Slowly recovering from the Finnish Midsummer weekend and decided to try some Dothan benching again
There was a little bit of LN2 left in the bottle after The Stilt's P4 world record runs. Only couple of litres but I decided to give it a go.
The setup for the run was the usual:
M/B: ASUS P4C800-E + CT-479
CPU: Dothan 1.6GHz
RAM: Mushkin PC3500 2x256
PSU: OCZ 520W
VIDEO: ATI Radeon X800XTPE ES from Spring 2004
CPU COOLING: Chilly1's coppercontainer
GPU COOLING: R404/R23 cascade
The Dothan LN2 Gallery for Your Viewing Pleasure!
Setup
Not too cold
Cold
a Bit Colder
3DMachine!
Its all over
Since there was only couple litres of LN2 I had to be quick
First a quick SuperPi 1M test:
3500 was a no go this time, might get there without the extra copperplate I used this time, also tweaking the CPU voltage might help. Anyways 3450 was ok.
Knowing that the CPU would do 3450 superpi I started w/ 3403 for 3D. First run was at 769/657 without memtweaks and it gave 8789.
Second run at 3403 and card at 786 MHz / 671 MHz:
CompareURL
For third run I tried 3450 CPU but it would crash halfway thru the test.
Fourth run was doing 3422 and 796/679 but it never finished since I ran out of LN2
The card has done Mark05 at 817 core w/ the cascade. 679 w/ fast memtimings was running smoothly and there was probably some more left too. So there is some more point left but not sure if its enough for 10k. LN2 is a must for GPU but even then I'm not sure if it enough.
at 904/722 card clocks it would be a different story =)
![Send a message via AIM to [XC] moddolicous](images/misc/im_aim.gif)
| Asus P4C800-E Deluxe REV. 2.00 MOD | Crucial Ballistix 2*512MB PC3200 | Powercolor Radeon X800PRO-VIVO@XT PE@620/630 FULL-MOD By Malachia Cooled By Ybris Keops K5 ATI Rev.2
| Maxtor 3*200GB S-ATA + 1*160GB P-ATA | Powered By Enermax Noisetaker 470W
