Page 13 of 29 FirstFirst ... 31011121314151623 ... LastLast
Results 301 to 325 of 705
Thread: 700mhz wall on HD4850 is smashed.
  1. #301
    May 2003
    Hopatcong, NJ
    w1zzard says that CCC is locked from the driver side, not a setting in the BIOS if you read the comments on the Diamond 4870 Black Edition news article @ TPU. You never know though, maybe it is the bios
    'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
    'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
    'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
    Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
    HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
  2. #302
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Quote Originally Posted by gurusan View Post
    highest core i got to was 920mhz on 1.48v 100% artifact free. So was 910 on 1.45v. Currently back to jsut a basically stock bios flash though (1.2v 750/1100).
    Can you send me your bios, that you use to get 750mhz stable, thanks.
  3. #303
    Aug 2006
    Oxford, UK
    Here it is. You might want to play with the fan settings as I haven't touched those in awhile since I'm now on watercooling
    http://rapidshare.com/files/12614046...table.rom.html
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
  4. #304
    Dec 2007
    can someone of those with 900mhz and a 4ghz quad do a 3dmark06?
    thats about the power of my next rig :P
  5. #305
    Jun 2008
    Quote Originally Posted by Miwo View Post
    The limit of overdrive's maximum overclock is actually saved in the BIOS. However, the section in it is protected. You can change the value, but the check notices and completely deactivates overdrive, then. Now a vendor with access to the BIOS' source code can of course set this value to anything they like. Selling that as a stunning feature is immoral, to say the least. I hope they get in trouble with ATI for that.
  6. #306
    Xtreme Legend
    Jan 2003
    Stuttgart, Germany
    please read again: http://forums.techpowerup.com/showpo...9&postcount=33
    http://forums.techpowerup.com/showpo...0&postcount=43
    bios signing process, manufacturers cant just go crazy on settings
  7. #307
    Aug 2006
    Oxford, UK
    that's super lame!
  8. #308
    Jun 2008
    My winflash2012 will not start.... When I click on it will run in my process list... but I can not see the program on my screen...
    Do I need something to get it working, I need to flash my 4850 card with something, its broken right now, so all help would be nice...
    I need to learn how to flash with a floppy and how to do it and with what program, or need to get winflash2012 to get up on my screen...
    I have a PCI card that I am running on now (nvidia) And I have my PCI-E ATI 4850 card in the PCI-e slot..
    Any help is welcome, if u are going to answer something else that is no good or helful for me, the dont answer at all.
    Thanks.
    How to use atiflash360....
    Do I use it in dos or what? need big help with this
    Last edited by splatch; 06-30-2008 at 01:42 PM. Reason: Add a question for "atiflash360"
  9. #309
    Oct 2007
    power circuit heat
    this is how my card looks now:
    +there is a 80 fan blowing to the card.
    the problem is, that the power circuit is still 80+ °C under heavy load (fur opengl).
    I think it is too hot
    how are you cooling it?
    Gigabyte P35-DQ6
    Intel Quad Core Q6600 @ 3.8 Ghz (1,36V) + D-tek Fuzion
    2*2Gb Super Talent DDR2
    Sapphire HD4870 512 MB
    RAID0 (3x HDD) + backup WD My Book
    Chieftec 750W
  10. #310
    Jan 2006
    just wondering. whats the MAX voltage the bios will allow you to change it to. 1.21? i know you can put what ever number but im sure theres some kind of cut off where it doesnt do anything anymore.
    Asus p5n-e sli
    E6300 stock heatsink
    2 x 1 ddr667 supertalent 5-5-5-13 2.1
    X1800xt 256mb
    Enermax liberty 620
  11. #311
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    Quote Originally Posted by tvdang7 View Post
    right around there, don't count on getting voltage from a bios. you need a mod to go higher.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
  12. #312
    Feb 2007
    what is the least amount of voltage that bios can give you for 2d? just wondering cause if i do the hard vmod, then that increases both 2d and 3d clocks, and while i'm in 2d, that just wastes power. so if i lower 2d voltage to maximum minimum and raise 3d to max, and then do the hardmod, i get better performance in 3d, but less wasted power in 2d.
  13. #313
    Aug 2007
    Quote Originally Posted by Boogerlad View Post
    That is my conclusion as well, but I haven't tested yet.
    ES Q9550 E0 @ 4.0GHz (471x8.5) 1.256v
    TR-Ultra-120-X, 115CFM 120mm fan
    Maximus II Formula @ 1884MHz FSB
    Ballistix DDR2-800 (4x1GB) 1132MHz 5-5-5-5-15 4-55-8-14-11-3-8-5-4-2T
    eVGA GTX 280 @ 702c/1404s/1260m (1.175v)
    Auzentech XPlosion DTS-Interactive Vantage 'X'-6,727
    300GB Velociraptor, PC P&C 750W
    (3)120mm, (2)90mm, (1)250mm case fans in TT Armor
    27.5" LCD/Z-5500-office, 95" 720P projector/7.1ch-living room
    Logitech Driving Force Pro-Microsim Racing Pod
  14. #314
    Aug 2006
    Oxford, UK
    .94v is the lowest that works via the bios
  15. #315
    Oct 2007
    pls help. I can't modify any bios. When I save it with RBE, and the load, to check it, there are only "---" at every voltage.
    what can be the problem?
    Gigabyte P35-DQ6
    Chieftec 750W
  16. #316
    Dec 2007
    RBE bug. Go in Control Pannel -> Regional Options and switch standards to English(UK).
  17. #317
    Feb 2007
    Thanks!
  18. #318
    Aug 2004
    The Netherlands
    If I recall someone posted a picture of a HD48xx card with extra caps on the back, but i can't seem to find it. Does someone have a link for me please? Thanx!
    Proc: Q9650 9x496 @ 1.440v batch L844B703
    Ram: 2x2GB OCZFlexII PC-9200 4:5 1240MHz 6-6-6-18 @ 2.12v
    Mobo: Gigabyte EP45-UD3P rev 1.0 - bios F9b
    Video: 2x Palit Dual Sonic HD4870 1GB in CF (840/4400)
    PSU: OCZ PowerStream 520W + Thermaltake VGA 450W
    HDD: 3x250Gb Barracuda 7.10 SATA2 Raid0 (ICHR10) 2x200Gb Barracuda 7.10 SATA2 Raid1 (ICHR10)
    Audio: Audigy 4
    Case: Dual Coolermaster Stacker; one for system rig and one for watercooling loop and cooling
    [SIGPIC][/SIGPIC]
  19. #319
    Jun 2006
    COLORADOOOOO
    i have added only 2 caps to the back (2.5v uf825).. i shall finish doing caps sometime soon.. freaking moving and then going to lake powell on the 7th.. so i am SOOOOOO busy..... i will for sure post pictures of the mods when i am done..
  20. #320
    Aug 2006
    Oxford, UK
    What sort of caps? I have a bag of Sanyo WG 16v 1500uF caps that I used on my creative...XFI
  21. #321
    May 2003
    Hopatcong, NJ
    I took a bunch of pictures of the caps and will try to list all of the ratings if I have time when I get home from work
  22. #322
    Jun 2006
    COLORADOOOOO
  23. #323
    Oct 2007
    Quote Originally Posted by albon View Post
    thx, it works.
    can I set any voltage between 0,94-1,263V? or is there any minimal step?
    Gigabyte P35-DQ6
    Chieftec 750W
  24. #324
    May 2003
    Hopatcong, NJ
    Quote Originally Posted by JamesBong420 View Post
    Nice, the United Chemicon PSAs are supposed to be one of the best caps to use for replacement/modding on power sections due to Low ESR. Panasonic FMs are also widely available and cheap to boot that should be great replacements. I may try to add a few in the back.
    I think the largest cap on the 4850 was a 16v 1000uF but I have to doublecheck. The black one or the green one, i dont remember
    bah if I order from digikey i probably wont get them until after the holiday
  25. #325
    Jun 2008
    If...If I want to use it on my Asus card, is that allright to use ur bios settings?
    Can I download it and flash my card with it?
