Page 13 of 55 FirstFirst ... 31011121314151623 ... LastLast
Results 301 to 325 of 1359
Thread: Retail Abit IN9 32X-MAX - Pictures, observations and testing...
  1. #301
    Jan 2007
    Mesa, AZ
    Quote Originally Posted by mark0326
    First post, here goes...
    I'm on the verge of buying my first Core 2 Duo MB - but I can't decide which.
    I keep returning to this Abit board, I hear some glowing reports and also some problems but what's stopping me making a purchase is being unclear whether the problems 'can' and 'will' be fixed with a BIOS update or not.
    PS/2 / USB issue and SATA RAID being the main issues to me and I'm looking for quality over absolute overclockability.
    I currently have an over-clocked ASUS board that will never re-boot, have to turn off, wait 15 seconds then turn on again - not prepared to pay £220 for another board with problems that can't be fixed in time. Thanks.
    Well, speaking only from what I have been reading since I dont have mine yet, if you are hell bent on building a C2D machine and must have SLI, then look no further than this. At this moment, this is, from what I am reading, the most trouble free board. WIll the problems get fixed with BIOS later on? Who knows, but I will have mine ordered in a few days!
    The Hulk: "Hulk smash!"
    MoBo: Evga 780i
    CPU: Intel Core2Extreme X6800 (L631A669)
    Heat Sink / Fan: Tuniq Tower 120
    Mem: Corsair Domnianator 6400C4D (2x1024MB)
    Video: BFG 8800GTX OC2 x1 (other card went bad and is going to be RMA'd)
    HDD: Seagate Barracuda 7200.10 320GB SATA
    Sound: On board
    Net: On board
    PSU: CoolerMaster 850W SLI
    Case: CoolerMaster Stacker 830 Nvidia Edition
    OS: Microsoft XP SP2
  2. #302
    Xtreme Mentor
    Sep 2006
    Quote Originally Posted by Ghostwind
    What exactly is the multi locked at on the IN9; 10,11 ?
    It would be locked at the default multi of the ship you are running.
  3. #303
    Jan 2007
    Quote Originally Posted by Skrips
    yeah i agree wth that too, with a bios update, everytin could be fixed up easily. Other than the heatsink PWM overheat problem, this board is near to perfect. I dont own the board, but if you just read out the posts here, youll find out that its good to go.
    An Untold prophecy rises - Welcome to the new empire!
  4. #304
    Corsair Rep
    Apr 2004
    Well, if I am checking the Vcore at the right point, I have found my issue. If I clear CMOS, bios shows, 1.325v Vcore. The point illustrated in the pic gives 1.27v. If I set manually to 1.55v Vcore (or any value in between 1.325v and 1.55v) and measure again, there is no change.
    So my question, is; Is this leg illustrated on the 5th PWM the correct check point for Vcore?
    Thanks.
Name:	Check Point 2.JPG
ID:	55218   Click image for larger version.
Name:	Check Point.JPG
    Yes, Yellowbeard, a tall rough man with a big yellow beard
  5. #305
    Jan 2007
    Quote Originally Posted by jer1cho
    Thanks, I've pretty much made my mind up ... but at just over £700 for MB, RAM and CPU it's a big investment that I want to get right first time!
  6. #306
    Sep 2003
    Edinburgh - UK
    See the red circles above the tape measure, these are the actual vcore voltages where I measure them.
  7. #307
    Corsair Rep
    Apr 2004
    Man I feel dumb as my brain is tired. Did you mean to attach a pic or am I just missing it?
  8. #308
    Xtreme 3DTeam Member
    Dec 2006
    UK
    Dude i`ve been running this board for a couple of weeks no problems at all, USB/PS2 issue easily worked around, can`t comment on SATA, don`t run it.
    Currently running 7900GTO`s SLI problem free, not hugely oc`ed yet @3038mhz, still finding my way on C2D, but so far rock steady. Benching on this board, in just one week i`ve gone from 733 on HWBOT rankings to 134. Money well spent as far as i`m concerned.
  9. #309
    Jan 2007
    IN9/NVidia drivers and domains?
    Great thread! I'm having a bit of a bizarre issue which maybe some can shed some light on...
    I've assembled all the components and gotten XP to install, patch and install drivers sever times.... Why? 'Cause when I join it to my domain it seems to hose a few .com services, kill windows installer and the event viewer goes from being a nice, quiet peaceful place to being filled with red and yellow entires.
    Any thoughts? I have Vista as well but am not quite ready to migrate.
  10. #310
    Corsair Rep
    Apr 2004
    Thanks JB, for some odd reason the first few times I viewed the page, the pic did not load. I checked it and Vcore is adjusting properly so, I have not found my issue.
  11. #311
    Sep 2003
    Edinburgh - UK
    Quote Originally Posted by Yellowbeard
    What is this issue you speak of yellowbeard?
  12. #312
    Corsair Rep
    Apr 2004
    In general, my board will not clock 2 different CPUs, both known to clock well on other boards. So far, it won't do even Memtest, much less Orthos stable at anything above about 300 FSB, even at 1.5v+ on Vcore. It's odd. I've changed CPUs and PSUs and every single piece of hardware with known working gear and I'm on water in room about 14c-15c ambient.
    As an example, my 6300 will boot at 500FSB bus and is semi stable at 475+ on another board. But, on the IN9, I cannot get it stable at all. My PC6600 will not pass Orthos Prime at default settings.
  13. #313
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    does this mean it won't get corsair certification? Man I was interested in this board too. Looks like immature bios.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  14. #314
    Corsair Rep
    Apr 2004
    So far the memory works fine in both linked and unlinked. I finally got a formula that works. I MAXed every voltage except Vcore and Vdimm which are 1.55v and 2.4v respectively. I am Priming at 389 x 8 right now, 1hr+. If this proves to be stable, I'll slowly work the voltages back down and see what I get. I've never had to max all voltages to get an OC like this.
  15. #315
    Aug 2006
    Salem, Oregon
    don't reboot, LOL
    For some reason on one boot all your settings will be stable and prime through, reboot, same settings unstable. Weird. I have had to drop my FSB to 378 to resolve this issue, multiple reboots, stable each time.
    vcore 1.25 E6600 L630BXXX
    Vdimm 1.9 Corsair Pc6400C5
    all other voltages are as set by the bios
    400 FSB for me was rock solid, 12 hour prime runs, reboot, and it is unstable, reboot again, and it was stable. Got tired of that, and have dropped down to this to have it 24/7 stable.
    i hope this is a bios instability, not the board, as this would be frustrating. Will give abit some time as this board has only been retail in USA for about a week.
    Good luck Yellowbeard, hope you can get this puppy running right, and give us some good pointers.
    Q6600 @ 3.6, cheap water cooling, and crunching 24/7
  16. #316
    Nov 2005
    Mansfield TX
    The most disturbing thing about this board is all these comments about a possible bios immaturity, chipset bugs, etc., because these are the things I thought Abit was working hard to eliminate. I thought this was the reason we had to wait two months after the intial 680i boards were released for abit to put their spin on the Nvidia reference design & produce a hell of a board. I was not expecting to have to wait on a bios release for my sytems to be stable and somewhat problem free. Very disturbing.........
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
  17. #317
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    Its the current trend. We have ourselves to blame for falling into these kinds of hyped up marketing.
    Palit 4870x2
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  18. #318
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Quote Originally Posted by linflas
    don't reboot, LOL
    Hmmmm........ASUS Striker Extreme does the EXACT SAME.....I definitely think it's 680i's problem.....Three motherboard manufactures with the EXACT SAME problem using the EXACT SAME chip.....At least they design different and use different bios.....BUT the problems are EXACT THE SAME....
    INTEL PWA FOR EVER
    Dr. Who my arss...
  19. #319
    Jan 2007
    Mesa, AZ
    Quote Originally Posted by hipro5
    So, the question is this: Is it fixable through BIOS revisions, or is it just simply a flawed chipset, just like the ill fated Ganite Bay? Time will tell on that one, IMO.
    MoBo: Evga 780i
    Sound: On board
    Net: On board
  20. #320
    Aug 2006
    Salem, Oregon
    I never had this problem on the evga 680i, it either worked or it did not.
    the reason I got rid of the EVGA was that it would be the best board I have ever had for 3 weeks, then just blow up, and some times take ram with it.
    I have my 3rd evga sitting under my desk right now.
  21. #321
    Jan 2007
    holy thats extreme man! the third one already! i wouldnt have purchased the second one...lol gl guys and if u find a solution to this prob, just let us know thanks
  22. #322
    Sep 2006
    Long Beach, Ca.
    I beat you there, I went for my 4th And it ran like a top for 4 days and then I had to reboot 2 times to get into windows All I wanted was an SLI solution but with the looks of things the 8800GTX's and Nvidia are gone to get the boot I think for Nvidia the 680i is the final nail in its coffin.
    What good is a card if you do not have a platform to use it on
    intel i5 2500k
    Asus P8Z68-V
    EVGA GTX470
    Corsair 8GB Vengence
    Corsair HX1000W psu ,
    High Speed Tech Station Top Deck,
    Dell U2410
  23. #323
    Mar 2005
    Bay Area, CA
    Wellllll - I got my board and my NB and SB coolers should be in today and tomorrow, one each day.. so I will start building on Thursday evening, which is a good night to start because Friday is a day I can tollerate sans decent sleep... anyways, so I am going to pull the sinks on the NB and SB off, and pull the heat-pipes out of the PWM sink, so it will look like this when done:
    I plan on leaving the thermal pad under the pwm sink... I think that's best for those fragile chips under it, but here's my question, should I use a fan on this also? will it overheat with just the sink on it? I do have an extra 40mm fan I could rig on it somehow.. but I don't want to do that unless it's becoming necessary to actively cool the PWM sink also.. ideas?
    Gigabyte x58 UD5 / core i7 920 @ 3.8 / 6G ddr3 / 100G Patriot Inferno + 500G WD / gtx470 SLI watercooled / x-fi / 1KW enermax / 5760x1080 surround
    Gigabyte z68x-ud3-b3 / core i5 2400 @ 3.6 / 8G ddr3 / 120G Intel 510 + 120G Adata S599 + 2x 1T WD blue / Zotac gt430 / x-fi / 500w ocz / 1920x1200
    DFI pro875B / pressy 2.8 / 2g corsair xms pro / 6800gt agp / 150g raptor x / 500w ultra x-connect / lots of UV lighting / smiles
    MSI K7N2 Delta-L / Athlon xp2600+ / 1G ocz platinum / chaintech TNT2 / 2x Diamond Monster 3D II SLI / Audigy / more smiles
  24. #324
    Sep 2003
    Edinburgh - UK
    May I ask where you got that photo from revenant? If your running water cooling then get it some active cooling on it somehow, if your running air then there should be enough airflow to keep it cool in that region.
  25. #325
    Jul 2006
    Marseille, Fance
    put bga swiftech heatsink on pwm chips, better contact, all copper.
