Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: MSI RS480 M2 Clockgen needed!
    Oct 2003
    Someone take the challenge?
    CA431251
    0436
    951412AG
    Sep 2003
    Alpharetta, GA
    You're still not going to get anywhere without voltages.
    Current system:
    Case: Modded Watercooled Jpac
    CPU: Intel Q6600 @ 3.5GHz [1.47v] - OCCT stable
    Mobo: DFI LanParty Jr T2RS @ 432fsb [1.37v]
    RAM: Crucial Ballistix Tracer 4*1GB DDR2 @ DDR1095 (5-4-5-15) [2.2v]
    HD: WD 300GB Velociraptor / WD 640GB Caviar
    GPU: HD 4850 Crossfire @ (700 | 2200)
    PSU: OCZ ModXstream 780w
    Nov 2004
    Keller, TX
    Well atleast a clockgen is a step in the right direction.
    V modd's can be tried later!
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I let Franck know the PLL info a few days ago. Not sure if they made he made any progresss yet. ATI may also be creating a soft pll too.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jan 2005
    Sweden
    Quote Originally Posted by FUGGER
    Any updates on how it's going?
    Gigabyte GA-990FXA-UD3 rev 1,0| AMD FX-8120@?| Corsair H100| 2x4 GB Patriot Viper Xtreme Division 2 PC15000 9-11-9-27| 2*Powercolor Radeon HD6970 2048MB @ Crossfire| 3*NEC MultiSync EA231WMi 23" Monitorer @ Eyefinity| OCZ Vertex 3 60 GB| 2*Intel 80GB X25-M G2 @ RAID0| Cooler Master Silent Pro M1000W| Cooler Master ATCS 840|
    Jan 2005
    Bulgaria:Maina Town(Plovdiv)
    Something new ?
    Mar 2005
    when the clockgen?
    I too have just acquired one of these nifty microATX boards, but zero o/c available in the bios. I'm using a Winchester 3200 that I pulled from an Abit mobo - where it could be safely o/c from 1999mhz to 2500mhz just by upping the fsb! - and with standard heatsink (but larger/faster fan).
    Anyone know when Clockgen will be available for this mobo? Or does CGen only get made for full ATX boards? Or can another MSI bios safetly used?
    C.
    beefin' it up!
    Dec 2004
    WPI
    thus far most CGens have been for whole chipsets, so any board regardless of size could use it.
    Using a different MSI BIOS probably wouldn't work, as as of now, this board is unique in MSI's lineup (only one with the chipset).
    Mar 2005
    Mumbai, India
    Msi Rs480m2 Il
    Quote Originally Posted by Cargo
    C.
    Well I did try some test yesterday which were given by Franck, but he thinks "fine tuning" is not available on 951412 and so there will be fixed frequencies to choose from and it will take hell lot longer. But lets hope for the best and till then I can get my board to run @ 204FSB not too shaby for now, huh??? What a bad way to waste Twinmos CH-5.......
    Mar 2005
    whoo hoo 204 is better than the 199 mine is stuck at
    Mar 2005
    Quote Originally Posted by harshal
    Well, that's something to look forward to!
    BTW, MSI have just released a new bios 3.3 that will "Strengthen memory compatibility" - whatever that means.... Anyway d/l and install it okay, but can't seem to see much difference. To tell the truth, I've steered well clear of the (very few) memory settings that can be changed, cos the board just "freezes" - and for hours too. Never known a mobo to take so long to reset - the "Clear CMOS" jumper doesn't seem to work at all on my board - you HAVE to remove the battery - and for several hours too. Best to leave it out overnight.
    Also, what are you all using to monitor temps/fanspeeds/volts? MSI's Corecenter tells me that it "Corecentre isn't compatible with your motherboard". (Thanks MSI! ), and PC Alert does temp/fan speed only - all the volt readouts are blanked.
    Whatever I like this board - just a waste running the 3200 at 1999mhz when it can hold steady at (very near) 2500mhz. Runs cool too at just 38-40C on ful load - Seti.
    Mar 2005
    speed fan seems to work although at least for me the sensor #2 needs to be calibrated it says its at 105C. At least its showing voltages for +3.3 and +12.
    Mar 2005
    Mumbai, India
    We all are made same - MSI RS480 M2
    Well Cargo, you are not the only one, any aggresive numbers (even with 2-3-3-5, forget 2-2-2-5) set with A64 Tweaker freezes my mb too, and even though it restarts, to my surprise Monitor does not show any signal. Clear CMOS does not help right away to get back the Video.
    I have also noticed Southbridge getting very hot (yes its HOTT) and thinking about an old TNT2 heatsink Fix on it for now as Mumbai, India is already very hot (32-35C). PC Alert minus voltage readouts is the only thing I am using as of now but then A64 3000 doesnt run that hot at stock. MSI, your Core Center is BS for now.
    At stock or 204 though its a very strong performer with S-Video out and DX9 class integrated GPU. But I have really started to think that MSI missed somethings when making this boards Hope it can't be too bad afterall and maybe future bios can fix something atleast (read VMEM) or else Franck finds some pre-fixed values which are easily achivable as A64 3000 & CH-5 are raring to go.
    Harshal.
    Mumbai, India.
    Xtreme Legend
    Jul 2004
    France
    Actually no fine tuning is possible on this PLL. In fact it is there, but does not work
    Anyway, there are predefined clock settings that can be choosen :
    With spread : the max FSB is 220MHz, with AGP = 73 and PCI = 36.
    Steps are : 200, 204, 210, 214, 220
    Without spread : the max FSB is 229MHz, with AGP = 76 and PCI = 38.
    Steps are : 200, 203, 209, 219, 229
    Mar 2005
    any Idea when it will be out CPUZ? And how will the new system of paying work?
    Xtreme Legend
    Jul 2004
    France
    I sent a test version (with no spread) to Harshal, I'm waiting for his results.
    As this version provides no fine tuning, it will be free.
    Apr 2005
    harshal: hurry up with the testing, i cant wait!
  18. #18
    Mar 2005
    Mumbai, India
    Hi Guys, well testing is done and I have sent results to the "GURU" of ClockGen.
  19. #19
    Jun 2004
    Harshal.
    Mumbai, India.
    Odd, my PQI tccd does 2-2-2-5 no problem on boot with the a64 tweaker.
    what do you use there?
    would also like to get my 3500+ up to speed!!!
  20. #20
    Xtreme Legend
    Jul 2004
    France
    OK there were some problems, hopefully this will work now.
    Some switch cause the FSB/PCI ratio to change. This is a real problem and tends to make the system freeze. By chance, starting from 200 up to 220, the ratio does not change. But from 133 to 200 it does. unfortunately there is not a lot i can do to avoid this.
    Anyway, as soon as the version is stable I post a link.
    See you,
    Franck
  21. #21
    Mar 2005
    Mumbai, India
    If Only............
    [QUOTE=boasist]Odd, my PQI tccd does 2-2-2-5 no problem on boot with the a64 tweaker.
    QUOTE]
    Well, I have AMD 3000 and Twinmos PC3200 512MBX2 with Winbond CH5 which takes 2.85v atleast to be 2-3-2-5 stable...
    Yes, my friend you are one of the lucky ones out there with those TCCD Chips.. If only I could get it (actually there are many things which are on my list..DFI nF4 SLI-DR is one of it) here in Mumbai....but there is no demand for high performance products as its not consumed by regular people... with 200W PSUs going as 350W... u can expect what it is like. But then can't blame people with less money, right? I hate it, but can't change it.
    But I have ordered G.Skill PC4400-TCCD 512MB DC kit as my unlce is visiting NY, US. Then I think i will be able to get 2-2-2-5.
  22. #22
    Xtreme Legend
    Jul 2004
    France
    Here we are :
    http://www.cpuid.com/download/CG-ICS951412.zip
    Big thank to Harshal for his tests
    edit : this clockgen assumes that the memory frequency is the same as the FSB. So far I don't know how to get the real one, so trust your BIOS settings.
  23. #23
    Mar 2005
    Red face
    Quote Originally Posted by cpuz
    Here we are :
    Many thanks Mr CPUZ! Working good!
    Just noticed this new 939 mATX board get a mention on another forum:
    http://tw.giga-byte.com/Motherboard/...-K8A480M-9.htm
    It uses the same ATI chipset, but seems to have more interesting options:
    1. CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
    2. PCI-ExpessX16 Voltage / Clock adjustable via BIOS
    3. DIMM Voltage / Clock adjustable via BIOS
    Can't seem to find it available anywhere yet though..... maybe not released yet...
  24. #24
    Mar 2005
    many thanks cpuz
  25. #25
    Mar 2005
    estonia , tallinn
    Here we are :
    why only 2000mhz
