Page 1 of 16 123411 ... LastLast
Results 1 to 25 of 377
Thread: List of DFI NF4 Ultra/SLI Bios
    Jun 2004
    USA, Vermont
    Here you guys go, I will go into length about each BIOS and how to tweak them in the near future...
    (-1 for TCCD/Micron/UTT-CH/UTT-BH/BH/CH This is the general bios that should work ok but is not optimized for any specific memory, -3 for TCCD/Micron, -2 for UTT-CH/UTT-BH/BH/CH)
    Stock Bios
    1.19 http://indabasement.com/DFINF4/bios/NF4LD119.rar
    These are the stock BIOS that shipped with the R.A00 boards
    1.25 http://www.dfi.com.tw/Upload/BIOS/NF4LD125.zip
    These are the stock BIOS that shipped with the R.A01
    1.26 http://www.dfi.com.tw/Upload/BIOS/NF4LD126.zip
    Not completely sure about the info on these BIOS if any one has input on them please PM me
    2.01 http://www.dfi.com.tw/Upload/BIOS/NF4LD201.zip
    1.LDT default set at 5x.
    2. Fixed IR connection failure.
    3. Fixed Boot failure when installing certain CL2 memory modules.
    2.09 http://oskarwu.myweb.hinet.net/dfi/...os/N24LD209.rar
    1. Update nvmm module to 4.79
    2. Update nv raid rom to 4.81
    3. Added memtest86+ option (memtest86+ 1.50 verison)
    4. Fix serial ata 3/4 disable but connect two hdd in serial ata 1/2 as raid drive , the raid array will not be correctly configured
    2.17 http://oskarwu.myweb.hinet.net/dfi/...os/nf4ld217.rar
    Fixes:
    Update memtest86+ 1.51 (New Features Added support for Intel i955X (Glenwood)
    Added support for nVidia nForce4)
    Bug Fixes:
    Fix a bug on K8 chipset recognition
    Fix Dual channel not detected on i865/875 (Bug added in V1.50)
    Some minor bug fixes
    Load Optimized Default =>Tref 3120 Cycle => fixed Corsair XPERT & OCZ
    VX Memory Steady
    2.18 http://www.ocxtreme.org/onepagebook/nf4ld218.rar
    Tweaked 2.17
    3.10
    http://www.dfi.com.tw/Upload/BIOS/NF4LD310.zip
    1.NVMM 4.85 and NV RAID 4.81.
    2. Enhanced memory compatibility.
    3. Enhanced USB compatibility.
    4. Enhanced the support of Athlon 64 in version E3(Venice).
    5. Beta, apparently the same as Oskar Wu's modded 3.10-2
    3.10p http://home.no/trac3r/Bios/DFI.LANPARTY.NF4/N4D310p.zip
    Tweaked 3.10
    3.14 http://home.no/trac3r/Bios/DFI.LANPA...4/NF4LD314.zip
    3.16 http://home.no/trac3r/Bios/DFI.LANPA...4/NF4LD316.zip
    Enable the 1+3 yellow slot dims
    Enables all 4 DIMM slots
    3.25 http://homepage.ntlworld.com/a.leach80/NF4LD325.zip
    1. Optimized for BH-5 and VX
    2 options for drive strength
    "not yet sure of the name?" http://eu.dfi.com.tw/Support/Downloa...AG=A&SITE=UK:D
    1 . Remove Write CAS latency item and replace it by Odd Divisor Select.
    2 . Add support for SST 49LF040B LPC flash ROM.
    3 . Add CPU temperature calibration option.
    4 . Fix ps2 mouse fail when ps2 kb not present.
    5 . Fix s1/s3 temp error after resume.
    6 . Fix startup VID option fail.
    7 . Fix C 'n'O.5 multiplier not working with Opteron CPU.
    8 . Fix day of month alarm can not set as 0 for every day usage.
    9 . Fix NF4-D model display error if SATA3/4 is disabled.
    10 . Fix ATI X1000 series logo error.
    11. Change FSB option to keyIn method.
    12 . Change 3114 ROM to 5.2.1.6 .
    13 . Change NV RAID ROM to 5.50 .
    14 . Change memtest86+ to 1.65 .
    15 . Synchronize DRAM related code with Expert and Venus.
    Oskar Wu’s modded bios
    3.09-2 (beta) http://oskarwu.myweb.hinet.net/dfi/.../NF4LD309-2.zip
    NVMM 4.71 & NV RAID 4.78
    please change Max async from 7ns to Auto
    3.10-2 (beta) http://oskarwu.myweb.hinet.net/dfi/.../NF4LD310-2.zip
    NVMM 4.85 & NV RAID 4.81
    3.26 http://mitglied.lycos.de/siedl/dfi3...wu/NF4LD326.zip
    Fix mem divider bug.
    3.31-3 http://oskarwu.myweb.hinet.net/dfi/...os/N4D331-3.zip
    3.31 with 3.10 ram table
    Memtest86+ update
    Modified 3.26
    3.31-2 (with 3.16 ram table) http://oskarwu.myweb.hinet.net/dfi/...os/N4D331-2.zip
    3.31 with 3.16 ram table
    Memtest86+ update
    3.31-1 http://oskarwu.myweb.hinet.net/dfi/...os/N4D331-1.zip
    Memtest86+ update
    4.14-3 http://home.no/trac3r/Bios/DFI.LANP...F4/N4D414-3.zip
    Added support for Venice and San Diego Cool n Quiet (TCCD)
    4.14-2 http://home.no/trac3r/Bios/DFI.LANP...F4/N4D414-2.zip
    Added support for Venice and San Diego Cool n Quiet (BH-5,UTT)
    4.14-1 http://home.no/trac3r/Bios/DFI.LANP...F4/N4D414-1.zip
    5.9-3 http://www.techpowerup.com/articles/...s/N4D509-3.zip
    Adds X2 support
    5.9-2 http://www.techpowerup.com/articles/...s/N4D509-2.zip
    Adds X2 support
    5.9-1 http://www.techpowerup.com/articles/...s/N4D509-1.zip
    Adds X2 support
    5.10-3 http://oskarwu.myweb.hinet.net/dfi/b...s/N4D510-3.zip
    Same as 5.09 Adds X2 support DRAM response time value for value ram
    5.10-2 http://oskarwu.myweb.hinet.net/dfi/b...s/N4D510-2.zip
    5.10-1 http://oskarwu.myweb.hinet.net/dfi/b...s/N4D510-1.zip
    5.10-3 FIX http://home.no/trac3r/Bios/DFI.LANPA...4/510-3FIX.zip
    Added dram response time fastest and fixed the program vdimm after ac off
    5.10-2 FIX http://home.no/trac3r/Bios/DFI.LANPA...4/510-2FIX.zip
    5.10-1 FIX http://home.no/trac3r/Bios/DFI.LANPA...4/510-1FIX.zip
    6.15 http://home.no/trac3r/Bios/DFI.LANPA...4/NF4LD615.zip
    1. Support Dual-Core Athlon64 CPUs.
    2. Fix certain PS2 mouse detection failure.
    USB KEYBOARD AND MOUSE DOESN'T WORK WITH THIS BIOS
    6.18-3 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D618-3.zip
    Fixes the USB bug from 6.15
    6.18-2 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D618-2.zip
    6.18-1 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D618-1.zip
    6.23-3 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D623-3.zip
    1 . FIX 6/18 BIOS DUAL CORE CPU PERFORMANCE PROBLEM
    2 . Add Errata 123 option , select disable can increase some performance in dual core cpu
    6.23-2 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D623-2.zip
    6.23-1 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D623-1.zip
    7.02-3 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D702-3.zip
    1. New ram dividers added, 233 and 250.
    2. This is a alpha bios for Rev E cpu's, do not use other revisions.
    7.02-2 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D702-2.zip
    7.02-1 http://home.no/trac3r/Bios/DFI.LANPA...4/N4D702-1.zip
    HL Rams/ LL Rams
    510T1 http://www.techpowerup.com/articles/.../N4LD510T1.zip
    HL Ram
    510B http://www.techpowerup.com/articles/...s/N4LD510B.zip
    LL Ram
    HellFire Modded Bios
    5.10-XCEL2-LL http://www.sonicxhosting.com/bios/N4D510-XCEL2-LL.rar
    Modded 5.09 with modded 3.16 ram table
    Adds X2 support
    Bios flash guide (Thank Pershoot for these flash guides)
    Bootable Floppy (Self Xtracting EXE) DOS Image w./ 310 Final:
    http://indabasement.com/DFINF4/bios/...310_PUBLIC.exe
    Insert floppy -> Double click .exe -> follow the prompt (you can just hit ok, defaults should be fine) -> when booting off floppy at the A: prompt to flash to 310 -> type flash and hit enter.
    Bootable CDROM (ISO) DOS Image w./ All Bios Revisions to Date (4/1/05):
    http://indabasement.com/DFINF4/bios/DFI_BIOSROM.rar
    ex: To Burn With Nero: Launch Nero -> Burn -> Image (nero6) or File -> Burn Image (nero5). Set First Boot to CDROM -> Follow On Screen Instructions to Flash.
    How-To Flash Bios:
    grab a bootable pure dos floppy disk (you can download dos image with 310 public release (NOT the "P" performance/beta version, but final version) on it, to be written to floppy above OR download bootable CDROM image w./ all bioses OR you can make one through your operating system: right click a: in my computer -> format -> check make ms dos startup disk) and place awdflash and bios file on this floppy. these can be found (dos flash util and bios file) above.
    enter bios -> load optimised defaults -> y->save -> boot off disk -> follow flash instructions in the .txt that comes with awdflash.rar OR type 'flash' at A:, if using bootable dos image w./ 310 on it OR follow on screen instructions if using bootable CDROM image. If using the 'awdflash.rar method', remember to replace BIOSFILE.BIN with bios filename (awd859e BIOSFILE.BIN /py /sn /cd /cp /cc /LD /R /f) -> after it is done, it will reset on its own -> after reset, enter bios -> load optimized defaults->y->save->after POST finishes -> shutdown ->switch off PSU -> unplug -> wait for yellow lights to turn off -> press power a few times-> set clear CMOS jumper -> wait for 10 minutes->set jumper back -> plug in ->switch on -> power up -> enter bios -> load optimised defaults -> now configure your bios.
    You guys can thank NiCKE^ for all of the bios info
    Dragon/ Pershoot/ NiCKE^
    P.S fell free to point out ANY mistakes and PM me if there is a bios that I have missed.
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Oct 2002
    FL
    good thread when i get my system up and running i'll be checking this thread out in the future.
    Mar 2004
    3.10-2 (beta) and 310 final is the same
    Jun 2004
    USA, Vermont
    OK I will change that, but the 3.10p are right, right?
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
    Mar 2004
    jop, 310p is 310 with optimized ram timings
    btw
    http://www.techpowerup.com/articles/other/114
    Feb 2005
    Excellent idea FireDragon, btw for the 3.26 why not just use oskar wu's link instead of that offensive link?
    DFI LanParty UT NF4 Ultra-D
    AMD Athlon 64 X2 4200+ | Stock
    OCZ OC3200 EL Platinum Rev. 2 1GB kit | Stock
    OCZ PowerStream 520W
    Thermalright XP-120 heatsink with Panaflo M1A fan
    eVGA 6600GT | Stock
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Yeah, very nice work indeed, now we need someone to test all the BIOS versions to find out best for TCCD and BH-5..........
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Xtreme Mentor
    Jun 2002
    Quote Originally Posted by S0nic
    maybe it is appropriate. apparently 326 is an offensive bios.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Jun 2004
    USA, Vermont
    Because I have not been able to find Oskars link...if someone has it then I would appreciate it if you could PM it to me so that I can change it.
    Dragon
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
    Nov 2002
    Hawaii
    That link for the modded 3.26 BIOS is bad.
    Dell 2405FPW
    Lian Li PC-75B
    PCP&C 510 ASL
    DFI LP UT NF4 SLI-DR Expert
    Opteron 180
    Chilly1 SS Phase Change
    2x512MB Mushkin Redline XP4000
    BFG 7800 GTX 256MB PCI-E
    2xWD 740GD RAID 0
    Maxtor 6B300S0
    Plextor PX-716SA
    Audigy 2 ZS
    Klipsch Promedia Ultra 5.1
    Jan 2005
    KAPVT MVNDI Rome, Italy
    your missing the 1st bios..only few people has it
    edit:
    the 119
    Jun 2004
    USA, Vermont
    Well do you want to PM it to me?
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
    Mar 2005
    3 more for you:
    331-1
    331-2
    331-3
    http://www.xtremesystems.org/forums/...ad.php?t=58042
    Banned
    Jan 2004
    Land of Buckeye
    subscribed! Great thread!
    Banned
    Jan 2004
    Land of Buckeye
    I think there is a 316 bios can enable full 4 dimms based on the 310 bios. Not bad
    Oct 2004
    Johannesburg , South Africa
    You mean @ 1T or 2T?
    i ran 4 x bh5 @ 2T stable..
    My Rig
    Conroe E6600 | ASUS P5W DH Deluxe
    TeamXtreem 2 Gig Micron | ASUS EN7900GT @ 700/800 (24/7)
    A-Open 700W | 2 x Hitachi 250GB SATAII
    Antec P160 | Watercooled
    Feb 2005
    Ankara, Turkey
    Quote Originally Posted by Onepagebook
    I'm using 316 bios - 2x512 geil bh5 on yellow slots... 1t
    NF4 Ultra-D - BIOS 3/16 Alpha (ram on yellow slots)
    WINNY 3000/CBBID 0501EPMW/xp-90 @ 9x255
    GEIL 2x512 Ultra-X 3200/BH-5/255Mhz 2-2-2-8@3.4 volt
    LEADTEK PX6600 GT TDH @ 580/1160
    OCZ ModStream 450w
    160GB Western Digital Caviar SE Ultra ATA/100
  18. #18
    Banned
    Jan 2004
    Land of Buckeye
    316 can do 4 dimm 4x512 DDR600 1t stable
  19. #19
    Jun 2004
    The Baltics
    WHERE is it???
    And show me the cpu which can do it as well
    away & gone
  20. #20
    Xtreme Recruit
    Jul 2003
    Denmark, Farum
    hello OPB
    I'm a bit confused, there is so many BIOS out right now.
    what is the best BIOS for G.Skill4400LE?
    Vapochill LS
    DFI NF4 SLI-DR
    OCZ EL DDR PC-3200 2GB CL 2-3-2-5
    AMD 3500+ Winnie
    ATI X1900XTX
    OCZ 600W
    2*250Gb Raid0
  21. #21
    XS News
    Dec 2003
    North Carolina
    If I flash to a different bios will I lose my raid array?
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
  22. #22
    Xtreme Recruit
    Jul 2003
    Denmark, Farum
    Quote Originally Posted by chunkylover77
    no! just enable raid in bios again.
    Vapochill LS
    DFI NF4 SLI-DR
    AMD 3500+ Winnie
    ATI X1900XTX
    OCZ 600W
    2*250Gb Raid0
  23. #23
    Jan 2005
    Quote Originally Posted by FireDragon
    here buddy
    Right Click Me and Save Target As don't do just a direct click onit right click is the way to leech it
  24. #24
    Dec 2004
    The Holy Land
    Quote Originally Posted by Holberg
    hello OPB
    and that is a good question
    so many bios to this boad ...
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
  25. #25
    Mar 2004
    Got all those bios here and will upload all new once there too.
    Intel FTW!
    Beanna
