wont let it go higher?
    I hope it will because if not that blows.
    well for now tweaking has to stop because my all in wonmder is starting to record pimp my ride for me so prime will have to wait
    -Emo Philips
  11. #411
    Love and Peace!
    Dec 2004
    hiding somewhere!
    Quote Originally Posted by Philosophy
    you need to being the 3.3v rail up, the vdimm will only go up to ~.15v under what the 3.3v rail is. when i want 3.4v for my ram, i have to bring the 3.3v rail up to 3.6v
  12. #412
    Member
    Dec 2002
    Leics UK
    Are these avalable retail yet?
  13. #413
    Love and Peace!
    Dec 2004
    hiding somewhere!
    i believe there is a member here who ordered one from shentech.com and get it in a while ago
  14. #414
    Mar 2004
    just got my 3700 from shentech. its CABSE 0515UPMW. ive been following this thread pretty much since it started. i finally just went ahead and ordered one up to see what i might get out of it. its gonna be watercooled so im lookin at some decent OC potential....**crossing fingers**. im a regular reader at ocforums, which is where i first heard about this thread. good job on all the work u guys have done so far, keep it up.
  15. #415
    Oct 2003
    Alpine, TX, USA
    Quote Originally Posted by DmatkO
    Let us know how it goes! Oh BTW, to XS!
    PS: Did you pay the $23 shipping fee at Shentech?!
    Retired
  16. #416
    Mar 2004
    yeah, i did pay the shipping, but i didnt have to pay tax. only odd thing about the whole ordeal was where it shipped from. from the tracking directions, the chip came from California .still, as bad as that seems, i cant imagine paying newegg $10.00 to ship a $12.00 fan. i think i would just end myself at that point lol.
  17. #417
    Jun 2005
    Greensboro, NC
    My 3400 from Shentech came out of Pennsylvania, but the company has a NY address. My 24/7 stable OC is 2695 at 1.595v, less than impressive. I can bench and play games at up to 2805 1.65v so far without problems, but can't pass Prime95 above 2695 (23.8 32bit or 24.11 64bit). Temps on air are decent - 38 C peak at 1.595v (SLK-948U + Delta 92mm 3-blade 2800rpm). Any other 3400 results?
    A64 3400+ Newark @ 2805, CABHE 0512 XPCW
    DFI LP nF3 250Gb, 11x255, 504-R1 BIOS
    2x512 Mushkin PC3200 Blue, 1:1, 2-2-2-6
    X800 Pro, WD740GD, OCZ PS 520, Win XP Pro x64
  18. #418
    May 2005
    Romania/Transilvania
    Maybe you should give it more volts (1.65V). I’ve followed this thread right form the beginning and I am waiting more results for 3400+ (3700+ is too expensive for me ).
    P.S. I already have a crappy 3400+ mobile Clawhammer, I don’t need another bad 3400+.
  19. #419
    Oct 2002
    South Suburbs of Chicago
    Hey guys, I saw some place that the Sandies (?) need Drive Strength 3 to run right on the DFI 939 boards. Seems to help a bit on my Newark too. Give it a try to see if your RAM likes that better or not.
  20. #420
    May 2005
    earth......among the the others
    hey guys
    i have been following this thread just for a few hours....
    when i posted to get info about 754 mobile....and after that i saw this one
    its 4 am here i am sleepy as hell but i would like to ask u guys a couple of things
    that "sentech"..i think its correct, ships worldwide......so i was wondering if any of u owners of newark cpu s live in europe and have tryed the services of that company?
    r u aware of any dealer in europe?
    the costum rates can be very high shipping from us...so i was just trying to do things the fast and cheapper way
    i am not changing to 939 right now and i was very well impressed with the results i have seen here
    can someone help me find one of these "babys" near my small and distant Portugal
    i want to join the 3,00mhz 754 club
    thnxs
    STEELBALLZZ - N3RO - MARTAKIS
    ZÉ DO BENCH TEAM
    add a volt or two.....
  21. #421
    Mar 2004
    i finally have put my system together. now comes the interesting part i need some help with. plz take note of my sig to see system specs. a few posts up i posted my 3700 "signature" 1. my 3700 on startup is running at 800mhz, and .950volts. would a bios update fix this?? 2. according to clockgen, i have a max multi of x12, max volts of 1.4. 3. as of right now, i have the system set at a x7 multi, .975v, and 210 htt. the memory is runing 1:1 at 2226. the chip is runing at 1470mhz. iv done a little oc on my old system, but i was hoping to get more in depth with this one. so far, im not lookin to optimistic.
    one last thing i would like to know is what kind of temp monitor people are using. i dont see an option for the dfi board in mbm5. thnx for the help.
    SPECS::
    AMD Newark 3700+ DFI lanparty UT NF3 250GB 1x1GB Mushkin XP PC4000 3-4-3-8 WD Raptor 36 ANTEC TrueControl 550 GiGa 6600gt Lite On CD+R\RW Sony FloPy Kingwin Arctic LiquiD CooLer..((heavily modded by me)) Coolermaster Cent5
  22. #422
    Love and Peace!
    Dec 2004
    hiding somewhere!
    i use smartguardian, check dfi's site for it
    also, when on auto, the dfi board defaults to 4x and 0.9v.. i think i mentioned this in the first post. simply change it to 12x and 1.35v for stock :p
  23. #423
    Mar 2004
    lol...man, i read this thread from front to back about 4 times already. guess i didnt see that part, or was just to giddy with joy to pay close attention. o yeah, i also d/l mbm5 and did a quick little change to the data folder. i swapped it with soundx98 folder, from dfi-street.com. im pretty happy with the setup he had since my 5v line is actually now staying at 5v. it was usually jumping around and would be reading anywhere from 2.38 to an extreme 6.85. thnx alot ozzi for the reply today.
    SPECS::
  24. #424
    Love and Peace!
    Dec 2004
    hiding somewhere!
    ouch!
    haha, well it's good to hear that you're basically set. good luck overclocking it!
    edit: just a random thing i did for kicks. nothing under 2.5x ht link multi seems to work right, and greater than 1.7v for the chipset is weirdness, so i topped out here:
    http://valid.x86-secret.com/show_oc?id=23871
  25. #425
    Jul 2004
    ozzi,what was your's max suicide SS and spi 1mb clocks on AIR ?
    And the ambient temp ?
    All*AIr
    478
    754
    939
