Hi all
ive been planning to replace the heatsink/fan combination of my NF4 Ultra-D for awhile now
and finally i did it!!
first i bought an old swiftech heatsink
after this i did ALOT of fitting and measuring
then i drilled the 2 holes
as u can see above, the drill just pushed the pins in the neighbourhood away, i didnt even have to remove those pins
after that i drilled a bit from the bottom away so that some obstructions on the mobo are avoided
as u can see its all a bit amaturistic, but i dont give aabout the looks, as long as its silent and cool!
i also used a drill only for it, which is actually a wrong tool :p but i couldnt find any better (and it actually worked)
the next few hours i spend lapping the heatsink... i started with 120, followed by 180, 240, 400, 600 and finally 1200 (i couldnt find any steps in between)
then i went fitting again, and i noticed two more obstructions had to be avoided
this is how it looks like after the lapping and after making place for those 2 extra obstructions (did those 2 with a metal saw, and with a big bolt)
now the heatsink fitted the mobo!!
so i started fitting the videocard... offcourse i had to remove some pins for that... this is the result
then i finally installed the heatsink very carefully with some as5
and after that also the videocard
after this i was very glad everything still worked
and also the results are very nice!!
without any casefans on the temp became 50°C, which is about the same temp as before with that small fan!!
with the casefans on it only becomes around 40°C!!
this is passive!! quite a nice result if u ask me...
