"Project Mastercool"
This name was given when Chilly1 built a Phase unit inside trans am Case. My aim here is to improve on that version.![]()
Cool Master Stacker Case Overview
4Qman & Sacha35 Completed Project.
Spec:
E6400 Conroe L628B
P5B Deluxe
G Skill HZ F2 PC6400
7600GT "For Now"
Phase:
FR8.5
Ricky's Evap"Custom Enclosure"
R404a
Small Condensor "2x 12v 120m Fans Push Pull"
Doing NOW![]()
I was waiting for this thread to appear on here.
Awesome job mate, looks brilliant. The red paint on the compressor is really unique!
I take it the mirror above the compressor is to reflect all the heat?
Originally Posted by Brettbeck
Yes about time i know,. Sure it was worth the wait as its running sweet as a nut.
The Perspex enclosure around the Phase unit was the main thing to consider when taking this project on. It stops the heat from the Compressor going anywhere near the Board & Gfx Card.Oh and keeps the Compressor temps nice.
Very impressive finish!
- 146 939 + DFI LanParty UT nF4 SLI-D
- SS Chilly1
- Geil Ultra-X (bh-5)
- HIS X1900 XT Extreme
agreed, well done.Originally Posted by girth_maul
I have a stacker here also that I have contemplated many times to use in some way with phase but never got to doing it
ThanksOriginally Posted by girth_maul
Thanks Johann, seeing units that chaps like yourself build gives the new guys like me a standard to achieve.Originally Posted by johann
The air flow Works really well and the temps are about as good as id get on the FR8.5, id have liked to have used the NL11 i have hereBut as its such a tight fit it wasnt possible.
E6400 Loaded...
This is a Old pic when i was charging/testing the Unit.
Wow! Very impressive case.
I love it![]()
lads you have done us proud
i love the attention to detail
did you paint the comp after brazing or before?
Yo Baz, Your little bad boy Danfoss come to a good homeOriginally Posted by bazx
Compressor was sprayed by sacha after it was Brazed and leak tested for a weekAltho we did encouter a leak so a bit needed rebrazing which we simply did then sprayed after.
Sacha's attention to detail shows on every part of the case, it honestly is alot better in the flesh.
Well done your efforts paid off big time![]()
a unit like this takes time and cannot be rushed and that is what will set you both apart from other builderOriginally Posted by 4Qman
but you have made a rod for ya own backs now we will except nothing less
then this level of detailed work![]()
Originally Posted by runmc
AGREED:![]()
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ????????I forgot "you must"
runmc,bazx,wdrzal
Wow Guys im glad you like it, It took a fair time to achieve this finish but it was mainly due to sacha being so persistant, as im in the Marines im away most the time so he deserves most the credit![]()
We designed and planned the air flow as this was a big concern with Phase in Case build. I must say its working without a problem and temps are normal on the board and Gfx card.
The 120mm above the HDD blows air onto the compressor and out the front, with the 2x120mm fans on the condensor pull from the front and the perspex enclosure slopes the air onto the 120mm and back out.while the 2x80mm blow onto the HDD from the rear which keep them sweet.
Again i cant stress how much your kind words and comments mean.![]()
Cheers dude,Originally Posted by Moc
How its mounted
Condensor
mate top marks its nice to see it finally finished looks the nuts![]()
E6400 @ 3.2Ghz L630A 1.5v - GSkill HZ 0606 5-5-5-12 1000Mhz 2.13v -
P5B Deluxe - TuniqTower - XFi Music - Armour Case
That is MAD Stacker I love it.
WOuld you mind adding it to the Stacker SLacker thread?
I as many of the other Stacker Owners I think would be honored.
The vertical alum pieces, did you polish those? I am thinking about doing the same with mine as my case is nearing completion.
Again, congrats on the case and especially fitting that cooler in there.
super cool!!!
got to find myself a fulltower to pimp or a server case to make a cascade
regards,
q
As I said before, really nice.
One question, why did you use a FR8.5?
