Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: What IC in crucial tenth anniversary ddr667?
    Aug 2004
    rutgers
    Hey, just wondering if anyone knew what ic these use:
    http://www.crucial.com/store/partspe...2KIT12864AA663
    The Canuck
    Oct 2002
    Montreal, Canada
    Quote Originally Posted by kemist
    It's definately D9, not sure which exactly, but they are good IC's.
    In the 3DGM review, it hit 800Mhz 3-3-3-10 @ 2.4V
    In the BCCHardware review, it hit 824Mhz 3-3-3-12 @ 2.35V
    The only issue with this ram is the price, ungodly expensive!
    Feb 2005
    D9DQT according to this site
    http://forum.lowyat.net/index.php?showtopic=298646
    Micron BT-3, B6-3
    but again not really sure if crucial put better IC with that aniversary heatspreader
    Oct 2005
    U.K.
    d9gmh, i have a kit
    $230 doesn't seem to much
    http://www.newegg.com/Product/Produc...82E16820148017
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    3x4GB G.Skill PC3-12800 7-8-7-24
    HIS Radeon HD 6970 2GB & Dell 3007WFP-HC
    Asus Xonar DX
    128GB C300, Velociraptor & Sammy F3's
    Corsair AX850W
    Windows 7 Ultimate x64 SP1
    Jun 2006
    Pyr0,
    are this rams capable 1000 @4-4-4-5 2.3/2.4v?
    Feb 2005
    Quote Originally Posted by Pyr0
    d9gmh, i have a kit
    does this kit also have D9GMH?
    this kit
    Oct 2005
    U.K.
    Quote Originally Posted by ocfx
    Pyr0,
    4-4-4-8 = 2.3V
    Quote Originally Posted by khurios2000
    this kit
    yes
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    Asus Xonar DX
    Corsair AX850W
    The Canuck
    Oct 2002
    Montreal, Canada
    d9gmh, i have a kit
    I was referring to Crucial's MSRP, but Newegg's price is quite reasonable
    Feb 2005
    yes
    lucky me, bought a used kit last night for 200 bones
    Nov 2005
    PHX
    I managed 800 3.3.3.12, but needed 2.4V for it. AFA cosmetics, it's nice to see all modules touching tape, then spreader. They're kinda purty too.
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    Quote Originally Posted by OCFX
    Pyr0,
    Yes, they can do 1000Mhz @ those timings.
    D9GMH
    Newegg no longer has them and ChiefValue is OOS.
    "You'll find happiness once you accept the inevitable or at least you won't be too pissed off" -- Me
    [SIGPIC][/SIGPIC]
    Sep 2006
    Mine won't boot at cas4 but will boot and run stable at 5-4-4-12 DDR2-1000 2.3v even 2.4v didn't give me cas4 and I'm unwilling to go higher so I left well enough alone. Still hella good as it's cheaper than buying any DDR2-800 and hoping to do 1000 with similar timings.
    I did also notice newegg removed the listing (they had stock earlier today though) and I just got mine so I must have ordered at the right time.
    edit: Maybe my board undervolts and I should try higher than 2.4? I have no mods to it. What do you think? worth it to try 4-4-4-x DDR2-1000?
    or just don't touch it? I do have a 60mm fan blowing on them
    Asus Maximus V Gene
    3570k @ 4.6Ghz +.13v w/Noctua NH-D14
    8GB Samsung 30nm @ DDR3-2133 10-10-10-25 1.4v
    EVGA GTX 670 FTW @ 1170/6800
    2x Crucial M4 128GB SSD
    WD Velociraptor 300GB
    Corsair HX1000 PSU
    Cooler Master HAF 932
    Hardware Junkie
    Jun 2005
    Okinawa, Japan
    Quote Originally Posted by Dredd
    Try this:
    So in order: 4-4-4-10-4-35-10-10-10-10 and the other settings exactly the same. I hope this helps.
    Set vdimm @ 2.45v and see if you get it going.
    Check with I did with a P5B Deluxe WiFi:
    [SIGPIC][/SIGPIC]
    Sep 2006
    Thanks but it won't post even at 2.45v and those settings. But 2.25v (in bios) boots at 5-4-4-8-4-35-10-10-10-10 But as soon as I set cas4 it won't boot at anything past 800Mhz.
    Asus Maximus V Gene
    Corsair HX1000 PSU
    I am Xtreme
    Dec 2002
    what bios?
    Sep 2006
    Quote Originally Posted by Revv23
    what bios?
    0711
    I know there's a newer revision. DO you think I should get it?
    Asus Maximus V Gene
    Corsair HX1000 PSU
    Oct 2005
    U.K.
    try 4-4-4-12-5-35-4-10-5-13
    what are your voltage settings for nb, sb etc.
    i950 (3035B684)
    Gigabyte EX58A-UD3R
    Asus Xonar DX
    Corsair AX850W
  18. #18
    Sep 2006
    No go even at 2.45v even 4-6-6-18 is no good *shrug* I've tried NB/Sb/iCH at max volts and it still wouldn't post at cas4 DDR2-1000. I probably have a set that just won't do it
    I'm even running the latest BIOS 804 and no change. Oh well I did manage to boot at 5-4-4-4-4-35-10-10-10-10
    edit: Now I got it to boot with 804 bios and 1.7v on the NB and 1.6v on the SB 2.4v on memory (tried this with 711 I think and no go)
    DDR2-1000 4-4-4-8-5-35-10-10-10-10 why would I need so much voltage on the NB/SB?
    Asus Maximus V Gene
    Corsair HX1000 PSU
  19. #19
    Nov 2005
    PHX
    How high can you guys go @ 3?
  20. #20
    Sep 2006
    Quote Originally Posted by Jodiuh
    3-3-3-12 @ DDR2-800 with 2.35v was ok here
    Asus Maximus V Gene
    Corsair HX1000 PSU
  21. #21
    Sep 2006
    The Netherlands
    Micron BT-3, B6-3
    Crucial's Tenth Anniversary modules are not even mentioned on that page...
    Besides, D9DQT is no longer in production.
    They use D9GMH (B6-3) which can be found on my DDR2 RAM List.
    They do. The ICs used on Tenth Anniversary DIMMs are handpicked by Crucial.
  22. #22
    Sep 2006
    I maxxed my voltages on the FSb termination, NB, SB, and ICH (running 2.3v on memory) to boot 4-4-4-12-5-35-10-10-10
    Gonna run memtest
    Asus Maximus V Gene
    Corsair HX1000 PSU
  23. #23
    Nov 2004
    damn I was just about to order this stuff from newegg and all the sudden they aren't carrying it I just I'll go back to the dominator 6400c4 (same IC's) the crucial at the price was a steal.
    DFI NF4 LANPARTY UT nF4 SLI-DR
    Opty 148 @ 2.90ghz W/ Tuniq Tower 120
    1gb PQI turbo 2.5-3-3-7 1t
    eVGA 7800gt CO
    Raptor X 150gb
    PC Power and Cooling 510 SLI
    Viewsonic VP191B
  24. #24
    Sep 2006
    Quote Originally Posted by SkyGod
    Unfortunately it's probably limited edition and won't be available again. I think Crucial should consider re-releasing it under a different name as a high performance overclock friendly part. Something similar to the mushkin redline or Dominator series. If they can make sticks that do DDR2-1000 at cas4 and they're rated for 667 that's amazing results. Especially at the price they retailed for (MSRP is $311.99 at crucial.com now)
    Asus Maximus V Gene
    Corsair HX1000 PSU
  25. #25
    Nov 2004
    well thats to bad I'm kicking myself for not ordering the other night I had them in my cart at the egg, and I figured i would just wait (I haven't yet decided on all the components for my new rig) I thought to myself, if I wait worst thing that will happen is they will get cheaper... no dice you snooze you loose, lol
    ** this is not my day, the egg doesn't have the 6400c4 dominator up anymore either they had it up a few weeks ago then took it down, then put it back up earlier this week.
    eVGA 7800gt CO
    Raptor X 150gb
    Viewsonic VP191B
