Hi Guys,
If you are looking to upgrade to 2GB of ram and can't decide about tight timings or high FSB with looser timings....I worked up a little comparison of our PC4000 Gold 2GB kit and the PC3200 Platinum 2GB kit.
All results are with the following setup:
3500+ Clawhammer CPU
XP-90 w/ Panaflo fan
DFI NF4 Ultra-D (SLI modded )
OCZ Powerstream 520
2 x MSI 6600GT TD128E
I have the 704-2BT bios loaded on the board.
DDR Voltage on the PC3200 Platinum kit is set to 2.6V in the bios.
Voltage on the PC4000 Gold kit is set to 2.5V with the +0.3 if not 3.2V set to enabled.
Both of these benchies are with the CPU underclocked to 2.0GHz....I wanted to show FSB and timings comparison only....A64 Tweaker included for Alpha timings and I believe I got them all the same...except for tREF since the FSB settings are different.
First one is the PC3200 Platinum 2GB kit P/N: OCZ4002048ELDCPE-K
Next the PC4000 Gold 2GB kit P/N: OCZ5002048ELGE-K
