Hi all.
Ive been benching today using the tweak RICK/PEDRO descovered.
I now have some concerns over this tweak.
It does seem to have given a performance boost in all tests but I could NOT get a run with the graphics overclocked where my nature score was not bugged.
This run should have been 25.5k max, but with bugged nature of 219fps it gives me a false score of 26590...
Problem was that even though I ran nature ten times over the result was the same bugged score every time.. appart from when I dropped back to stock graphics clocks when I got a "normall" score.
This is worrying because if I can get this sort of repeatability, others may also have bugged natures and might not notice... Id recomend that everybody checks there nature to make sure that its not artificially high..
http://service.futuremark.com/compare?2k1=8224182
I am NOT saying that everbody has a bugged score, as all my other tests did fun faster with this tweak. But its worth checking for as I can repeat the bugged nature over and over...
I havent checked anybody elses scores, but if you do have any odd ones can you post here.
Or if you think this is down to something else on my system let me know.
I never had this problem before switching to multiprocessor driver.
Thanks.
Holst
