Beautiful job, bro.
Where can I find hotglue?
Thanks!
The hot glue is only holding things in place...little extra stability in case I accidently snag a wire or something I wont rip off the soldering job I did.
Hot glue is great for holdign down wires, vr's, you name it. And easy as pie to remove if need be.
I would hit any local hobby store, Home Depot, Lowes...places like that. Got my glue gun from Home Depot for $9..came with case, gun, glue.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
- You may not post replies
- You may not edit your posts
Forum Rules
