Results 301 to 325 of 997
Thread: ATI 3850/3870 Voltmod thread
Threaded View
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Updated:
    Tested by multiple users and the mods work fine.
    Mods are carried out at your own risk. I will not take responsibility for any voltmods gone wrong. No-ones forcing you to mod your cards and invalidate your warranties.
    RAM mod: 80K or 100K trimmer connected between the points marked in blue. Some cards appear to have slightly higher default voltage. If so, I recommend using the higher value of trimmer (ie...100K).
    Thanks to (in no particular order)
    Rumon, Miwo, largon, Kyky, pinto, pitya
    optional core voltmod points (thanks to Largon)
    you sigged that?
    why?
    ______
Tags for this Thread
