Results 1 to 17 of 17
Thread: My new solid copper GPU pot
    xtreme energy
    Oct 2004
    Europe, Latvia
    I wanted a new GPU pot so here it is, made by local milling pros
    I will start benching when summer is over - need to rest now
    Oct 2002
    Germany
    Veeery nice work, kiwi! They are based on rev.3 mousepots, right?!
    xtreme energy
    Oct 2004
    Europe, Latvia
    Yes with a few slight modifications Have to say big thanks to Jason (aka MickeyMouse) and Tapakan
    May 2007
    Very nice I am green with envy - enjoy and look forward to seeing your results.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Will the plexi be ok in use? Nice pots!
    you sigged that?
    why?
    ______
    X.I.P.
    Jul 2004
    Hellas-->Athens
    Greta job Kiwi...maybe the only modification you will need it is to replace the plexy with acetal...
    When Mercedes brought their C111 to Talledega years ago and blew away the closed course record did it count? Yes..
    That was a "factory" car and a "one of" that no one could buy and was never sold.
    Records are records and that is a fact so get over it.
    Very nice kiwi
    Feb 2004
    Conway AR
    Nice work. how much does it weigh? looks massive.
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Looks good, now you just need to wait untlil the summer is over, so you can start benching and test it
    Sep 2005
    Belgrade, Serbia
    Great work kiwi
    Born to overclock
    xtreme energy
    Oct 2004
    Europe, Latvia
    Quote Originally Posted by rhino56 View Post
    cpu pot ~2kg, gpu around 1kg
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    HUMUNGUS COOLING area for that GPU
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    OC Jedi (on stand-by)
    Jan 2005
    Germany
    Nice container kiwi
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
    -100C Club Member
    Feb 2004
    australia
    They are some very nice solid tubes there kiwi
    With the GPu pots the square face that attaches to the die, what are the dimentions for that?
    Also how wide is the tube?
    Jun 2006
    Kayl, I think the design is very similiar to Jason's rev. 2 pot which has been posted over at OCX.
    -100C Club Member
    Feb 2004
    australia
    Quote Originally Posted by Stapler View Post
    do you have a link?
    xtreme energy
    Oct 2004
    Europe, Latvia
    Quote Originally Posted by kayl View Post
    45x45mm
    Diameter 45mm - you can see it is basically same width as that square you talking about
