i was pretty iffy on whether i could actually setup my rig with w/c components i had ordered in this thread even after all the research i did but finally i got my rig setup today after receiving final parts yesterday.
main components:
EK Supreme
MCW60
PA120.3
MCRES
TT Armor Full Size
to start off with here are some nicely composed phone cam rig shots:
disregard the shoe lace for now.. im waiting on making a custom hold down for the rad this weekend.
Work Log:
i wish i would've actually took pictures to make this a more vivid worklog but i didn't![]()
to start out i stripped my case down and gave it a shower.. in the shower. then to get it ready for the day i wiped it down and used a hair dryer on it for 15 minutes.
mmm compressed paint time! i started out with a gray coloured primer suitable for wood and metal. i coated everything (hdd cages, dissassembled fans, plastic fan holders, I/O plate, case) with 5coats with aprox 30 minutes in between coats. after the final coat it was left to dry for 1 hour.
from grey to black and beyond! used same methods as above for the 5 black coats i sprayed and then finally left it to dry over night. paint used was gloss.
i love the look of black and white so i decided to spray the fans/holders and hdd cages white for a nice looking contrast. same methods used above, paint used was glossy.
finally onto the clear coat, again same method as the others, haha, except i let this coat dry for 4days.
finally with the case done i could begin on the tubing and blocks. i assembled everything in the case, leak tested for 5hours then installed the mobo and gfx only to find out...
i measured wrong!
after some cursing i recut some of the tubing, reloacted the res to the mobo plate and reinstalled everything followed by a leak test.
leak test passed! 2hours to be exact.. a little short i know but i'm impatient guy. now was the time to install the Enzotech low profile copper sinks on the mobo and 8800gtx along with MCR21 vreg sinks for the gtx. this was a pretty frustrating installation as both the Enzotech and MCR21 sinks have incredibly weak thermal tapepretty much the MCR21's would not stick at all and the Enzo's would last maybe 5mins even after i held them there for awhile. to remedy this i used *drum roll* .. carpenters glue! seeing as thats all i had at the time and it worked even tho the bottle looked like it was from the 1980's.
final step was to route the cables as best i could and power it up. i was really nervous at this step as i wasn't sure everything would work or i would have accidentally messed up, im sure you all know what im talking about. after hitting the switch everything booted up and i loaded defaults and strolled in to windows.. only to be greeted by my dreamscene looking like a slideshow and everst freezing followed by a BSOD! so calmly i powered down and checked for leaks, wires and also on the small mem/ram sinks. everything looked ok so i powered up again and this time no bsod and i was able to run the cpu and gfx card at load without bsod or electrocuting myself.. huaaahh!
now to the sweet stuff, back to my previous o/c and see how it faired vs. my previous true120 aircooling.
and the results pls sir!
CPU:
first on the cpu i tested with prime. Q6600 @1.36v load and the rest in the cpuz shot. i have no before shot or maybe i do but im too lazy to find it.. but with true120, 2x120mm 12v fans and 20-23c ambient:
prevoiusly:
Idle
40c cores 1/2
34c cores 3/4
Load
70c cores 1/2
68c cores 3/4
before you suggest, cores 3/4 have always been 5-6c cooler at idle with over 8+ mounts with true120.
now:
Idle:
36c cores 1/2
32c cores 3/4
Load:
explained with a screenshot![]()
since i'm semi-hardcore gamer i wanted to see the 8800gtx gfx results. i mainly play GoW, Crysis and RTHDRIBL (yes you can't play it). unfortunately no screenshots as i deleted them but i can provide current ones if pleaded with but as for now i am to lazy to rebench them.
previously:
(stock cooling 621/1620/900)
Idle:
62c @100% fan
Load:
85c @100% fan
82-85c was the average temp i saw with all games.
Now:
(PA120.3, 3xDS12 Yates 12v, 621/1620/900)
Idle:
38c
Load:
45c!!!
yes you calculated right.. that is a 40c difference between watercooling and the stock air cooler.. i was blown away by these results and am now testing if i can get a higher gfx clock! but it's doubtful without vmod![]()
anyway i did have fun doing this but i would warn anyone about to embark that water and electricity is dangerous but with research, patience (which i lost sometimes), and non alcoholic beverages that this can be accomplished!
thx for reading, feedback welcomed![]()
