These 2 weeks, DFI has done a lot.
Just remember DFI launched ATI RD482, RDX200 CF-DR, 2 weeks ago.
I am still impressive in the OC ability, great layout and components.
Today, DFI launches revised nF4 – EXPERT version.
Lets have a look.
The box changes to green plus EXPERT wording.
Previous nF4 is blue and RDX200 is red.
The backside of box has detail description.
The outlook of the board
We can see it’s similar with RDX200.
The same 100% Japanese capacitors keep good quality.
Left below
For advanced user who has audio card or TV tuner card, the original nF4 just has 2 PCI.
This version increase to 3 PCIs and keep the diagnostic LEDs.
Right below
The same as usual to have POWER&RESET switches.
4 nF4 built-in SATAII and 4 SATA from Sil3114 which supports RAID5.
Also built-in PC speaker which can be disable by jumper.
Left above
2 IDE slots.
The same as INTEL LGA775 uses 24PIN + 8PIN in power connectors.
But normal 20PIN + 4PIN POWER still can use.
IO and Memory
6 USB 2.0 + Dual Gigabit LAN + 1 IEEE1394
The memory slots are great. You can use CPU and chassis coolers to reduce the heat of memory
SLI switch is electrical.
Enlarged PCI-E gap is wonderful for user to use water blocks or compressor to tweak the VGA performance.
nF4 chipset cooler is magnetic levitated fan. It’s 3000 to 7000rpm. User can adjust it by himself. This design is great for performance and low noise.
The components close to CPU socket
4 phases PWM with aluminum components to enhance the stability.
The best selling point for this board
Keep the nF4 great OC blood, in memory, it break the AMD 4DIMM in DDR333 2T spce.
In EXPERT, we may can reach DDR400 1T with 2 2-2-5.
I use 2 pairs GSkill 1GBFX to test this.
Time is late. Wait for more detail test in BIOS and memory tuning............
BIOS Options…
The boot up screen is getting better.
BIOS
Basically, the setup is similar with previous DFI LanPARTY nF4 series.
However, the range is more flexible.
Main setup options
Built-in MEMTEST is a great tool. The version is 1.65
The highest frequency is 550
HT 1~5X also has 1.5X and 2.5X
CPU voltage also has 2 segments adjustment.
1st segment is 0.08V to 1.55V
The 2nd segment is %, maximum is 136%
The overall highest voltage is 2.108V
DRAM voltage
Previous version is setting into 2 sections : 2.5V~3.2V&3.3~4V JUMP.
This version is non-section voltage from 2.29V~4V. Even the voltage is over 3.3V, there is no heat issue as before.
SLI uses electronic switch. You can switch into 1X/16X or 8X/8X mode in BIOS
DRAM tuning options
Same as previous version
First page
Next page
The key factor of OC - DRAM Drive Strength
From LEVEL1~LEVEL8 to LEVEL1~LEVEL15
BIOS Temp./Speed control page
Test Congiuration
AMD K8 939 3000+ 0517
DFI nF4 SLI-DR EXPERT
GSkill 1GBFX DDR400 2 2-2-5 2 pairs
SPARKLE 6200
Maxtor 30GB
DELTA 350W
Even it’s 512X2 DDR400 2 2-2-5, when you plug 4 DIMMs, you still need to adjust the BIOS very carefully.
DDR400 1T 4 DIMM is not CPU(AMD).MB(DFI).DRAM(GSkill) official guarantee.
All official guarantee is dual channels not 4 DIMMs in 2 channels.
Reached! DDR400 2 2-2-5 1T 512MBX4 2.68V
PI 32M finished!!!
Forget the most important accessory
Longer SLI bridge
3D VGA
MSI 7800GT SLI
3DMARK2003
3DMARK2005
DRAM
2GB Kit
GSkill 2GBHZ
DDR570 3 4-4-8 1T 2.49V PI 32M
Thanks for posting
