Page 13 of 51 FirstFirst ... 31011121314151623 ... LastLast
Results 301 to 325 of 1265
Thread: AMD Shanghai/Deneb Review Thread
  1. #301
    Jun 2008
    yet wprime says 3.074g weirdly.
  2. #302
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    wprime is often wrong I will update my cpuz right away, it is still the same hdd as during G|C Same bios also - need to update I think. Hopefully that 32m passes, I'll do it with new CPUz
    €dit: 32m with new CPUz
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
  3. #303
    Sep 2006
    Croatia
    Oh come on SoF, don't do that, you had to leave some numbers in the middle of test, then it would be a teaser, this is just plain cruel
    If this ~ 4GHz score is on air cooling and without ACC, it's really quite impressive
    Waiting for some more tests, hopefully without black coloured squares
  4. #304
    Xtreme Mentor
    Nov 2005
    Devon
    Looks like my GA 790FX-DQ6 SB600 based board will love this new 940BE
    SoF can you say what type of air cooling are you using?
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  5. #305
    Xtreme Cruncher
    Jun 2006
    Thanks for that screeny SoF,is the Northbridge clock 2Ghz by default(NB multi 10)? We saw 1.8Ghz HTT def. clock but didn't see what NB clocks are default for 940BE.
  6. #306
    Jan 2005
    East Blue
    it's simple scythe mugen laying on it with 120 and 92mm fan full speed on 2 sides without additional weight. wprime1024m 1.32V 46°C load
    sorry but I have to keep performance covered for now This chip is running real cold
  7. #307
    Xtreme Cruncher
    Apr 2008
    Ohio
    Quote Originally Posted by SoF View Post
    man that's impressive..
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
  8. #308
    Jun 2008
    2 fans on that mugen and at 3300 with only 1.320 with default of 1.35....46 celcius seems pretty high compared to what we've been hearing of running like 3.8g 1.5 volts and only 37 celcius or something....
  9. #309
    Jan 2005
    East Blue
    I never have good cooling values on air it is not mounted properly as I will go DICE as soon as possible. but maybe takes me until next week end
  10. #310
    Jun 2008
    alright that makes more sense, the other guy was using a DuoOrb cpu cooler which I assume isn't far off in cooling performance.
  11. #311
    Jan 2005
    Is every 940 Phenom2 Black Editions? .. or is there some normal ones too?
    Nothing interesting here.
  12. #312
    Jun 2008
    can't wait for iocedmyself to show up again with game fps numbers.
    SoF can you test max air northbridge clock?
    and how far you can keep high nb with a high core clock?
    faior- All 940's are black edition just like the 9950's were all BE.
  13. #313
    Jan 2005
    Quote Originally Posted by Caveman787 View Post
    Thanks a lot mate! Didnt know all 9950 were BE though, damn if Id knew that I would have bought it elsewhere for cheaper, darn. Not every webshop tells if its BE or not :S
  14. #314
    Jan 2005
    East Blue
    I tested nb with 2.400 for prime with 3600mhz cpu and 2.200 mhz nb / 4020 mhz cpu some minutes ago.
  15. #315
    Jun 2008
    Sweet I'm gonna assume they both worked.
    I have a feeling we may see 2,600 mhz northbride with good clocks this time.
    Which combined with a 2,000mhz htt will yield some nice performance.
  16. #316
    Xtreme Cruncher
    Jun 2006
    2.200 mhz nb / 4020 mhz cpu ,wow . Was it stable?(i presume it was )
    So by your experience ,NB has some hefty headroom which is great since it can net ~5% speed gain in many cases versus default/stock NB clock..
  17. #317
    Jan 2007
    Btw yes am benching at 3ghz with 2ghz NB. And sorry for absence but OS hard disk died had to reinstall everything
    SiSoftware Sandra
    Benchmark Results
    Multi-Media Int x16 iSSE2 : 170280iit/s
    Multi-Media Float x8 iSSE2 : 223516fit/s
    Results Interpretation : Higher index values are better.
    Performance vs. Speed
    Multi-Media Int x16 iSSE2 : 56.61iit/s/MHz
    Multi-Media Float x8 iSSE2 : 74.31fit/s/MHz
    Performance Test Status
    Run ID : AMD Phenom(tm) II X4 940 Processor (Quad-Core, 3.01GHz, 4x 512kB L2, 6MB L3)
    Platform Compliance : Win64 x64
    NUMA Support : No
    SMP (Multi-Processor) Benchmark : No
    Total Test Threads : 4
    Multi-Core Test : Yes
    Cores per Processor : 4
    SMT (Multi-Threaded) Benchmark : No
    Processor Affinity : P0C0T0 P0C1T0 P0C2T0 P0C3T0
    System Timer : 14.32MHz
    Rendered Image Size : 640x480
    Processor
    Model : AMD Phenom(tm) II X4 940 Processor
    Speed : 3.01GHz
    Model Number : 9024
    Cores per Processor : 4 Unit(s)
    Type : Quad-Core
    L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size
    L3 On-board Cache : 6MB, ECC, Synchronous, Write-Back, 48-way, 64 byte line size, 4 threads sharing
    Features
    SSE Technology : Yes
    SSE2 Technology : Yes
    SSE3 Technology : Yes
    Supplemental SSE3 Technology : No
    SSE4.1 Technology : No
    SSE4.2 Technology : No
    EMMX - Extended MMX Technology : Yes
    SSE4A Technology : Yes
    HTT - Hyper-Threading Technology : No
    Performance Tips
    Notice 5008 : To change benchmarks, click Options.
    Notice 5004 : Synthetic benchmark. May not tally with 'real-life' performance.
    Notice 5006 : Only compare the results with ones obtained using the same version!
    Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
  18. #318
    Jan 2005
    East Blue
    no I only tested 4020 with 1m - can't get it stable, think it needs ACC (what does not work yet for me, waiting what others say about deneb and acc). shortly did 4080 1m but crashed during saving
  19. #319
    Jan 2007
    SiSoftware Sandra
    Benchmark Results
    Dhrystone ALU : 41008MIPS
    Whetstone iSSE3 : 34658MFLOPS
    Dhrystone ALU : 13.63MIPS/MHz
    Whetstone iSSE3 : 11.52MFLOPS/MHz
    NUMA Support : No
    Number of Runs : 64000 / 640
    Processor
    Speed : 3.01GHz
    Model Number : 9024
    Type : Quad-Core
    Features
    Performance Tips
  20. #320
    Jan 2007
    SiSoftware Sandra
    Benchmark Results
    Cache/Memory Bandwidth : 40.74GB/s
    Speed Factor : 36.50
    Results Interpretation : Lower index values are better.
    Cache/Memory Bandwidth : 13.87MB/s/MHz
    Float SSE2 Cache/Memory Results Breakdown
    Data Item Size : 16bytes
    Buffering Used : No
    Offset Displacement Used : Yes
    Detailed Benchmark Results
    2kB Blocks : 152.92GB/s
    4kB Blocks : 190.88GB/s
    8kB Blocks : 195.38GB/s
    16kB Blocks : 198.55GB/s
    32kB Blocks : 210.45GB/s
    64kB Blocks : 185.46GB/s
    128kB Blocks : 169.42GB/s
    256kB Blocks : 151.32GB/s
    512kB Blocks : 99.10GB/s
    1MB Blocks : 84.62GB/s
    4MB Blocks : 35.76GB/s
    16MB Blocks : 7.52GB/s
    64MB Blocks : 5.77GB/s
    256MB Blocks : 5.77GB/s
    1GB Blocks : 5.83GB/s
    Run ID : AMD Phenom(tm) II X4 940 Processor (Quad-Core, 3.01GHz, 4x 512kB L2, 6MB L3); AMD ??? (9600); 1x 4GB DDR2 PC2-17200 (5.0-5-4-8)
    NUMA Support : No
    Page Size : 4kB
    Use Large Memory Pages : No
    Processor
    Speed : 3.01GHz
    Model Number : 9024
    Type : Quad-Core
    Features
    Chipset 1
    Model : ASUS ??? (9600)
    Revision : A1
    Front Side Bus Speed : 1x 201MHz (201MHz)
    In/Out Width : 16-bit / 16-bit
    Maximum Bus Bandwidth : 804MB/s
    Chipset 2
    Model : AMD (Family 10h) Athlon64/Opteron/Sempron HyperTransport Technology Configuration
    Revision : A1
    Front Side Bus Speed : 2x 2.01GHz (4.02GHz)
    Maximum Bus Bandwidth : 15.70GB/s
    Logical/Chipset 2 Memory Banks
    Bank 0 : 2GB DDR2 5.0-5-4-8 CR3
    Bank 1 : 2GB DDR2 5.0-5-4-8 CR3
    Channels : 1
    Bank Interleave : 2-way
    Memory Bus Speed : 2x 536MHz (1.07GHz)
    Multiplier : 8/3x
    Width : 128-bit
    Memory Controller in Processor : Yes
    Cores per Memory Controller : 4 Unit(s)
    Maximum Memory Bus Bandwidth : 16.75GB/s
    Performance Tips
    Tip 11 : Use the 'Switch Chart Type' button to switch between Detailed and Combined charts.
    Warning 5010 : Cannot use Large Memory Pages due to lack of privileges.
  21. #321
    Jan 2007
    SiSoftware Sandra
    Benchmark Results
    Int Buff'd iSSE2 Memory Bandwidth : 11.18GB/s
    Float Buff'd iSSE2 Memory Bandwidth : 11.18GB/s
    Int Buff'd iSSE2 Memory Bandwidth : 10.68MB/s/MHz
    Float Buff'd iSSE2 Memory Bandwidth : 10.68MB/s/MHz
    Assignment : 10.93GB/s
    Scaling : 10.89GB/s
    Addition : 11.49GB/s
    Triad : 11.42GB/s
    Buffering Used : Yes
    Bandwidth Efficiency : 66.77%
    Assignment : 10.94GB/s
    Scaling : 10.86GB/s
    Triad : 11.44GB/s
    Bandwidth Efficiency : 66.76%
    Run ID : AMD ??? (9600); 1x 4GB DDR2 PC2-17200 (5.0-5-4-8)
    Memory Used by Test : 1.75GB
    NUMA Support : No
    Page Size : 4kB
    Features
    Chipset 1
    Revision : A1
    Chipset 2
    Revision : A1
    Channels : 1
    Multiplier : 8/3x
    Width : 128-bit
    Performance Tips
  22. #322
    Jan 2007
    SiSoftware Sandra
    Benchmark Results
    Memory (Random Access) Latency : 89ns
    Speed Factor : 83.40
    Memory (Random Access) Latency : 0.08ns/MHz
    1kB Range : 3clocks / 1ns
    4kB Range : 3clocks / 1ns
    16kB Range : 3clocks / 1ns
    64kB Range : 3clocks / 1ns
    256kB Range : 16clocks / 5ns
    1MB Range : 56clocks / 19ns
    4MB Range : 86clocks / 29ns
    16MB Range : 248clocks / 83ns
    64MB Range : 266clocks / 89ns
    Memory Access : Random
    Processor
    Speed : 3.01GHz
    Model Number : 9024
    Type : Quad-Core
    Chipset 1
    Revision : A1
    Chipset 2
    Revision : A1
    Channels : 1
    Multiplier : 8/3x
    Width : 128-bit
  23. #323
    Jan 2007
    SiSoftware Sandra
    Benchmark Results
    Memory (Linear Access) Latency : 14ns
    Speed Factor : 13.90
    Memory (Linear Access) Latency : 0.01ns/MHz
    256kB Range : 10clocks / 3ns
    1MB Range : 22clocks / 7ns
    4MB Range : 25clocks / 8ns
    16MB Range : 44clocks / 15ns
    64MB Range : 43clocks / 14ns
    Memory Access : Linear
    Processor
    Speed : 3.01GHz
    Model Number : 9024
    Type : Quad-Core
    Chipset 1
    Revision : A1
    Chipset 2
    Revision : A1
    Channels : 1
    Multiplier : 8/3x
    Width : 128-bit
  24. #324
    Jan 2005
    East Blue
    do you know the edit function? by the way I don't like sandra benches at all
    €dit: finally I have 4 gig 32m running but 4.1 crashes 1m ^^ still no good ram clock even with current bios (P05).
  25. #325
    Jan 2007
    heh yeah i know the edit function but i hate seein those single posts that take an entire page. Others asked for sandra benches so i figured i may as well
