Awesome, Sniper but.............
I think your Gflops is a bit low. Usually on my setup I get low gflops if Vcore is a tad low, or some other process takes up to much cpu time.
Sig always changing.
I actually saw 69 gflops last night when trying for 4788, but it stopped with error after the 5 pass.
Have to ask Sniper,
You don't seem too keen on SS. I notice you talk from past experience. What is your dislike of it (I haven't been around for a while)? Also, is this "bclk mod" easy to do (I'm ok with a soldering iron)? What does it involve?
Not to try to get ahead of you of course![]()
The bclk mod is for "old" GB X58 non A mb's wich is limited to max 103 pci bus without the mod.
I'v had 2 SS back in the good old Athlon XP/P4 days, a VapoChill and a Prom. Both worked ok for a while I guess, but there where several disadvanteges for me:
- They produce more nois than my water cooling setups.
- There's allways a risk of condensation.
- Greasy sockets, cpu's and mb's.
The last one is the worst. I like to test out different cpu's and mb's all the time, and with a SS all your parts will be greasy and full of goofy stuff.
You also need to refill and tune a SS to match your cpu's power draw for max performance.
I'm not saying a SS is bad, just not for me and my use.
Ohh, and please do![]()
CPU: Core i7-2600K@4.8Ghz Mobo: Asus Sabertooth P67 Case: Corsair 700D w/ 800D window
CPU Cooler: Corsair H70 w/ 2 GTs AP-15 GPU: 2xGigabyte GTX 670 WindForce OC SLI
RAM: 2x8GB G.Skill Ripjaws PSU: Corsair AX850W Sound card: Asus Xonar DX + Fiio E9
HDD: Crucial M4 128GB + 4TB HDD Display: 3x30" Dell UltraSharp 3007WFP-HC
Speakers: Logitech Z-5500 Headphone: Sennheiser HD650
Very nice!
Is that with VDroop On or Off?
Insane, huh?
I think you lose up to 10 GFlops or so with Nehalem... But with Gulftown it's a ton more it seems, lol.
► ASUS P8P67 Deluxe (BIOS 1305)
► 2600K @4.5GHz 1.27v , 1 hour Prime
► Silver Arrow , push/pull
► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
► GTX560 GB OC @910/2400 0.987v
► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
► CM Storm Scout + Corsair HX 1000W
► EVGA SR-2 , A50
► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
► Megahalem + Silver Arrow , push/pull
► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
► XFX GTX 295 @650/1200/1402
► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
► SilverStone Fortress FT01 + Corsair AX 1200W
► EVGA SR-2 , A50
Nice mhz and gflops SteveRo![]()
Thanks Sniper, I wonder how much higher I cuold push vcore w/o doing damage.
I have not dealt with returning CPU's to Tigerdirect but I have returned a 920 to Compusa whom they own. I bought a 920 that took way to much vcore to hardly hit 4.2GHz, brought it back to Compusa and they let me swap it for a new one without asking a single question.
I suspect the retailers don't care because they return them to Intel and probably charge back Intel for the full cost. Intel probably test the chips and sells the working ones to OEM's in batches.
I actually returned a 975 to them not to long ago and the staff were all pissed and claiming that the Classified board was my problem, end result: they took it and credited the cc for a full refund.
You got more guts than I taking your 980x pass 1.50v, I can't do it.
Not wanting to bury this chip so soon. jajajaja
Good runs!!!!
Asus RIVE Bios 2003
3930k 4.5 ghz @1.29v
G-SKILLS 32gig ddr-1600 ripjaws Z
Enermax Evo Galaxy 1250W
2x EVGA GTX 480 Superclocked SLI @ 900/1800/2000
X-Fi Fatal1ty Titanium PCI-E
4 x crucial Realssd C300 256 Raid 0
Areca 1880i
Seagate 1TB
CM HAF 932
On water:
HK 3.0
2x MCP655
FESER X360
Blackice GTX 480
DD-GTX 480 VGA blocks
DD Reservoir
Windows 7 64bit
Dell 3008WFP 30"
Help Save Lives Join World Community Grid!
4.7 @ just 1.44V - very nice! Looks like a great chip!![]()
I just noticed you have my entry at pcie 115, for the 4.7 run I had pcie at auto.
Please update, thanks!
Also - question - how safe is it to continue to bench 32nm at 1.44v?
Is there any real data on 32nm safe bench voltages?
By "bench" I mean usage level of 1-2 hours here and there not 24/7.
