Results 1 to 8 of 8
Thread: FireGL mod for Radeon HD 2900XT
    Dec 2006
    Kuwait
    Workstation graphics on the cheap
    A Chinese website has posted a modded version of AMD's drivers that will turn an ATI Radeon HD 2900XT into a FireGL V8600.
    This might not be all that useful to most owners of a Radeon 2900XT, but if you're into OpenGL 3D rendering and need a fast card for the previews, then a Radeon HD 2900XT will be a lot cheaper than a FireGL V8600 card.
    Considering that the FireGL V8600 will set you back US$1899, while you can pick up a 1GB Radeon HD 2900XT for as little as US$499.99, you can save quite a bit of money this way.
    You can download the modded drivers here and it's about a 70MB download.
    http://www.newdisk.cn/?wesley8
    Is this possible ?
    Gaming rig;
    ASUS RAMPAGE IV BLACK EDITION
    I7-4390K
    G.SKILL Trident X 16GB 2400
    Intel 530 240GB
    2x Asus GTX780
    Corsair AX1200
    HP ZR30w 30
    Win 8.1 pro
    Sound rig;
    Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
    Xtreme Cruncher
    Oct 2006
    Copenhagen, Denmark
    Very nice, thanks for the info! I know some people who'll find this trick very very useful.
    CM Stacker 810 w/ Yate Loons | Enermax Infiniti 650W
    ASUS P5K Deluxe | Corsair XMS2 PC2-6400 2x2GB
    Intel Core 2 Quad Q6600 | Thermalright Ultra-120 eXtreme
    BFG Geforce 8800GTS 640MB | ASUS Ageia PhysX P1 128MB
    Logitech G15 | Logitech G5
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    I think this could be especially useful if diamond gets that 2gb card working, it's called the 2900xt pro edition (since they no longer can call it firegl) and that should be a nice deal for people that could actually use the memory
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
    Feb 2005
    Belgium
    GeForce 4 titanium had about the same modification, I never tried it but in theorie it should have been working quit good if I remember that right. The Titianium series didn't offer same performance as the Quadro series, but didn't fall back that much after the modification.
    Dec 2006
    Kuwait
    So. can some one try and tell us the result
    Gaming rig;
    I7-4390K
    Intel 530 240GB
    2x Asus GTX780
    Corsair AX1200
    HP ZR30w 30
    Win 8.1 pro
    Sound rig;
    Mr Fantasic
    Apr 2004
    Quote Originally Posted by koc View Post
    this worked on the 9700 pro firegl eqivilent
    they are hacked drivers to force windows to use a diffrent hardware id.
    RIP GrandDad , I'll miss you -15/07/1985
    RIP GrandMother, I'll miss you -08/08/2007
    Dave is the man!
    Sep 2007
    CA Bay Area
    It worked on the nv40 fine. I remember i had one of those.
    Jan 2004
    Modded driver results in this thread:
    http://www.xtremesystems.org/forums/...ighlight=v8600
    (start at post #19)
    Dimastech Easy Dual v2.5 (black)-----Silverstone Strider 1500w-----ASUS Maximus IV Extreme-----Intel 2600K-----Corsair Dominator GT (4x4GB) DDR3 2000-----2x Samsung 840 Pro 256GB SSD's-----2x GTX Titan 6GB SLI-----Dell 3008WFP
    Watercooling Loop: EK Supreme HF Rev. 2 - Acetal-----2x EK-Titan Acetal connected via EK-FC Terminal Dual Parallel-----2x Swiftech MCR320 Drive Radiators w/ built-in MCP35X Pumps-----EK-MultiOption RES X2 - 250 Advanced-----6x Scythe GT 1850rpm Fans-----Primochill LRT 3/8" ID - 5/8" OD (Red)-----Bitspower Carbon Black Fittings-----Distilled Water + PT_Nuke PHN + Feser Base Corrosion Blocker
