Page 1 of 16 123411 ... LastLast
Results 1 to 25 of 444
Thread: Gunna try some SLI action Today:)
Hybrid View
    Overclocking Guru
    May 2002
    SoCal, USA
    Finally got me a few nVidia 6800 Ultra cards, MSI.
    I'm gunna test them on a couple of Swiftech MCW-50 Tec blocks today.
    Looks like fun, see if I can't get into the Top 20 on the ORB
    OPP
    XS News
    Dec 2003
    North Carolina
    Somehow I think you wont have a problem getting into the top 20 there OPP.
    Look forward to the results as usual.
    Edit: is that the DFI board?
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
    Nov 2004
    Montgomery, AL
    Yeah, somehow I don't think you're going to have any problems getting into the top 20 OPP
    Jan 2005
    Bay Area, CA
    Chunky: it is MSI...
    Opp: If you are trying for 05, you might want to try out the newest driver 76.41 (came out today and looks like it is the fastest for 05 of the bunch)unless u whql only...
    http://downloads.guru3d.com/download.php?det=1022
    Banned
    Jan 2004
    Land of Buckeye
    Good setup buddy,
    Besure to press:
    shift F2(press together) and then alt f3
    and use ati/nv speed up to OC your video card.
    like this you will see under bios.
    Overclocking Guru
    May 2002
    SoCal, USA
    Thanks for the info guys. I still have to build a couple water loops. After that, it's on
    OPP
    Nov 2004
    looking good, what chip you using with that killer setup?
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by mushk1n
    I'll be useing a FX55.
    OPP
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    OPP,
    I think the swifty's will work really well with that...
    TEAR IT UP!!
    MSI board, right? Looks to have GREAT spacing between cards... that's the ONLY place that DFI fell asleep with their NF4 series....
    C
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by charlie
    OPP,
    TEAR IT UP!!
    C
    The DFI have the Same Spacing between slots as the MSI, they both have 1 slot between them.
    OPP
    Overclocking Guru
    May 2002
    SoCal, USA
    Before I fire this thing up, does anybody know were to measure the core voltage on these 6800s?
    OPP
    Banned
    Jul 2003
    West Virginia
    Quote Originally Posted by OPPAINTER
    OPP
    Left side of this resistor (+) and any ground for VGPU. Your voltage will increase once Windbloze loads the drivers so don't start too high. VR-Zone has a nice BIOS mod for an extra .1v also. I got my cards to 1.77 with pencil/BIOS mods.
    Aug 2004
    OPP
    The ASUS is the only board with good spacing, but, we know how well that board does.
    The VREG is the same as the AGP versions. Shamino has the info right here:
    http://www.vr-zone.com/index.cgi?i=926&s=1
    And the memory mod:
    http://www.vr-zone.com/index.cgi?i=1622&s=1
    MSI K8N Diamond
    2 x 6800 Ultra PCI-E
    Innovatek NV40
    AMD 64 3200+
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by dwwalker14335
    And the memory mod:
    I used the VRZone info for modding, but on the VRZone picture the measure point doesn't exsist on my card, my card looks different.
    I have measure two places, one reads 1.58V and the other reads 1.1V, neither sound right to me.
    OPP
    Aug 2004
    OPP
    When I measured mine, I used the one that is directly in line with ic's 5&6, right to the left on your pic. I got around 1.42 V.
    MSI K8N Diamond
    Innovatek NV40
    AMD 64 3200+
    Oct 2002
    Field of Battle
    OPP
    I guess the mcw50-t are just narrower than I remember... on my DFI-SLI, with default ASUS coolers there was nearly NO space!!
    C
    May 2003
    Zaragoza (Spain)
    OPP
    Are you sure on that boss? sure it's just one slot on both but i think MSI has some more milimeters to play, I say this because one of my MCW50-T's does not fit between the cards, unless I'm doing something wrong.
    Thx god for the dryice and the liquid nitrogen.
    HeatWare
    eBay
  18. #18
    FROG
    Guest
    OPP,
    TEAR IT UP!!
    C
    But the MSI Plat. and Diamond are the same as the DFI.. I have a Diamond and use its SLI bridge on DFI at the moment as I am modding a DFI Ultra into a SLI.
    OP are 80Watt pelts gona be enough?
  19. #19
    Oct 2002
    Field of Battle
    Quote Originally Posted by FROG
    Well, I think we'll find out soon
    I think it'll be FINE
  20. #20
    Overclocking Guru
    May 2002
    SoCal, USA
    The coolers are colder then straight water so thats why I'm useing them, they will be fine untill my Cascade is ready.
    I'm waiting for JB weld to dry on my ehiem for my second loop. I thought I had more water stuff in my garage but my Pumps and Rads suck
    Won't be able to play until tomorrow, I have one card now. It reads 10c.
    OPP
  21. #21
    Nov 2002
    Nice OPP. So what's going to be powering those TECs? The 17X watters too or something else?
    edit: Cross posted Here is the vcore mod for 6800U with checkpoint:
    http://www.vr-zone.com/?i=926&s=1
  22. #22
    Overclocking Guru
    May 2002
    SoCal, USA
    Quote Originally Posted by texuspete00
    These are 80W pelts, I have a 25amp supply here that runs at 13.7V, my Radio Shack speacil
    OPP
  23. #23
    Jun 2002
    Ohio, U.S.A.
    This is gonna be good! You got a taste of SLI from Equito now you want some of your own do you?!
    Be sure to pop into this thread with your results when you finish
    *** The XS SLI 3DMark 05 and 03 Top 10 List ***
  24. #24
    Aug 2004
    Do you wanna give me one?
    Good luck with those cards
  25. #25
    Oct 2003
    Terra
    OPP , maybe u can do something with this
    Its my XFX 6800GT
    CPU : Intel Core 2 Extreme QX9650
    MB : Asus P5E X38 Rampage bios
    RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
    VGA : Sapphire 4870
    Power : Antec Quattro 850w
    Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
    DVD : Samsungs DVDwriter Sata + Liteon DVD
    Sound : Creative XFI Xtrememusic
    Cooling : D-Tek Fusion + D-Tek Fusion GFX
    Monitor : Samsung 226BW
    Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
