KX-7 Ready To Give Up
Mr Icee....
I'm really going nuts with this KX-7...... First with the RAM I had on hand... I could not get my XP 2100 To run at stock speeds with it......
So I got a 512mg Stick Of Corsair XMS 3200....
It was an improvement.... But It's Still Way off what my KR-7 Was doing.... 12X164: 1968MHz. On Air...
The Fastest this will run now is... 1750MHz. With the same chip... 11X159 !!! This is CAS2 2-6-2 It won't run Command 1t... Or Access faster than 3.... And It won't run with Enhanced on....
Vcore is now 2.01....
MemV is 3.02
Via 4.38's
The divider is not an issue because I can't break 160FSB....
Nothing else has changed since on my setup with the KR... This is my last plea..... I'm seriously thinking of going Intel.... Like a 2.8 with IT-7.... Maybe a Prometera
Is there something I'm missing; BIOS, 4 in 1's I have the settings you recomended for WPCREDIT...
I don't know what else to do at this point...
Royd
- You may not post replies
- You may not edit your posts
Forum Rules
