Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Clockgen for Abit Kv8 PRO (K8T800Pro)
    Mar 2004
    Denmark
    Hello guys!
    One of my friends just got this mobo (Abit kv8 pro) and then we wonna know if theres a beta version of clockgen, or something for det via k8t800pro chipset??
    Shuttle SN95G5 V2
    AMD Athlon64 3000+ Winchester @ 2430MHz, 1.47vcore
    Club3D X800Pro 256MB
    1GB Kingston Value PC3200 @ 221MHz, 3-3-8-3, 2.7v
    200GB Maxtor DiamondMax 10
    NEC 3500A DVD±RW
    Acer AL1715 17" TFT
    Mar 2003
    Denmark
    "M-I-A"
    Mar 2004
    Denmark
    Nope, but i'll send it to him
    Shuttle SN95G5 V2
    NEC 3500A DVD±RW
    Acer AL1715 17" TFT
    Sep 2003
    With that version you can adjust the multi but it doesnt work for the fsb.
    I found the later version of uguru software works very well and has many options that can be adjusted in windows.
    ftp://ftp.abit.com.tw/pub/download/u...s/uguru/2.021/
    Mach II|FX55@3.2Ghz|Gigabyte K8NF-9|X800XT
    OCZ powerstream|HyperX BH5
    3D 01 35059
    Mar 2004
    Denmark
    So the one Bias is linking to, is only able to adjust multi ?
    In the version of ocguru you are showing me to, theres also adjustment for multi ??
    Damn, im tired |-)
    Shuttle SN95G5 V2
    NEC 3500A DVD±RW
    Acer AL1715 17" TFT
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    Hey there K32a,
    Is your friends a rev 1.1 board? I'm kinda curious as to how it clocks.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
    Nov 2002
    Earth: The Insane Asylum of the Universe
    bias_hjorth, are you sure that works? I emailed CPUZ just the other day, and they said ClockGen won't work with the uGuru chip.
    Sep 2003
    Damn, im tired |-)
    Yes clockgen will adjust the multi fine, there is no option in that version of uguru to change the multi, you can use it to change fsb and all the voltages for v core, v dimm and so on, it works well, just one thing the vdimm is now limited to only 2.8v which is a real shame and holds back on the overclocking ability of the board.
    Here is a screeny to show you the options.
    3D 01 35059
    Xtreme X.I.P.
    Aug 2002
    The older version of OCGURU lets you go up to 3.2v in the software
    Regards
    Andy
    Sep 2003
    Regards
    Andy
    Have you got it to work?
    I tried that and it didn't work for me, the machine just freezes and when I looked in the bios it had the most amazing chinese writing where it normally shows the voltage for the ram
    3D 01 35059
    Mar 2004
    Denmark
    Originally posted by Poki
    Hey there K32a,
    Hello, do i know you?
    Well, his board is rev 1.0 and the agp/pci lock wont work with the 15 bios on rev 1.0 boards, only on 1.1 A crappy thing.
    Shuttle SN95G5 V2
    NEC 3500A DVD±RW
    Acer AL1715 17" TFT
    Sep 2003
    Bios 14 enables the locks, if the board doesn't lock after you install bios 14 then it needs rma to Abit for a hardware fix.
    3D 01 35059
    Feb 2004
    CeBIT City
    Does OCguru confirm the lock?
    Pentium-M 1.4
    Kubuntu, KDE 3.x, 2.6.x
    Sep 2003
    Yes, if you set to fixed in bios and reboot, open uguru and if it shows 66/33 then its locked, if it shows 68/34 then lock is not on, 68/34 is the default on this board for some reason
    This applies to version 1.0 board.
    3D 01 35059
    Feb 2004
    CeBIT City
    It seems to work. But i've problems with my mushkin level II.
    Pentium-M 1.4
    Champion
    Jun 2003
    cape town
    i get a kv8-pro next week.
    anybody know if it likes single side bh-5
    Feb 2004
    CeBIT City
    Mine doesn't. Mushkin Level won't boot @ 200 MHz with 2.5V
    Pentium-M 1.4
  18. #18
    Sep 2003
    My mushkin Bh5 double sided is not good in this board, kingston BH5 single sided works ok for me.
    Imo the mem slots on this board are not good quality, even when the memory seemed as though it was correctly inserted I had the odd bsod and crashing which I knew was memory related. I know this sounds silly but now when I insert the memory I move it a little side to side, it seems to help with contact and that cures the problem.
    3D 01 35059
  19. #19
    Champion
    Jun 2003
    cape town
    ...kingston BH5 single sided works ok for me.
    excellent. i have 4 sticks of ddr 400 valueram bh-5. thanks for the info. if i may ask are you able to use more than 2.8vdimm and still maintain stability?
  20. #20
    Nov 2002
    Are you guys putting your RAM in DIMM 1 & DIMM 2? Try DIMM 2 & DIMM 3. I found out awhile back my AN7 is supposed to use 2 & 3, and it seems better on the KV8 Pro as well.
  21. #21
    Xtreme X.I.P.
    Aug 2002
    This is the UGURU I use to give 3.2v
    www.aocb77.dsl.pipex.com/uguru.zip
    Note non of my Mushkin bh-5 works with this board, all my Corsair XMS 3500 does. Corsair XL PRO also.
    Also note that VTT does not track VDIMM above 2.8v, at least on the board I had.
    Regards
    Andy
  22. #22
    Champion
    Jun 2003
    cape town
    i wonder if that can be fixed same as on the ic7-max3
  23. #23
    Xtreme Mentor
    Jun 2002
    1.1 should be out very soon, butr I guess they will clear old 1.0 stock first.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
  24. #24
    Jul 2004
    sheffield uk
    spaceman the kv8pro only has 2 dimm slots!!!
    so how can it seem better on the kv8 pro to use dimms 2 and 3?
  25. #25
    Nov 2002
    Doh, that's what I get for trying to think, at 2 or 3 in the morning. I'm not sure if my 2x512 of Mushkin are single sided or double sided, that might be why some work & some don't. BTW, I had the K8NS Pro in my rig not too long ago, and THAT one has 3 DIMMS, lol.
